F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Coding for 6NR BMW Apps?
proTUNING Freaks
      11-01-2013, 02:36 AM   #1
hsk1610
108
Drives: 2013 328i xDrive
Assuming I have the FSC code, can someone tell me how to enable 6NR BMW apps? Tried searching but could not find what needs to be activated through ESys. Thank you in advance.
      11-01-2013, 05:58 PM   #2
HFW003
HFW003's Avatar
Australia
5714
Drives: 2024 M340i xdrive
If you shoot Shawnsheridan a PM I'm positive he will be glad to help you.
Shawn is the Yoda of coding and has helped me on many occasions.
Appreciate 2
      11-01-2013, 08:27 PM   #3
hsk1610
108
Yes, he has helped me out tremendously today with coding and resolving corrupted CAFD files and errors.
      11-01-2013, 08:40 PM   #4
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
You would have to add 6NR to your VO, write VO to car, Import and Activate the 9C FSC Code into Head Unit, then VO Code Head Unit / Combox.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
Appreciate 2
      12-15-2013, 01:10 AM   #5
hsk1610
108
I've added 6NR to the VO, imported and activated the FSC Code. Can you tell me what is involved in VO coding the Head Unit/ Combox? Is is editing the FDL using the CAFD file and adding the following?
A4A_REMOTE_APPS = aktiv - Adds "Apps" under Main Menu = > Connected Drive with Sub Menu BMW Apps (Facebook, Twitter, Web Radio). If 6NR is in the VO, or enabling this with no valid 6NR FSC Code, it will override CONNECTED_DRIVE = aktiv setting and ConnectedDrive on Main Menu will revert back to BMW Assist.
Where do I find the listing for the A4A_Remote_Apps?
      12-15-2013, 03:10 AM   #6
shawnsheridan
VO Code:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE.
      12-15-2013, 05:10 AM   #7
hsk1610
108
VO Code:
Shawn, then is that the end of the process after I click CODE or do I still need to go find the CIC HU and Combox and edit additional options?
      12-15-2013, 05:21 AM   #8
shawnsheridan
That's it. The benefit of VO Coding is that based on the option codes in the VO, it automatically makes all the required FDL Code changes needed to support those options.
      12-15-2013, 09:33 AM   #9
hsk1610
108
Thank you for your assistance, Shawn.
      12-16-2013, 07:48 AM   #10
hsk1610
108
Coded the ECU as instructed but had two errors and now I have the drivetrain malfunction and fuel system malfunction indicators on. How do I clear these or do I need to visit the dealer?
      12-16-2013, 10:25 AM   #11
shawnsheridan
VO Coding the Head Unit and Combox should not produce any errors, so I am not sure what happended.
You can try clearing them with Tool32:
Assuming the fault condition no longer exists, to clear the fault code.
1) Launch C:\EDIABAS\Bin\TOOL32.EXE
2) Hit F3
3) Load C:\EDIABAS\Ecu\F01.PRG
4) In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
5) Hit F5
6) "Results" window should show "JOB_STATUS = OKAY"
Hopefully, Problem Solved.
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
      12-16-2013, 10:35 PM   #12
hsk1610
108
2) Hit F3
5) Hit F5
Recoded the ECU and this time the coding worked without any errors and now I have BMW Apps showing under ConnectedDrive menu.
Unfortunately, the drivetrain malfunction would not go out. I guess it was a fluke that the malfunction happened as I was coding it. The car is at the dealer now.
      12-16-2013, 11:00 PM   #13
shawnsheridan
Weird.
      02-11-2014, 12:00 AM   #14
chizi
chizi's Avatar
United Arab Emirates
Drives: BMW M5 2012 Hamann
Weird.
hi yoda what are the step by step instructions to do this im a little confused im trying to code my f10 2012 to make the bmw apps work
      02-11-2014, 05:42 AM   #15
shawnsheridan
You just add 6NR to your FA and for CIC VO Code HU_CIC & CMB_MEDIA, or for NBT VO Code just HU_NBT.
But BMW Apps requires a 9C FSC Enabling Code issued by BMW AG for your VIN be imported and Activated in the head unit fist. Do you have the FSC Code?
      02-11-2014, 07:16 AM   #16
chizi
chizi's Avatar
No I don't have a code
      08-14-2014, 07:26 AM   #17
todor
Drives: E46 M3
How does one find that FSC code? Does BMW sell them or something? If they do, I'm sure they'll do the coding for you as part of the purchase... so what's the use case for doing this yourself?
(sorry, I know it's an old thread, but it's a related question)
      08-14-2014, 11:02 AM   #18
shawnsheridan
BMW may, or may not sell you a "6NR BMW Apps Retrofit". It depends really on the car's build date and equipment. If they do, and they performed the official retrofit, they would program (not code) the car accordingly. You of course will pay considerably more to have them do it then if you did the work yourself.
And in cases where you cannot get official "6NR BMW Apps Retrofit", you can usually obtain the FSC Code from various sellers, and perform an "unofficial "6NR BMW Apps Retrofit".
So, you do it yourself to either save money, or out of necessity when you can't get an official "6NR BMW Apps Retrofit".
Appreciate 2
Bugra8.50
      08-18-2014, 01:19 AM   #19
radair
radair's Avatar
21
Drives: G26 i4 M50
Hi Shawn, is it also possible to activate 6NR BMW Apps for HU_Entry & CMB_MEDIA?
I didn't find any information about that in the net.
Greetings
Roland
      08-18-2014, 01:40 AM   #20
kitster
United Kingdom
542
Drives: G31 M Sport
You need ProNav for 6NR
      08-18-2014, 05:39 AM   #21
shawnsheridan
Greetings
Roland
Kitster is correct. You need 609 Nav Pro in order to have 6NR Apps.
      08-18-2014, 08:37 AM   #22
steve@codemybimmer
BimmerPost Supporting Vendor
steve@codemybimmer's Avatar
Hong Kong
668
Drives: 2020 G20 320i M Sport
Have any of you guys gone back to the dealer for a software update after importing an activating the 6NR FSC code?
I know from factory, a CIC equipped F30 with 6NR would have 6NF and 6NL as their Bluetooth option. Will there be any conflicts with 6NH and 6NR written to the FA on VCM?
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming
steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca
Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs
f30post
