      12-28-2009, 04:45 PM   #45
Lech911
Drives: 120I 2007
here are the pics of my problem
      12-28-2009, 04:48 PM   #46
Lech911
Drives: 120I 2007
Red face
ok, the second picture i tried to show a couple of holes where 2 tabs should get in for the console to enter properly, they just get too low ive tried getting it back in any possible angle to try to raise these tabs to get into they respective holes but it just doesn't fit, please help me
and thanx for the reply
      12-29-2009, 12:48 AM   #47
GtiGyver
GtiGyver's Avatar
69
Drives: 2009 Space Grey E90 328i MT
Ok, first you'll need to make sure the trim under the driver's side and passenger's side dash is removed.
The console may need to be raised from the back significantly and wiggled into place.
Just noticed you have a 120i, the console is definitely different.
Still, FYI the console on the 135i doesn't just easily slip in place. You really need to play with it and move it from side to side and up and down. Eventually it'll just pop into place.
At least it did for me.
      12-29-2009, 05:31 AM   #48
Lech911
Drives: 120I 2007
i did remove both of the trims and (believe me) i've wiggled it a lot, but well, i'm guessing i'm just unlucky hehe,
I just secured it the way it is, and i'll bring my car to the dealer to see what they can do, thank you for all your help, this site and this thread rocks! I just got my bmw and i love all the stuff i'm learning here, thanx
      05-09-2011, 12:49 AM   #49
darkvaderr
Drives: 1M ordered
trying to do a cubby hole to ashtray swap
how easy it to scratch up the console or completely break it?
doesn't look like something I'd like to do to my new car, but any more experiences?
      05-09-2011, 06:23 AM   #50
merlinbk
27
Drives: None (yet)
Originally Posted by RobLS View Post
Painter's tape?
I saw this on my phone and thought the same thing. Lol
Automotive Photography
      10-22-2011, 03:12 PM   #51
Guam128i
Guam128i's Avatar
Drives: 08 328
How much did the carbon fiber interior trim cost and where did you buy it?
      01-14-2012, 11:45 AM   #52
MarkW112
Drives: BMW 135i
Hi guys,
Just trying to remove the centre console, and have for the past 1 1/2 hours been trying to disconnect the pictured connector (it had a purple bit on it, which I've removed to see if that helped), which goes from the armrest (phone cradle). I've managed to disconnect the other connector that came out of the armrest (bigger one).
Can anyone please advise how to get this connector apart?
      04-06-2012, 10:11 PM   #53
JefryHorizon
JefryHorizon's Avatar
Drives: Bus Pass
Feel bad for you folks with iDrive. I found out that you don't have to remove the panels under the passenger and driver side, just remove the plastic rivets and unclip them from the center console piece. I have a steptronic and putting the car in D gave the center console much more space to slide out. Super easy task compared to all the other mechanical stuff I've been working on. Thanks for the guide OP!!
      04-07-2012, 01:55 AM   #54
speedyjoe
11
Drives: E46M3/1M
Originally Posted by MarkW112 View Post
Hi guys,
I alsonran into the same problem as you after removed all nuts from the console but only these two cables. so if someone could post how to unplug these would be appreciated
      04-07-2012, 01:56 AM   #55
RaihaX
RaihaX's Avatar
Australia
156
Drives: 08' 135i
lol theres a clip that you need to push/pull from memory.
      05-13-2012, 04:55 PM   #56
pjueern
Drives: 120d, M-sport, BSR
No easier way to for example DI-NOC on the ashtray trim?
As its pretty easy on all of the other trim in the car, why should the ashtray be any different.
      05-14-2012, 09:11 AM   #57
ken1137
ken1137's Avatar
Drives: BMW S1000XR
2009 e90 335i  [6.40]
Hi guys,
I'm assuming you should be able to pull apart the two pieces. I dont have the iPhone cradle so I just have the female end of the connector which is placed in the same position you pulled it from on the console. Hope that helps...but not 100% certain. GL
BMWCCA member
      04-03-2013, 12:14 PM   #58
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
Drives: 2020 Tesla 3 LR AWD
2013 BMW X1  [10.00]
If I had known what a PITA this all was I wouldn't have swapped out my trim. But now it's finished. Thanks for the DIY!
      04-18-2013, 11:34 PM   #59
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
finally worked out how to remove the ash tray lid.
      04-19-2013, 10:05 AM   #60
cheshirecat79
cheshirecat79's Avatar
Drives: 370z & 135i
Would you like to share some details, sir?
      04-19-2013, 12:11 PM   #61
JimD
JimD's Avatar
368
Drives: 128i convertible
I was worried about damaging my console when I did this the first time so I priced it on RealOEM and found it was about $100. I figured I could risk that so I proceeded to install the drink holder you get with iDrive. Nothing was significantly damaged so I did it again in my wife's 1 (and automatic). If you are careful, I think this should be your outcome. Plastic pry bars will help a little but basically you just have to be careful and not apply too much brute force.
Germans definitely do not want their electrical connect to jiggle lose. That is a good thing except when you want to take them apart. You have to figure out what the mechanism is that prevents unplugging for each connector. It is generally a plastic notch on the outside of one piece snapping into a recess on the other side or some kind of loop around. The connector for the instruments is really clever in having the loop around lever jack the connections into position.
Jim
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09
      04-21-2013, 12:19 AM   #62
Moocow
Moocow's Avatar
Australia
24
Drives: 135i
2009 135i  [9.00]
I followed this guide
http://www.eurotuner.com/techarticle...t/viewall.html
Now I just have to work out how to remove the small panels under the inside door handles.
      09-08-2013, 03:43 PM   #63
steve116i
Drives: 2006 116i SE
AndyM
Hi there,
I understand this thread is quite old now, however I had the exact same idea in mind to change the dash trim to be montego/electric blue and I was wandering if AndyM or anyone else could tell me where abouts I could get hold of the montego blue dash/door trim?
Thanks
      09-08-2013, 07:19 PM   #64
AndyM
AndyM's Avatar
134
Drives:
Originally Posted by steve116i View Post
Hi there,
Thanks
LeatherZ.com
      10-23-2013, 02:00 PM   #65
XHRL
XHRL's Avatar
Drives: 2011 135i
How did you remove the center console on the DCT?
similar procedure or is it completely different?... Just received my wrap in the mail and about to tackle this job tonight!
      10-23-2013, 02:08 PM   #66
Mr Kleen
teh porcupine
Mr Kleen's Avatar
South Korea
97
2013 BMW X1  [10.00]
Same procedure but it's really difficult to get the console over the DCT. With a manual you can just put it in 4th. I would recommend having an extra set of hands and maybe try to remove the DCT lever.
