04-10-2023, 08:04 PM | #1 |
1110
Rep 2,327
BimmerCode - popular coding settings for LCI?
So I got the recommended module and app, which ones are some of you doing for the LCI?
I think I would set use remote to close my trunk, seatbelt chime, video in motion...what else? |
04-10-2023, 09:03 PM | #2 | |
4094
Rep 3,675
Drives: 2022 M5C
I’m going to tinker with brake force display next — for safety purposes more so than aesthetics, so with activation only under the most extreme braking force option listed.
Not a BMW guy...but certainly an M5 guy.
NoMods1109.50 |
04-12-2023, 07:48 AM | #3 |
11
Rep 43
my m5 is red, so i added red ambient lighting.
uninterrupted window close if a door is opened when a passenger is closing a window rolls royce chimes start car with start stop deactivated - i decide when i want to use this and not the car!! passenger mirror reverse dip to 50% there is an option to control the exhaust flap through idrive, however i havent had chance to code this in |
04-13-2023, 08:54 AM | #4 | |
1716
Rep 1,909
Drives: 2023 M5C
IG @windtendo_m5
Maverik2594140.00 |
04-14-2023, 05:23 AM | #5 | |
41
Rep 38
04-17-2023, 07:31 PM | #6 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
Exactly. Shouldn’t need coding I thought. Turned mine off at the button day 1 and have never seen it since.
'07 Yamaha R1 (sold)
04-21-2023, 10:30 PM | #8 |
4094
Rep 3,675
Drives: 2022 M5C
The connection instructions don’t mention windows one way or another, but I would keep them closed if you’re coding anything related to window operation itself (i.e., window lifter interruption when opening a door) because it will not write properly if they are not sensed closed and you may receive warnings/codes that won’t clear without recoding or reverting to a backup (as opposed to the ones that will clear after the ECU and ignition restarts).
(I know you mentioned you got the BT adapter, I’m also assuming you have an iPhone).
NoMods1109.50 |
