BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Front springs only?
      08-31-2021, 02:37 PM   #1
brad65ford
256
Drives: 2022 M3
Front springs only?
Yes I know it sounds stupid and I apologize in advanced for asking this. But has anyone successfully just did from springs? The rear is perfect on my 19 comp the only thing I don't like is the front height.
      08-31-2021, 05:29 PM   #2
FatRear08
FatRear08's Avatar
1427
Drives: F90 M5
Buy a HAS kit and do them all. Then adjust front and rear as you want it. If you only drop the front, then the rear, even though you like where it is now, may be a touch high giving too much forward rake.
      08-31-2021, 05:49 PM   #3
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
I would not suggest this given the rebound rates on the front and rears would not be the same, so while it may look good, it may not feel that way when cornering, over bumps or on uneven surfaces.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      08-31-2021, 06:01 PM   #4
brad65ford
256
Drives: 2022 M3
Mine already rides unusually bouncing over multiple bumps. While I do follow you in theory that makes totally sense. But I doubt in real world one would even noticed it. Again assuming this, I could be night and day difference not sure though. Basically I have to do springs since I want the front lower, can start with the front since that is what IMHO needs it and its the easiest to do. From just height alone, the H&R sports M5 springs looked perfect drop to match the stocks rears but again I could be wrong.
      08-31-2021, 06:41 PM   #5
brad65ford
256
Drives: 2022 M3
Here is a pic of my 19 comp, doubt it has lowering springs but damn, I'm amazing people go lower. Looking at it from a photo makes me realize that its the right rake and if anything lowering everything is a must.
      08-31-2021, 06:58 PM   #6
FatRear08
FatRear08's Avatar
1427
Drives: F90 M5
You may have springs in there already judging from some other Comps I’ve seen.
      08-31-2021, 06:59 PM   #7
brad65ford
256
Drives: 2022 M3
Appreciate that FatRear08. I've been wondering this as well. Its just not as low as the M550i for sure from comparing. No clue honestly. I tried to look from underneath, seems these springs are way up in the body.
But after looking at other 19's comps, they do seem similar to my height. Maybe it is stock height. And now I know why none comp M5 want to lower theirs.
r33_RGSport12971.00
      08-31-2021, 07:03 PM   #8
FatRear08
FatRear08's Avatar
1427
Drives: F90 M5
I agree the M550i springs would have you sitting lower. That being said you may have a HAS kit in there.
      08-31-2021, 07:11 PM   #9
josec70
josec70's Avatar
Here you go .. this is my 19' M5C On HR 550i springs.
I would figure out what's in there and go from there. If you have HAS maybe you just need to make an adjustment on the fronts.
If you have springs then my suggestion remains swapping out all 4 and install a complete set based on the amount of drop you want.
      08-31-2021, 11:44 PM   #10
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
You'll be surprised.
90% of my customers a the Comp.
And they comes in to get it lowered.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
