BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Lowering just the front
      04-13-2021, 04:14 AM   #1
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
Hey guys I wanted to know if it is possible to just lower the front maybe an inch or so?
I have attached some pics for u to see. I'm on Titans 7s with 285-35-20 front and 345-30-20 rear on 4S. Running an aggressive camber of -2.6 and some fender rolling for rear. I happy with how the rear looks but would like to know if just lowering the front will mess with anything or leave it as it is?
Thanks for y'all's help.
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
      04-13-2021, 06:06 AM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
I would not do front only as the spring rates would not be uniform and possibly create some issues such as excessive rebound.
Maybe consider a sleeve kit (KW HAS or M Perf) so you can adjust front and rears to your liking.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      04-13-2021, 02:41 PM   #3
M5 F90 (2018)
141
Drives: M5
I was looking at my car this morning and thinking the rears look spot on but fronts could do with an inch drop and thought exactly the same about just changing the fronts and then thought about it a bit more and thought there might be issues. Shame.
      04-13-2021, 02:45 PM   #4
GTATX
GTATX's Avatar
Lol same here.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      04-14-2021, 03:25 PM   #5
Boiler Up!
Drives: 2021 M5C
Any of the HAS kits will allow you to set front and rear ride heights independently and have springs rates that are tuned to work together like the stock springs.
I have a M-Performance HAS that I'll be installing on my car when it arrives. Much like you, I've seen the front sits a bit high compared to the rear. I'll be lowering the front to equalize the gaps between the bottom of the fender/quarter-panel and top of the tire.
      08-31-2021, 05:46 PM   #6
brad65ford
256
Drives: 2022 M3
Wow another post on the same subject. Thinking I'm going try it since no one has yet.
