12-30-2014, 04:55 PM | #1 |
62
Rep 581
Trying to determine if I have hybrid turbos..
Hello, all.
I am trying to determine if the turbos that came equipped with my car are hybrids. Is there any physical differences I should look out for in comparison to oem turbos? Also, I have a very bad wastegate rattle so would that necessarily mean by default that I do not have hybrids? Thanks, Durim
08' Sparkling Graphite Metallic E82 135i. 6spd Manual. |
12-30-2014, 05:38 PM | #2 |
European Editor
10642
Rep 22,992
I really don't know what you mean by: "hybrid turbos" ???
Your turbo(s) are covered for 80K miles or 8 years. IF your car is over that, it is quite possible BMW would still cover most of that job. You might want to ask your local dealer.
12-30-2014, 05:41 PM | #3 |
192
Rep 2,235
Are you asking if you have RB's or something and didn't know it?
I'd say thats impossible unless for some foolish reason you don't have a JB4 yet. You'd know if you were making mega power wouldn't you? I am curious how a set of RBs would perform on a bone stock tune, my guess is probably not very well at all. What makes you think you have anything but the stock anyway? Turbos are expensive, I doubt anyone would just trade it in without swapping with stock turbos first. Its like throwing away a few grand. |
12-30-2014, 05:43 PM | #4 |
62
Rep 581
"Hybrid" turbos, meaning RB and/or Vargas where the oem turbos have upgraded internals i.e compressor wheel, housing, waste gate, etc.
12-30-2014, 05:49 PM | #5 | |
62
Rep 581
I am under the impression I purchased a preowned 135i equipped upgraded hybrid turbos. Current Mods: JB4 G5 ISO Map 7 E85 Backend Flash E60 BMS 3" kittyless down pipes Berk Race Axle Back BMS DCIs ER Charge pipe w/ Tial Q BOV VRSF 7" FMIC w/ upper charge pipe Walbro 255 lpfp The reason why I believe this to be so is because I and others believe my car to be excessively fast. I have comparison videos to other cars but I do not believe them to be appropriate for this forum. My question is, does having a waste gate rattle necessarily mean I have oem turbos? |
12-30-2014, 06:12 PM | #6 |
22
Rep 406
I've followed a few of your videos but i don't think you have raced another 135 with similar mods try that see how that goes then try to race a upgraded turbo N54. Best idea I can come up with without dropping the subframe to get into the turbos.
12-30-2014, 06:15 PM | #7 | |
62
Rep 581
BMW has offered to change my turbos under warranty however, my main concern is that I would potentially swapping out upgraded turbos for oem. |
12-30-2014, 06:22 PM | #8 |
22
Rep 406
you can also try to dyno the car and see if your numbers match anyone same mods or bigger turbo although weather has been fairly warm by us especially xmas day and racing would be more fun best bet is prob a dyno
12-31-2014, 01:32 AM | #9 |
aiming for 450.....
304
Rep 2,910
You'll have to drop the downpipes and see the exhaust side of the turbos. If I remember correctly and seeing a side by side comparison pic of both stock and RBs I found on E90post, the hot side impeller is larger (noticeably) than stock.
I honestly don't think you will be able to tell just from the outside unless you can tell the difference on the thrust arm for the waste gate which on some previous RBs are upgraded.
Quote from Ezeedee regarding car mods:
"you're only done when you sell the car " |
12-31-2014, 01:49 AM | #10 |
29
Rep 414
I stumbled upon your videos the other night. I bet if your waste gates are
Rattling you have stock turbos. Your car seems to be setup pretty well and that would explain why you're beating such fast cars. I bet your car is putting down 450whp and 500ft which is good for a 3300 pound car.
2008 Aw/Coral Red Manual 135i Coupe-
JB4 G5 + BMS race flash, BMS meth kit, VRSF DP, Big tom Ic, BMS chinese tester CP, Custom Muffler Delete, BMS Oil Cooler Valve, Cowl Filters, Clutch Stop, B&M Short Shifter, Spec Stg 2+ Clutch W/ Oem dmfw, Vmr V710, KW v2, M RSFB, 1M Front and rear Bumper, Performance Side Skirts, slek trunk, Lci blacklines.] |
12-31-2014, 03:34 AM | #11 |
1688
Rep 3,141
Drives: 2014 M5 6MT
The compressor and turbine housings are the same on the RB upgrade. If they are RB, there will be an ID plate on the front of the compressor housing with a serial number and date of assembly. That's how they track there turbo's for warranty purposes.
2014 M5 6MT
12-31-2014, 07:48 AM | #12 |
129
Rep 917
Just take a log and post it. People can tell by the log if it has aftermarket turbo's.
2011 135i M Sport 6MT LeMans Blue | Active Autowerke Gen II axle back | Berk d******* | N54 gutted mids | FuelIt Walbro 450 fuel pump | Pure Turbos Stage 2 | 3.5bar TMAP | Pure Turbos inlet pipe | BMS intake | BMS oil catch can | ETS intercooler | ETS charge pipe | BMS JB4 w/ ISO firmware | BMS backend flash stacked on PPK | Eibach springs | Whiteline rear subframe bushing inserts | cosmetic tidbits
12-31-2014, 11:04 AM | #13 | |
62
Rep 581
How so? Remember, RBs turbos are not considered aftermarket. |
12-31-2014, 12:14 PM | #14 |
81
Rep 1,051
Uh, what?? By whom?
RB is not an OE supplier so it is "aftermarket." BMW doesn't sell the turbos in the condition and with the internal parts that RB does, so again they are "aftermarket." External appearance has nothing to do with it. You wouldn't call an LS3 swap in a 135i "not aftermarket" just because you slapped the N54's plastic engine cover on top of it.
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
12-31-2014, 12:31 PM | #15 | |
62
Rep 581
Don't RBs run same boost as oem turbos? |
12-31-2014, 01:29 PM | #16 |
81
Rep 1,051
The tune sets the target boost level, so it depends on if you tune or load a map that utilizes the capabilities of the new turbos.
They have a larger compressor, and some models have a larger or clipped turbine. That should make higher boost levels usable, though you may also get a nominal increase in power at the same boost level due to higher efficiency.
12-31-2014, 02:06 PM | #17 |
172
Rep 2,347
Durim post a log, also if you have RBs/VTT hybrids your car should pull hard all the way to redline 7k. The stock turbos die off quicky after 6K.
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
12-31-2014, 02:32 PM | #18 |
456
Rep 6,478
Just pull the downpipes and look at the turbine housing, Rob ports the crap out of it.
Or post a log and it'll be fairly obvious if your car is tuned for hyrbid twins.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
01-08-2015, 09:45 PM | #20 |
62
Rep 581
Just dropped off my car today for the Wastegate rattle to get new turbos.
Service manager is a friend of mine. He will be removing the turbos and comparing them to the new ones. Hopefully he can manage to get me a picture of them side by side. |
01-08-2015, 10:08 PM | #21 |
114
Rep 1,140
Drives: N54 135i 6MT
You may want to start praying that they are OEM, otherwise the dealer won't cover you and you will be hit with a few grand bill!
01-08-2015, 10:09 PM | #22 |
62
Rep 581
