Boost falls like a rock at exactly 5000rpm...log inside?
09-09-2015, 01:53 AM | #23 |
101
Rep 229
Drives: 08 E90 335i 6 spd MT
so after reverting back to stock and letting map 7 adapt again.. same sh** is going on.. .tappering down to 16 psi is happeing at around 3500rpm... I have attached logs. one in map 7 showing boost drop again. and a second one with map 2 where turbos hit target all the way through. I am reaching out to Terry - to see if he has any insight - or can point me in the right direction. |
09-09-2015, 04:45 AM | #24 |
648
Rep 779
Are you thinking the stock turbos are going to hold a 19-20psi target up top? Both logs above end at 16psi. Asking for much more than that over 6000 rpm on stock turbos is almost an exercise in futility. It can be done, but the efficiency and shaft speeds would be horrendous.
If you want to hold big boost over 6000 rpm, you need turbo(s) that can actually out-flow the motor at high RPM. Boost is a measure of restriction. The engine is an air pump and when it flows more air (high RPM) than can be fed to it (stock turbo CFM), the pressure inside (boost) falls. Barring anything I missed in the thread, boost falling off over 5000 rpm is entirely the norm for stock (really small) turbos. If you're keeping 16psi at 6000rpm, you're doing just fine for stockers. |
09-09-2015, 06:06 AM | #25 | |
650
Rep 2,019
335i e92 TPC 19Ts
09-09-2015, 11:09 AM | #27 | |
101
Rep 229
Thanks for your feed back! I am 6 months into this platform and I am learning as fast as I can. I appreciate you guys taking it easy on me. In conclusion, I guess I am asking the little snails more than they can handle. RSL, your statement above makes perfect sense! Thanks for the info: I guess the best thing for me to do is run a custom map:6 with a set boost curve that is more appropriate for what the td03's can handle. |
09-09-2015, 11:50 AM | #28 | ||
648
Rep 779
09-10-2015, 03:15 PM | #29 | |
101
Rep 229
Thanks for the INPUT GUYS! Much appreciate it! Thanks to people like you my learning experience has been great! |
09-11-2015, 07:17 PM | #30 |
261
Rep 1,093
Okay so what I've found so far in every log that has remained consistent is MAF g/s is being CAPPED at 286 g/s. On every log (I've logged twice a day for a week now) boost tapers exactly so that 286 g/s is maintained but not exceeded. WHY! Increasing load doesn't help as MAF request already exceeds 286 g/s. Increasing ceiling and adder does nothing useful because PID freedom doesn't seem to be the problem. the problem is whatever is causing MAF g/s to be capped. I don't know what that is. I would have killed to make 286 g/s on my old K04 GTI but this is WEAK on this platform. I also notice that the intercooler worked TWICE as well this time last year. Where temps rise 15 deg now they only rose 7 deg last year. I had stock airbox last year vs AFE now which may play a role but I don't even care about that right now. Did I mention the car runs and feels great right up to 5000rpm. I don't expect any miracles with the stock turbos but I'm definitely missing a couple lbs of boost in the 5300-6000 rpm range.
Here's a log showing what i'm talking about with the MAF g/s capping despite request for more. Everything has been massaged since OP log. Better overall but not there. http://datazap.me/u/stanlalee/log-14...&data=19-20-23 I've tried broad range increases/decreases with base WGDC but that just messes with 2500-5000rpm boost control. I'm perfectly happy with everything up to 5300rpm. All ears lol. BTW this is not a MHD tune. they are all based from OFT OTS tunes (with LOTS of changes) which all followed target boost to a T before this started happening. I'm going to throw a fuel pump at it since mine is weak but you can see in the above log it never dipped below 50 (but trims are horrible! Could that cause the cap?). |
