11-11-2016, 10:17 PM | #1 |
Rep 22
Vinyl Carbon wrap finished! 09 Sdrive35i
finished applying my vinyl wrap on my trim! saw another members work and had to copy it!!! i had to snap the aft internal trim attachments on the door handle trim as it is melted into place from factory. reattached handle trim to door panel with 3m double sided tape. i drilled the trim attachments from the a/c and light selector sections and re-glued them back with epoxy. i highly recommend apply heat after applying vinyl to trim, it better activates the adhesive and form the vinyl in place. otherwise bubbling or "pleating" can occur after a few days. thats what happened to me. after i applied a little heat from my heat gun, three weeks and no issues yet.
2004 X5 3.0L Grey
2009 Z4 Sdrive35i Space Grey |
11-12-2016, 05:22 PM | #3 |
Rep 22
i had to use 2 rolls ($10 per roll 1ftx5ft) with a lot left over to wrap the trim. i might have been able to use one roll if i premeasured better. i was surprised how inexpensive it was for 3m vinyl and how nice the wrap quality was. it even reflects the weave differently at different light angles.
link to amazon https://www.amazon.com/gp/aw/d/B01DY...ds=TECKWRAP+5d
2004 X5 3.0L Grey
11-14-2016, 05:22 PM | #7 |
Rep 22
i bought a trim removal kit from harbor freight for about $5. plastic pry bars to prevent damaging the surrounding panels.
the only easy trim panel is the center column, gear shift selector. working the pry bars around the trim, it will pop right off. you will have to pop off the leather boot and remove it. disconnect the wire connectors, and then the trim will come out. the door trim panels have the aft ends with little posts that are "melted" on the inner side of the panel to secure it. i had to pry hard enough to break the melted ends off. the front half of the trim is clipped and and pops off easy. you will have to comfortable with just 3m double back taping the aft ends back in place after wrapping. the light selector trim and center "a/c control panel" trim are also melted into the leather panel with plastic posts. these are bigger round posts that were easy to drill off the melted ends. after wrapping, i epoxied the trim onto the panel at the drilled end locations. btw, the light selector panel pops right off, but the a/c panel. has multiple screw attachments below the trim with clips on top. you have to remove the radio to access the lower screws. there is a post in the forums that shows where the screw are. i will try to find it again and post the link. sorry no pics, i wasn't thinks of posting my results originally, but after all that work and how nice it came out i thought it would be good enough to show. let me know if i can elaborate any steps more clearly for you.
2004 X5 3.0L Grey
11-14-2016, 07:52 PM | #8 |
Rep 22
here is the link to the control panel removal and the screw locations. I don't have the NAV system so I had to remove the radio to get to the screws above the radio. If you have the CD player, I believe you can access without removing the player.
http://e89.zpost.com/forums/showthre...h+trim+removal |
12-31-2023, 07:09 PM | #11 |
31
Rep 78
Hi, Im a little late to the party here.
In the process of buying a 35is and planning to do a whole host of mods, including wrapping the interior trim pieces. The trim pieces are smooth, and not the carbon textured aluminium option. I have some experience wrapping intricate parts and was hoping to do these trim pieces without breaking them off the panel. Plan is to remove the panels. Take any attached switches and dials. Use knifeless tape around the edges to avoid cutting/ scratching the panels by accident. From you experience do you think a neat job is possible without breaking them trim pieces off the panel? Last edited by mittu; 12-31-2023 at 07:25 PM.. |
02-07-2024, 09:19 AM | #12 | |
70
Rep 202
02-09-2024, 12:56 AM | #13 | |
159
Rep 473
Second thing is that cars are getting older... all main issues have already been covered mostly and you can just google or search the forum, watch a video on youtube to find answers you need.. no need to post... I for example watched your steering wheel swap video recently... But yeah ive been on this forum since 2016... back then this forum still had people on that had bought or leased their z4-s new...it was a bit different vibe.. Now its mostly new second or even third owners that sometimes post questions and a handful of kind users that try to be helpful and answer...
2009 35i DCT Havana brown with ivory white interior. Mods: Cobb stage 1+FMIC, Wagner EVO1 FMIC, BMS DCI, KW V3 suspension, M3 front control arms, Hardrace RTAB, Michelin Pilot Sport 4S tires.
B21166.50 |
02-09-2024, 12:54 PM | #14 |
70
Rep 202
02-09-2024, 04:21 PM | #15 | |
167
Rep 625
Drives: E89 Atacama Yellow 35is
Back then a lot of cars were new, used daily, and there were a sea of mods and updates available….now many of the cars are garage queens, the mods are done.. I guess people find FB etc more instantly accessible…generally I find the quality and depth of information generally lacking on social media. I’m on another forum for older cars and the pace there is even more pedestrian….
Much modified 2011 Atacama Yellow 35is…previously a much modified 2012 Atacama Yellow 20i MSport
Change history here… https://www.dropbox.com/s/8h1vabklgz...0List.pdf?dl=0 Build thread here… https://z4-forum.com/forum/viewtopic.php?t=131886 |
mittu30.50 |
02-09-2024, 06:18 PM | #16 | |
70
Rep 202
B21166.50 |
