01-22-2023, 11:58 AM | #1 |
130
Rep 214
Offsets and Sizing
Hello,
Wheel gurus…. Will these wheels work and looking to have them be flush. Wheel Specs: Brand new set of 4 Rohana RFX17 ROTARY FORGED Wheels / Rims WHEEL SIZE: 20 WHEEL WIDTH: 10.0 FRONT AND 11.0 REAR WHEEL OFFSETS: 22 FRONT AND 32 REAR BOLT PATTERN: 5 X 112 FINISH: GLOSS BRONZE FINISH 285/35/20 Front 295/35/20 Rear Car is stock height non comp but might also look to go with M550I springs. |
01-22-2023, 01:09 PM | #2 |
1569
Rep 29,202
Compared to the OEM wheels, the front will stick out 12mm and the rear will stick out 2mm.
Patton2502939.50 |
01-22-2023, 01:25 PM | #3 |
130
Rep 214
01-22-2023, 01:41 PM | #4 |
5234
Rep 10,616
Many put 15 mm spacers on their stock front wheels. I think you will end up ok factoring in the decreased wheel offset pushing the wheel out by 6 mm plus half of the 12.7mm increased wheel width (the half of the 10mm increased tire width should not add to that since it is sitting on top of the increased wheel width). You won’t want a spacer.
I plan to run that size up front on my similar spec Titan7 TS5. I have H&R M5 springs but people have run this same combination with the 550xi springs. |
01-25-2023, 09:10 PM | #5 |
1104
Rep 1,083
The front is ok, rear I would throw on 8mm spacers
Below is 21x10 ET22 front and 21x11 ET24 rear to give you an idea on flushness, moderate drop 285/30/21 and 295/30/21 I personally prefer the rear to be slightly more flushed than front for a perfect stance Owner's IG: https://www.instagram.com/bmwgram/
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
01-31-2023, 09:34 AM | #6 | |
682
Rep 527
02-02-2023, 08:23 AM | #7 |
1104
Rep 1,083
dcohen13682.00 |
