12-31-2023, 11:22 PM | #1 |
11
Rep 34
Why it's difficult to find the Anti-dazzle (glare free) and variable light distributi
Hey, I am new to the forum but not new to the brand/platform/topics discussed here.
I have M5 First Edition. Prior to this, I had an M6C and M4C and I successfully coded the Anti-dazzle (glare free) and variable light distribution (VLD) coding using Bimmercode expert mode. I also coded the easy entry/exit on my M6 using Bimmercode. However, I spent a good 2 weeks researching the aforementioned topic on the M5 and no luck. Any idea how to code the VLD, AD and easy entry/exit on 2018 M5 using Bimmercode? |
01-07-2024, 03:33 AM | #2 |
582
Rep 2,047
The coding should be similar to the G30
VLD and GFHB Body domain controller 3530 LaMaster1 > LUT_FLC_FORWARDLIGHTING_Y > AFS > enable 3530 LaMaster1 > C_FLC_ENA > enable [was already enabled] 3531 LaMaster2 > c_AFS_ENA > enable 3532 LaMaster3 > c_HBA_ENA > enable [was already enabled] 3532 LaMaster3 > c_HBA_GFHB_ENA > enable For Easy entry you might also need to code the seat module, not sure if bimmercode supports this |
M5FirstEdition11.00 |
01-07-2024, 07:46 AM | #3 |
262
Rep 561
Drives: '23 M5 Comp
Is the headlight hardware the same as in the markets that allow this option to work? I had a 2016 M4 and enabled that option only to find out that the headlight hardware was different in the U.S. and it would not work right. It wouldn’t open the tunnel when driving behind another vehicle.
Thanks! |
01-07-2024, 10:56 AM | #4 | |
11
Rep 34
01-07-2024, 09:40 PM | #5 | |
1543
Rep 2,022
01-07-2024, 10:01 PM | #7 |
1543
Rep 2,022
01-07-2024, 10:45 PM | #8 |
11
Rep 34
Sorry again, on my M6 I coded them using Bimmercode to keep them on all the time. Didn't to physically turn them on. But this option doesn't exist in Bimmercode for f90. Same as easy entry and the VLD etc.
01-09-2024, 03:57 AM | #9 |
1543
Rep 2,022
Hmmm maybe pre lci is different, for lci it has memory so it stays on unless you use your high beams manually then you have to turn it back on. I'm sure somewhere there's a line of code that has to do with headlight memory or highbeam memory so try searching for something like that?
01-09-2024, 06:35 AM | #10 | |
11
Rep 34
01-09-2024, 10:58 AM | #11 |
1543
Rep 2,022
I'm concerned why yours is set to g042 lol... did you have someone code your car for you before? Or maybe previous owner? Anyway change that to g30 afs for starters
01-09-2024, 12:35 PM | #12 | |
582
Rep 2,047
Choose matching model + "AFS" option |
01-09-2024, 12:38 PM | #13 |
11
Rep 34
My car wasn't coded before and I have no clue why is that. I will go through the process again today and send share screenshots. Also my car is F90 (M5 2018)
01-09-2024, 07:25 PM | #16 |
11
Rep 34
So I tried to code this again and nothing matched the codes above. For instance, when I hit C_FLC_ENA there is no clue after that to choose from (aka enable/disable).
01-10-2024, 02:02 AM | #19 |
582
Rep 2,047
You can look at the value and see they match, its only the name that are different. The correct for LUT_FLC_FORWARDLIGHTING_Y will be Werte=00, 00, 00. The rest choose Werte=01
01-10-2024, 10:19 AM | #20 |
712
Rep 604
Hi Gents !
If any of that works for anyone please let us know! I am very interested in this especially if it will work for Pre-LCI car. I doubt that there is hardware missing. One thing that comes to mind is that some cars came with different light control modules that have additional cable in the plug mentioned under thread about LCI tail light conversion. I don’t know exactly remember but some cars have 4 wires and some have 5 therefore there could be some difference there. That would be the only thing that comes to mind. |
01-10-2024, 10:30 AM | #21 |
11
Rep 34
I don't see Werte=01 under LUT_FLC_FORWARDLIGHTING_Y as per the screenshots I shared above
01-10-2024, 12:17 PM | #22 |
582
Rep 2,047
3530 LaMaster1 > LUT_FLC_FORWARDLIGHTING_Y > 00, 00, 00
3530 LaMaster1 > C_FLC_ENA > 01 3531 LaMaster2 > c_AFS_ENA > 01 3532 LaMaster3 > c_HBA_ENA > 01 3532 LaMaster3 > c_HBA_GFHB_ENA > 01 |
