BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Another possible brake pad option
      06-06-2021, 08:23 PM   #1
M090
77
Drives: BMW F87 M2 F10 M5 G05 X5
Just want to share another oem upgrade pad available now.
Just had endless installed over the weekend.
MX72, a step up from oe pad which is very prone to fade at high temp.
      06-06-2021, 08:47 PM   #2
shawnhayes
1834
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
The eip238 pad says it fits M5 2016 up. This seems off. Is that for the F10 M5?
It says on some websites it fits the M2 as well.
Is that the pad you got? Does it fit well? Where did you get it?
Shawn
      06-08-2021, 09:43 AM   #3
M090
77
Shawn
it's eip289, I had it preordered at a local shop during March and finally came.
Eip238 is for f10 m5, which is a different caliper to the f90 m5, eip238 will not fit f90.
      06-15-2021, 04:40 PM   #4
shawnhayes
1834
You have a source? Mine are giving the wrong numbers?
Shawn
      06-16-2021, 06:15 PM   #5
M090
77
Shawn
The shop I got it from is in Vancouver, local to me. You can probably contact endless USA if you are in the states.
      07-30-2021, 04:02 PM   #6
Tak M5
Drives: F90 M5C
I installed the endless front brake on my M5C.
Yes the squealing noise while braking is gone gone but I have a clunking sound while going over uneven surfaces and upon initial braking. It sounds as if the fitment is loose and there is play within the calipers. Any suggestions?
      07-31-2021, 02:08 PM   #7
shawnhayes
1834
Had the same problem in my M2 with Hawk DTC-70's. Awesome pad. They are made a little "looser" than the OEM pad. Either put up with it, or you can come up with something that will keep the pad from moving around as much. Lots of copper grease, or a titanium backing plate, or little rubber pads on the back of the pad (that's what BMW uses). It will not harm braking. But make sure it's just the pad "clunking" and they weren't installed improperly
Shawn
      08-06-2021, 03:11 PM   #8
Tak M5
Drives: F90 M5C
Well I installed these ferodo carbon brake shims on the back and around the front end of the brake pads. Noice is totally gone. Perfect now:
https://www.ferodoracing.com/products/accessories/
      08-09-2021, 07:13 AM   #9
shawnhayes
1834
Nice find. Looks a lot like what BMW uses on the back of the M sport pads.
Shawn
