04-25-2020, 03:06 PM | #4 |
104
Rep 195
Titan 7, forged and about 800/wheel. Best value I could find and went that direction. Setup is 285/35/20 and 305/35/20. You can go smaller tire size than that if you want, mine is the max you can do.
04-28-2020, 09:30 PM | #5 |
251
Rep 2,251
thanks for info so far these are only ones ive been able to find as well. Trying to find other though and maybe 19's too!
05-07-2020, 10:04 AM | #6 |
In the Details
1810
Rep 867
Drives: Yes
Garage List 2020 AMG GTR [0.00]
2022 R8 Quattro Spyder [0.00] 2023 X5M50 [0.00] 2023 718 Spyder [0.00] 2024 Silverado [0.00] 2024 Civic Type R [0.00] |
I'm running 295/35/20 and 305/35/20 PS4's on my titans. That keeps the f/r ratio like stock and it fits and looks amazing. It's also lowered on Eibach springs.
Jonathan G.9.00 derrickcz1.50 |
05-07-2020, 12:33 PM | #7 |
283
Rep 288
Drives: 2018 F90 M5
Dinan 20" wheels are worth a look. Significantly lighter than stock.
$3k Lightweight (Front: 22.5 lbs; Rear: 23.6 lbs) https://www.dinancars.com/products/w.../D750-0093-BRU
BMWs: 03 E39 M5, 22 330e, 23 X5 45e
2016 Porsche Boxster Spyder 2016 Toyota 4Runner Sold - 2018 M5 |
05-07-2020, 06:45 PM | #8 | ||
Rep 19
I would like to run a square tire and wheel set up. Would you advise 285 or 295 square and with 4 Titan7 "front " wheels or 4 Titan 7 "rear" wheels?? Thanks!! |
05-07-2020, 08:42 PM | #9 | |
In the Details
1810
Rep 867
Drives: Yes
A 295 on front wheels mounted on the rear will push the sidewall out 11mm and......... the front will come out 16mm which is very similar to popular spacer widths. A 295 on rear wheels mounted on the rear will push out only 3mm and 295 on rear wheels mounted up front would push out 8mm. I would definitely go with fronts on 295s for a square setup. The rear will be a little tight but you can run a bit more camber and be ok or just go with rear wheels and 295s and be similar to stock clearance. |
05-07-2020, 09:18 PM | #10 | ||
Rep 19
Would any recommendations change if I went with 285/35 square set up and just used bigger spacers? I have run square 285/35 winter tires on the staggered 9.5"/10.5" oem wheels and was happy with that. I was going to leave the winter tires on the oem wheels and go with a square Titan7 set up on the summer tires. For me , the advantages of tire rotation and tire life with square set up outweigh the slight stagger looks |
05-07-2020, 11:07 PM | #11 |
In the Details
1810
Rep 867
Drives: Yes
In my last sentence I suggest using rear wheels if you are concerned about clearance.
05-07-2020, 11:24 PM | #12 |
195
Rep 612
295/35 and 305/35 setup looks killer.
I’m going 285/35 front with 305/35 rear on mine. Will try that first on 20’s and next setup will be 21’s |
05-10-2020, 01:07 PM | #14 |
102
Rep 352
20 inch Titan 7 wheels are about 4-5 lbs lighter than stock 789M forged wheels. That is very minor difference that will get eaten up by the larger tire size. The only way to lower weight is to go 19-th in size.
05-11-2020, 06:43 AM | #15 | |
In the Details
1810
Rep 867
Drives: Yes
typically when you go to wider wheel and wider (and taller) tire and still weigh less you are ahead. |
Jonathan G.9.00 |
05-12-2020, 05:38 PM | #16 | |
102
Rep 352
And you could go R-compound with plenty of choices in 19 inch size. Lower price too. |
05-13-2020, 06:52 AM | #17 |
In the Details
1810
Rep 867
Drives: Yes
yes, I am sure an R compound tire is very popular on the F90.
01-19-2023, 03:08 PM | #18 | |
Rep 11
Drives: BMW F30 328i
So 305/35/20 is way to big you want diameter to stay as close to OE specs as possible. Look up tire comparison calculator. 305/35 would be roughly 1.9% bigger diameter and almost 2in circum. that's quite a bit. Problem is can't go down from 35 to 30 on sidewall it would be way to small . 295/35/20 is your best bet at only about .7% bigger diameter and .8in circum. Maybe you know this but just in case. |
01-29-2023, 06:10 PM | #19 |
133
Rep 391
Drives: 2021 M5C
01-29-2023, 06:17 PM | #20 |
In the Details
1810
Rep 867
Drives: Yes
01-31-2023, 11:41 AM | #21 |
681
Rep 527
hit up https://www.rexracingwheels.com/ fully forged and 100% custom. Turnaround is 5 weeks.
