10-12-2011, 01:04 PM | #1 |
104
Rep 1,653
Win 7 registration problem
i did a clean install on my new build PC, and i tried to register it with a purchased key from microsoft......and it gave me this error.....is there a way around it or do i have to install and upgrade it again?
2011 E92 Space Grey/black + Tech + Premi + Heated Seats
10-12-2011, 02:23 PM | #2 |
33
Rep 576
That error shows that the product key is for a windows 7 upgrade, which is not a clean install like you did. For that product key to work you need to have an old version of windows installed, such as vista, then do the win7 upgrade and use that key. I think u purchased the wrong key/cd?
10-26-2011, 06:10 PM | #4 |
Careful, I Bite.....
153
Rep 504
Or, you can:
1) Install W7 without putting in the CD key. 2) Upgrade from W7 to W7, this time putting in the CD key. 3) Activate W7 as normal. This was the way to do it for Vista, and should work also for W7. Got this from a tech website: click Start, type: CMD Right click CMD, click ‘Run as administrator’ At the command prompt, type, regedit Go to HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersionsetup/OOBE/mediabootinstall change its value to 0 Go back to the Command Prompt, type the following: slmgr /rearm Restart the pc and use the activate windows to re-enter your product key Last edited by MadDog; 10-26-2011 at 06:19 PM.. |
