03-02-2022, 08:38 AM | #23 | |
130
Rep 391
Drives: 2021 M5C
03-02-2022, 01:06 PM | #24 |
123
Rep 105
It's everything that Fotios and FshnGry have described, to a T. They are much more eloquent than I am, but I wholeheartedly agree with them.
Turn in's are immediate, flat, and confidence inspiring. At higher speeds, the rear end feels more connected and less floaty. When driving normally, it feels completely stock. Not harsh like some coilover setups. Hope this helps. |
03-03-2022, 01:25 PM | #25 | |
Perennial PFC
336
Rep 1,275
I’ve had the Dinan tension strut ball joint on the work bench since last summer but didn’t want to dive into the install after doing the other two, thinking the car was new enough and the rubber in the thrust arm couldn’t be a problem yet. I put the Dinan ball joint in this winter, and now that the roads up here have cleared of snow for now, I took the car out for a drive. I just drove in the “normal civilized BMW driver” mode with a few faster turns thrown in, but the feel of the car is definitely changed for the better! I’m very surprised, and have to assume when the car is on track the improvement will be even more noticeable. It make me wonder, did BMW give the M5 CS a ball joint on the thrust arm? Those owners rave about the feel of the car, I wonder if that’s part of it? |
Holset274.00 |
03-09-2022, 11:18 AM | #27 |
Perennial PFC
336
Rep 1,275
CarBahn website says theirs does, Dinan doesn't show it for the M8, but I'd give them a call to see if that's just an oversight. I wish a new M5 CS owner would check to see if BMW put the ball joints on their car as stock equipment!
03-09-2022, 12:32 PM | #29 |
Perennial PFC
336
Rep 1,275
I did my own install, removing the strut entirely to press out the stock rubber bushing. Afterwards, I was told by a local independent shop that they are able to do the bushing replacement without removing the strut. Much less labor involved if they are able to press the bushing out by just unbolting the bushing end of the strut and pressing out the bushing while it’s still on the car. Apparently special tools allow them to remove the bushing that way.
03-11-2022, 02:16 PM | #30 | |
525
Rep 2,333
03-11-2022, 03:49 PM | #31 |
Perennial PFC
336
Rep 1,275
Took me longer than that, but I'm a slow worker. If the shop has to take the strut completely out, you have to unhook the front axles from the hub which is a pain. And to do it by the book, you need to replace the various bolts and nuts which come to about a $100 by themselves. I haven't seen the special tool the shop mentioned to me, but I assume it's similar to a bearing removal tool with the proper sized pushers to press out the rubber bushing. Maybe mention that approach to see if any of the quotes use the tool? It has to be much quicker than removing the strut completely.
03-13-2022, 08:27 PM | #32 | |
1834
Rep 1,320
Where is this arm so I can check? Shawn |
03-13-2022, 10:09 PM | #33 | |
525
Rep 2,333
03-14-2022, 07:27 AM | #34 |
Perennial PFC
336
Rep 1,275
Great, I was hoping someone would be able to look. Here's a shot looking at it from the wheel well. The panel covering it from below is held with maybe five eight millimeter socket screws. Or taking out the liner for the wheel well which is more of a hassle with 13 or so screws. That's the Dinan ball joint installed, and I'd guess if BMW did the same thing it'd look sort of like that. Not like the stock rubber piece at least.
The car feels better on turn in with this, and I'm betting BMW helped the CS with one of their own. Thanks so much! |
03-14-2022, 07:33 AM | #35 |
Perennial PFC
336
Rep 1,275
If I owned a shop and there was a way to save time on a procedure, I'd look into it. My guess would be that the tool would cost a few hundred dollars, and would pay for itself very quickly. To my thinking doing it on the car involves less disassembly and wear and tear on the various pieces. You'll like the change though, I was surprised.
03-14-2022, 12:16 PM | #36 | |
1834
Rep 1,320
Track review of CS coming. Chin Motorsports track event last week was AWESOME. CS is so much better than base level M5 on track. Shawn |
03-14-2022, 12:45 PM | #37 |
Perennial PFC
336
Rep 1,275
03-14-2022, 08:37 PM | #38 | |
1834
Rep 1,320
The ccb's are better for the short stops. The 160-69 slowdowns aren't any better on the straights. First estimates are I'm 3 seconds a lap faster in the CS. But I never drive 10-10ths. Looks like my best lap so far is a 2:08. I averaged about a 2:11 in the regular 2018 with a "hard driving" 2:09 and some change. Shawn |
03-14-2022, 08:48 PM | #41 |
Perennial PFC
336
Rep 1,275
3 seconds is pretty significant for basically the same car, but with refinements. I'd be happy with that. You might find it'll come down with more seat time in the new car, even on a track you're very familiar with. Oh, do the seats help? From the few pictures from Chin it looked like they have quality cars turning out. Yeah, odd hole in the arm. Not any weight savings, wonder why? Hard to see the guts of the bushing, but it does look different from my stock bushing in the base M5. Maybe it's just a stiffer material without a spherical bearing. Thanks for going to the trouble of taking the pictures.
03-14-2022, 08:51 PM | #42 | |
1834
Rep 1,320
My girlfriend had to stabilize herself A LOT in the 18 M5 during a lap. The CS, not so much. Shawn |
03-14-2022, 09:00 PM | #43 |
5234
Rep 10,616
There are 2 arms off the steering knuckle/front hub. The straight arm with the hole in it that you took the picture of goes more or less sideways to the subframe. The one that goes forward is curved and the one that the Dinan or Carbahn ball joint is meant for. It’s called the tension strut or strut rod.
03-14-2022, 09:09 PM | #44 |
Perennial PFC
336
Rep 1,275
Here's a photo of the stock bushing. Seems to be a slight difference to the CS version, but a picture from right underneath yours might reveal more. But, thanks for your help, it's not that important.
