BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    CarPlay Full Screen in the M5
      11-20-2021, 07:38 PM   #1
RobRed
ID10T Specialist
90
Drives: F90 | F97
Wanted this for 3 years in my 2019 M5 and finally had to dig in myself.
I did multiple searches to find instructions. I was able to piece together what i needed to know through various posts.
There are folks out there providing coding services as usual but I have tools so why not. I have eSYS and BimmerCode so I went simple first with BimmerCode and found success.
I'm not sure what's relevant here so here are the stats on my System:
CarPlay activated by BMW (1yr). Upgraded by BMW to lifetime.
I Level: S15A-21-7-555
111174.3.210
North American EVO 2018-2
NBTevo_X20511I
Telephone: TB-007.030.001
Media: TB-007.030.001
BimmerCode Full Version: 4.1 (12440) - 13.1.0 using Vgate iCar Pro Bluetooth 4.0 dongle
1 - Logged into the car with BimmerCode
2 - Headunit [module]
3 - Chose Expert Mode
4 - 3000 HMI [module]
5 - Scrolled for a zillion lines to CARPLAY_FULLSCREEN, tapped > to open
6 - Tapped "aktiv" (was nicht_aktiv)
7 - tap <
8 - tap Back
9 - tap Code
You'll need to reprogram favorites anytime you code the head unit.
Appreciate 5
SGMM5115.50
Jamesmick131.00
      11-22-2021, 02:38 AM   #2
euro*
euro*'s Avatar
1658
Drives: F90 M5
Tried to do the same just now, no luck . I've also tried this maybe a year ago and had the same results as I did today. Still wanted to try it, thinking that maybe BimmerCode changed something with their update, after seeing your thread.
Once I coded it, on the right of the CarPlay screen I just get a white box. Same results on my '19 M5 and my wife's '19 X3
      11-22-2021, 08:22 AM   #3
m_fife
m_fife's Avatar
Drives: 2018 M5
You have to be on version "NBTevo_X" or above for this to work.
2018 Alpine White ///M5
      11-22-2021, 12:08 PM   #4
euro*
euro*'s Avatar
1658
Drives: F90 M5
Both cars are NBTevo_X
      11-22-2021, 06:36 PM   #5
Ptoscano911
Drives: F90 M5
Shoot I was about to do this.
      11-23-2021, 07:40 AM   #6
m_fife
m_fife's Avatar
Drives: 2018 M5
What I-Step are you on?
      11-23-2021, 12:03 PM   #7
Mick0005
Drives: 2013 M Sport F30 335i xDrive
I recently did this with this method from another forum member and it was a no brainer. Worked fine and highly recommend. Current FX makes it like $27 USD.
      11-23-2021, 08:12 PM   #8
RobRed
ID10T Specialist
90
Drives: F90 | F97
euro* I've seen on other threads when researching this that the white box appeared - I'll try to find the reference.
Do you have other coding setup? Perhaps another setting is causing an issue?
This is a bummer.
ps I added a couple more data points (in my first post regarding my system but I doubt that has any bearing.
111174.3.210
      11-26-2021, 03:03 PM   #9
m_fife
m_fife's Avatar
Drives: 2018 M5
Also how is your CarPlay activated? From BMW or aftermarket?
      11-26-2021, 03:15 PM   #10
RobRed
ID10T Specialist
90
Drives: F90 | F97
For reference my CarPlay was activated by BMW (1yr). Upgraded by BMW to lifetime.
      11-27-2021, 08:59 AM   #11
euro*
euro*'s Avatar
1658
Drives: F90 M5
This is a bummer.
111174.3.210
I ended up getting M5 coded by a member here from the forum, and he did the full screen for me with some patch file, and remote coding over esys
About your other questions, CarPlay in both cars came from factory, lifetime.
M5 had other coding, X3 didn't have any coding before.
      12-02-2021, 07:24 PM   #12
myounz
myounz's Avatar
156
Drives: M3 Competition
Just wanted to chime in and say this worked like a charm on my 2019. The previous owner did the trick to get it full screen but BMW flashed my iDrive when taking care of a recall. This trick worked on brought my back to full screen from split screen. Thanks RobRed !
      12-03-2021, 12:41 AM   #13
Wojti_
17
Drives: BMW F11, G30
Carplay full screen is possible from Soft N, now the newest is Y
      12-05-2021, 12:08 AM   #14
RobRed
ID10T Specialist
90
Drives: F90 | F97
Awesome glad I could inspire you :-)
      12-26-2021, 01:13 PM   #15
Camarejh
Camarejh's Avatar
Drives: 2021 BMW M3 Competition
This is a bummer.
111174.3.210
Can you hook me up with this guy who did the remote coding? I dont even have apple carplay in my 18. I was going to activate it through connected drive but im scared ill get the 3/4 screen and wouldnt waste 300 bucks on that
      12-26-2021, 01:17 PM   #16
euro*
euro*'s Avatar
1658
Drives: F90 M5
This is a bummer.
111174.3.210
Vick, His whatsup: +60 12-396 9654
      12-26-2021, 01:20 PM   #17
Camarejh
Camarejh's Avatar
This is a bummer.
111174.3.210
For some reason its not working on whatsapp
      12-26-2021, 01:22 PM   #18
euro*
euro*'s Avatar
1658
Drives: F90 M5
This is a bummer.
111174.3.210
Not sure. Make sure you enter the number correctly to your contacts. That number is 100% correct and works
      12-26-2021, 01:25 PM   #19
Camarejh
Camarejh's Avatar
This is a bummer.
111174.3.210
Nvm i got it to work thank you!
      01-18-2022, 02:46 PM   #20
mdemon
mdemon's Avatar
Drives: AY F80 M3
Sub
      04-05-2022, 10:28 PM   #21
johnronin
Drives: F90 and G05
has anyone got a simple fix for the white box on the side? I coded fullscreen carplay and got carplay looking like euro* pic. My car is EVO -N and has lifetime carplay.
      04-06-2022, 02:31 AM   #22
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Simple solution - buy one of the many USB or ENET solutions out there. Process is completely automated.
  • Evo-N or O can be USB activated
  • Evo-P or higher requires ENET
I recommend ENET solution as it will future proof you, in case vehicle software gets updated to P or higher.
Alternative would be convincing dealership to update software to X so you could simply code via BImmercode or E-sys.
