04-03-2024, 08:23 AM | #1 |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
182
Rep 302
After having bought the "CDV Free" clutch slave 2 years ago, I finally got around to changing the CDV out, but I didn't even have to use the new clutch slave.
Kern417 made a great video showing how to do it for FREE11!!1! https://www.youtube.com/watch?v=CFict1fzerE All you need is to get the central under panel off with 8mm and 10mm. For this job, you'll need: -#8x3" wood screw - locking plyers -13mm socket -3/8" ratchet and short extension Benefits of this mod: The driveability benefits are numerous: - less clutch slippage between shifts which makes engagement quicker and puts less wear and tear on the clutch so it should also last longer - less whiplash on engagement if you know how to shift and don't have to wait so long for the CDV to bleed out so you can keep up with traffic easier - quicker engagement means on fast shifts it retains more boost between gears (without powershifting). I was able to maintain 6psi boost which made the car accelerate much faster. I felt like I hit a 50 shot of nitrous compared to how it was before. This was a benefit I never expected with this mod but I think it is legit and it makes sense. I always felt like the throttle tip-in on shifting was soft on this car so I'm hyped that this made a huge difference. This is one of those things that doesn't require higher octane, a more aggressive tune, or have any real negative consequences (so long as you're not dumping the clutch at every stop light, shocking the drivetrain.) Overall 11/10 mod because it's free and helps with performance and reduces clutch wear. Update: pedal was a bit soft so I bled the clutch line with my Motive Power Bleeder (M2 uses same reservoir for clutch and brakes). Fluid was dark so I'm glad I did. I would suggest bleeding the clutch line as part of this mod. |
04-07-2024, 09:46 AM | #3 |
182
Rep 302
The only thing I would add is that I had to bleed the clutch line as it got a bit soft (but still worked.) Luckily I had some SRF leftover and a Motive bleeder.
04-07-2024, 11:30 AM | #4 |
BimmerPost Supporting Vendor
24477
Rep 191,448
05-05-2024, 02:57 AM | #5 |
204
Rep 185
Conservatively, I would not recommend doing this. BMW engineers and particularly, M engineers, are smarter than you. It is there to serve a purpose. It feels snappier because your essentially releasing the clutch more abruptly, which will wear and tear your mechanicals a lot faster. Another thing to consider is one of the reasons why MT6 is less prone to crank hub slippage than AT is because of these clutch characteristics.
2019 M2C Sunset Orange 6MT
Eventuri Intakes Eisenmann Valved Full Exhaust |
05-10-2024, 07:14 PM | #6 | |
136
Rep 116
Otherwise, I removed my cdv and appreciate the more direct clutch engagement and improved 1st to 2nd shift. |
05-11-2024, 09:01 AM | #7 |
4629
Rep 4,727
I swapped to a valve that doesn't have the CDV. Like most mods I immediately noticed it and within a day I adapted and now couldn't tell you what it was like to drive the car with a CDV. It would be interesting to drive someone's stock car without CDV delete, UCP, and AS shifter.
Telluride135.50 ///MPhatic14159.50 |
05-11-2024, 01:20 PM | #8 | |
136
Rep 116
However, when I first got my car (with the cdv installed) and experienced running it through the gears at full fury, shifting just prior to hitting the rev limiter... I wondered if my left foot was riding the clutch pedal between my 2nd to 3rd or 3rd to 4th upshifts. Being my first BMW and ignorant of a cdv, I definitely questioned if I had forgot how to drive a stick! |
05-11-2024, 03:24 PM | #9 |
511
Rep 882
BMW makes cars for everyone, everyone can't engage the clutch properly.
I prefer driving without a CDV and the delayed reaction it produces, haven't removed it on the M2 yet though.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
05-12-2024, 12:38 AM | #10 | |
477
Rep 723
If the clutch engagement was more predictable and linear, I'd be on the clutch a lot less because I'd be more certain when it engages and could build up better/more precise muscle memory. As it is now, it's kind of a crap shoot. Obviously you don't want to be on it too little because then you run into driveline shock, but there's a good middle ground, which in some MT cars is very easy to find. Engineering is rarely just making the most optimal decisions. There's cost, customer feedback, deadlines, and decisions from management all playing a factor. In that sense I think the CDV is a perfect example of good engineering, but a bad end result. |
05-12-2024, 08:03 AM | #11 |
The Seeker
14160
Rep 3,417
I've considered doing this many times, but with the way I drive the car I don't think it's necessary. If I do it, I'll want it all, which is NO MORE DAMN REV HANG, and a lighter flywheel. This car loses revs so terribly slow, and it bugs the isht out of me.
05-12-2024, 08:30 AM | #12 | |
4629
Rep 4,727
I do think there are situations where the CDV and rev hang compound on each other. Especially during attempts to quick down shifts.
05-16-2024, 06:35 PM | #13 |
136
Rep 116
Have not watched many of Joe's M2C videos but this video hit my YouTube feed. What do you know, he briefly touches on the benefits of removing the cdv. Subjective... but I agree with his take. Watch from the 8:45 mark.
Plus, he has nothing but raves for the F87 M2C. |
