03-19-2022, 01:33 PM | #68 |
7
Rep 43
HI Guys,
Did the update and it came up with a few errors, its says I have NBTEVO Y on the idrive, but the screen didn't update with ID6 icons/settings/etc...also, the airbag light is flashing and the SOS emergency call error is also on the dash. link below is the screenshot of error log. THanks! https://www.amazon.com/clouddrive/sh...V1eDdu8tINO3uY |
03-19-2022, 01:35 PM | #69 | |
10535
Rep 41,159
Drives: 2018 Alpina B6 650ix GC
Airbag requires you Lock ACSM.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
tlow6.50 |
03-19-2022, 01:39 PM | #70 |
7
Rep 43
03-19-2022, 01:53 PM | #71 | |
10535
Rep 41,159
Try E-Sys Transmitter: Click "External Applications" in the left menu. Click "External Application" Double-click "Transmitter" Double-click "ACSM verriegelung_schreiben" Or Tool32: Tool32 => ACSM4.prg => steuern_verriegelung_schreiben = control_lock_write 1) Launch C:\EDIABAS\Bin\TOOL32.EXE 2) Hit F3 3) Load C:\EDIABAS\Ecu\ACSM4.prg 4) In the "Select Job: F01" window, select steuern_verriegelung_schreiben (steuern_verriegelung_schreiben = control locking write) Or Tool32, load the ACSM5.prg, STEUERN(ARG;VERRIEGELUNG_SG;0).
SaNGRia996.50 |
03-19-2022, 02:08 PM | #72 |
7
Rep 43
Sorry for all the newb questions, when I go to FDL code the HU_NBT2 for ID6, there is no CAFD to read...am I doing this wrong with the update?
Using the Esys didn't work for the airbag...there is also and option to click "ACSM verriegelung_schreiben_new" should i try that? if not ill go get tool32 and give that a try |
03-19-2022, 02:15 PM | #73 | |
10535
Rep 41,159
No, use Tool32 then. |
03-19-2022, 02:29 PM | #74 |
7
Rep 43
https://www.amazon.com/clouddrive/sh...Wngx4n2otPOAJi
https://www.amazon.com/photos/shared...dk6B7uFi8nkEMh Do you have a link to download tool32? Thanks again for all the help...you da man and a life saver |
03-19-2022, 02:59 PM | #75 | |
10535
Rep 41,159
PM sent.
SaNGRia996.50 |
03-19-2022, 06:02 PM | #76 | |
997
Rep 1,353
You can also do this in ISTA as well. But great to know it is on Esys.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
03-19-2022, 07:09 PM | #77 |
997
Rep 1,353
The right way of TAL calculation is shared in the very first page. Nothing different than that. Follow the steps. It will give you the answer. If you want remote support PM me!
03-19-2022, 09:06 PM | #78 | |
7
Rep 43
I cant see an active FA under VO, just the read...then tried click the read SVT under VCM and this error popped up: (also tried something else but dont remember how i got there and got this error: https://www.amazon.com/clouddrive/sh...OwgqsHNeuqtnul) https://www.amazon.com/clouddrive/sh...hoKlXvEvuVivXA Details: com.bmw.esys.domain.psdz.PsdzException: SVT <"ist"> could not be read. [C064] at com.bmw.esys.domain.psdz.Psdz.requestSVT(Psdz.java :1454) at com.bmw.esys.domain.svt.SvtLogic.readSvtActual(Svt Logic.java:184) at com.bmw.esys.gui.svt.SvtCompareController$SvtReadW riteController.doRead(SvtCompareController.java:85 5) at com.bmw.esys.gui.DefaultReadWriteController.read(D efaultReadWriteController.java:75) at com.bmw.esys.gui.ReadWriteSupport$ReadAction.doAct ionPerformed(ReadWriteSupport.java:93) at com.bmw.esys.gui.AbstractView$AbstractGuiAction.ac tionPerformed(AbstractView.java:234) at javax.swing.AbstractButton.fireActionPerformed(Abs tractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed (AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed (DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultB uttonModel.java:259) at javax.swing.plaf.basic.BasicButtonListener.mouseRe leased(BasicButtonListener.java:252) at java.awt.AWTEventMulticaster.mouseReleased(AWTEven tMulticaster.java:289) at java.awt.Component.processMouseEvent(Component.jav a:6505) at javax.swing.JComponent.processMouseEvent(JComponen t.java:3320) at java.awt.Component.processEvent(Component.java:627 0) at java.awt.Container.processEvent(Container.java:222 9) at java.awt.Component.dispatchEventImpl(Component.jav a:4861) at java.awt.Container.dispatchEventImpl(Container.jav a:2287) at java.awt.Component.dispatchEvent(Component.java:46 87) at java.awt.LightweightDispatcher.retargetMouseEvent( Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(C ontainer.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Conta iner.java:4422) at java.awt.Container.dispatchEventImpl(Container.jav a:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719 ) at java.awt.Component.dispatchEvent(Component.java:46 87) at java.awt.EventQueue.dispatchEventImpl(EventQueue.j ava:735) at java.awt.EventQueue.access$200(EventQueue.java:103 ) at java.awt.EventQueue$3.run(EventQueue.java:694) at java.awt.EventQueue$3.run(EventQueue.java:692) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:708) at java.awt.EventQueue$4.run(EventQueue.java:706) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPri vilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java: 705) at java.awt.EventDispatchThread.pumpOneEventForFilter s(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(E ventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThre ad.java:91) Caused by: job failed with negative response error: code: service returned global negative response description: Service RC_RLE_VCM returned a negative response with response code requestOutOfRange; LinkName: VCM_ETHERNET severity: ERROR Timestamp: Sat Mar 19 18:55:49 PDT 2022 ErrorCategory: VEHICLE_ERROR ID: 433 Class: com.bmw.psdz.vehicle.connection.util.ResultUtil ExecutionContext={category=TAL, ecuid=(VCM,0x10),PSdZEvent={message=MCDDiagService <id=454649, job=com.bmw.psdz.jobs.uds.vcm.MCD3_UploadFromVCM, service=RC_RLE_VCM - RoutineControl RequestListEntry, description=error: negative response : requestOutOfRange, link=VCM_ETHERNET>, timestamp=Sat Mar 19 18:55:49 PDT 2022, package name=com.bmw.prodias.execution.primitives.mcd, class name=SingleEcuJob, text id=MCD_EVENT_ID__JOB__SERVICE__DESCRIPTION__LINK__ , event id=default, event type=DiagService error, null}} at com.bmw.psdz.vehicle.connection.util.ResultUtil.fa ilJob(ResultUtil.java:132) at com.bmw.psdz.vehicle.connection.util.ResultUtil.ch eckResponsePositive(ResultUtil.java:90) at com.bmw.psdz.vehicle.connection.util.ResultUtil.ge tPositiveResponseOrTerminateOnError(ResultUtil.jav a:177) at com.bmw.psdz.vehicle.connection.wrapper.LegacyJobW rapper.getJobResult(LegacyJobWrapper.java:368) at com.bmw.psdz.vehicle.connection.wrapper.JobWrapper Factory$JobWrapper.execute(JobWrapperFactory.java: 152) at com.bmw.psdz.vehicle.connection.wrapper.JobWrapper Factory$JobWrapper.execute(JobWrapperFactory.java: 136) at com.bmw.psdz.vehicle.configuration.jobs.VCMJobs.re questMVTfromVCM(VCMJobs.java:145) at com.bmw.psdz.vehicle.configuration.VehicleConfigur ation.requestMVT(VehicleConfiguration.java:141) at com.bmw.psdz.vehicle.configuration.VehicleConfigur ation.requestSVT(VehicleConfiguration.java:157) at com.bmw.psdz.vcm.facade.VCMImpl.requestSVT(VCMImpl .java:255) at com.bmw.psdz.vcm.facade.VCMImpl.requestSVT(VCMImpl .java:1) at com.bmw.psdz.facade.VCMBF.requestSVT_aroundBody28( VCMBF.java:133) at com.bmw.psdz.facade.VCMBF.requestSVT_aroundBody29$ advice(VCMBF.java:55) at com.bmw.psdz.facade.VCMBF.requestSVT(VCMBF.java:1) at com.bmw.esys.domain.psdz.Psdz.requestSVT(Psdz.java :1447) ... 42 more |
03-19-2022, 09:31 PM | #79 |
10535
Rep 41,159
Well, than EVO is likely VO Code locked. PM sent.
04-17-2022, 10:10 AM | #80 |
Rep 16
Hi SaNGRia I have some question.
1. Can use this step for flash NBT Evo 2nd hand from other country ? 2. Are not use BIN file or not? I'm a beginner with coding but interested retrofit and coding from CIC to NBT EVO ID6. |
04-17-2022, 03:37 PM | #81 | |
997
Rep 1,353
As far as NBT EVO Retrofit goes, you can not do this process in the car otherwise you will lock the HU. You have to VIN Flash the HU on the bench before you install on a car. CIC is a different situation. Can be flashed and/or coded after installed.
05-12-2022, 06:24 PM | #83 |
997
Rep 1,353
Yes you can
05-21-2022, 01:19 PM | #84 |
Rep 6
Hi Guys,
Thanks for the very informative and great article I had the NBTevo_J version and id5 skin with working carplay(not full screen). And after reading your post I decided to flash my NBT to the latests vesrion to be able to activate full screeen option for apple carplay. So, the flashing process went well and I have the latest nbt version with id6 skin. And I also coded all necessary stuff APPLE_ENHANCEMENTS => aktiv HMI / HMI_39_39_128 => aktiv But there is some issue. Apple carplay doesn't work for now. I don't even have a carplay option in the connection settings when i try to pair it with my phone. Is it fsc code issue or I'm missing something? |
05-21-2022, 01:39 PM | #85 | |
997
Rep 1,353
FSC wont be effected by Flashing via Esys like this. Default code the unit. Delete all connections, Press and hold 70 sec exact on power button then re pair them. Lmk.
Alexey Brui5.00 |
05-21-2022, 03:20 PM | #86 | |
Rep 6
Anyway I tried previously to clean all connections and reboot the system. But it didn't help Last edited by Alexey Brui; 05-21-2022 at 03:24 PM.. Reason: typo |
05-21-2022, 08:48 PM | #87 |
997
Rep 1,353
On the Esys, you click the NBT2 and click CODE. It will default code it.
Alexey Brui5.00 |
05-22-2022, 02:27 PM | #88 | |
Rep 6
HMI_ID_VERSION => id6_light (had id5_plus_plus) APPLE_ENHANCEMENTS => aktiv HMI / HMI_39_39_128 => aktiv Also I enabled some of these flags CARPLAY_SWT = aktiv WLAN_DIAGNOSE = aktiv WLAN_STATUS = aktiv WLAN_WIFI_DIRECT = aktiv ENT_MIRACAST = aktiv ENT_MIRACAST_DISPLAY_SETTINGS = aktiv ENT_MC_WLAN_STREAM_DMP_COVERART = aktiv ENT_MC_WLAN_STREAM_DMP_VIDEO = aktiv Then I cleaned all connections, rebooted the system and tried to repair my phone and the car. But the Carplay still doesn't work Looks like the Carplay is connected but when I click on the connected device I don't have the Apple Carplay option and also music and other functions don't work. The Apple Carplay menu also wasn't shown I would be grateful if you have some suggestions Thanks! |
