12-13-2012, 06:42 PM | #1 |
BimmerPost Supporting Vendor
8211
Rep 18,823
Drives: BMW
▀▄ eas | Factory-Direct Source for Öhlins Suspension Systems (R&T)
This is the latest step in the Ohlins Racing automotive philosophy – Road&Track by Ohlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over!
Ohlins has added a clever light-weight design with a majority of the parts in aluminum. On top of that, all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. The Features of DFV Technology So what is DFV? It is Dual Flow Valve technology – and it sets us apart from our competitors. Only Ohlins has DFV technology on its road and track products. With DFV, the dual flow valve gives the same characteristics on rebound as it does on compression, thanks to the damper fluid having a consistent path of flow in both directions. This means that the wheel and tyre can quickly and effectively resume their important position back on the ground, providing grip and traction. The new Öhlins R&T range uses DFV technology on every single fitment, making it the perfect upgrade for the enthusiast that needs comfort and agility in the one unit. Figure 1: (Compression flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the compression ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the compression ports in the DFV, increasing comfort. Figure 2: (Rebound flow) At low shaft speeds, oil flows mostly through the shaft jet bleed (lower dotted arrow). At higher shaft speeds, oil flows mostly through the rebound ports in the piston (upper dotted arrow). At very high shaft speeds, or during sudden shaft accelerations, oil can also escape through the rebound ports in the DFV, maintaining tyre contact with the road. Because DFV opens more quickly and easily on minor road imperfections, ride comfort is surprisingly supple and more akin to an OEM strut than a coilover set-up. Over undulating surfaces, the compliancy of the R&T units allows the car to crest bumps and pot-holes, whilst still keep stable and in control. Traction is always maintained at its optimum level. When comparing suspension, why settle for second best? Figure 3: (Vehicle – no DFV) Without DFV the oil can not flow through the piston quickly enough on the rebound stroke after hitting a bump, so the tyre is not able to stay in contact with the road. Figure 4: (Vehicle – DFV technique) The DFV valve opens, letting the oil flow quicker through the piston on the rebound stroke after hitting a bump, enabling the tyre to stay in contact with the road. When adjusting ride height on coilover units, it’s worth comparing how it’s done. On many inferior designs, height is adjusted by raising or lowering the lower spring platform. This has the effect of compressing or extending the spring, which can limit the suspension travel that may cause topping out. The Öhlins method is to leave the spring seat in its perfect position, whilst the lower flange spins easily on the threaded body, to allow you to adjust with absolute precision whilst maintaining the perfect characteristics that we took so long to design in! Once you’ve set it all up, the adjuster simply locks off to maintain your exact settings. Dampers will get hot. That’s one thing that you can be sure of. As the piston moves within the damper, it generates friction – and therefore, heat. Although we can’t stop heat, we can deal with it, and this is yet another way that Öhlins differs from the competition. As the heat increases, the viscosity of the damper fluid can change, altering the car’s handling characteristics. Our unique needle bleed valve expands with temperature, closing the gap that the fluid travels through, maintaining a consistent damping rate. The best thing of all? You won’t even notice! All you’ll feel is that the car responds consistently, lap after lap, turn after turn. Allowing you to concentrate on braking points and apexes whilst the Öhlins technology takes care of the damping. Figure 5: Thermal Expansion These kits all work well ‘out of the box’, but there’s still plenty of adjustment for you to set things your way. You like stiff and reactive? Or soft and forgiving? It’s all there. Too much low speed rebound damping can have an adverse effect on grip, so the easily accessible adjuster at the base of the Öhlins units allows small, but positive increments of fine tuning, so you can take into account every single parameter. Sounds complicated? Nothing could be further for the truth. Just a few clicks either way from our factory settings will soon have your car responding precisely to your inputs and driving style. The Road & Track McPherson struts also feature camber adjustable upper and lower mounts to give you the possibility to fine tune your wheels for the right occasion – whether you want to go for a ride in your neighborhood or take your car for a spin at the track on a weekend. Features - DFV (Dual Flow Valve) - Adjustable ride-height - Fully rebuildable - Corrosion salt spray tested (ISO 9227) - Includes hardware and installation instructions - 2 year Limited Warranty Front - McPherson Strut - Single bleed adjuster - Spring preload adjuster (approx. 15 mm lower than standard) - Coil Springs (343lbs/in) - Dustcovers - Uses original top mounts Rear - Conventional Shock Absorber - Single bleed adjuster - Separate spring preload adjuster (approx. 15 mm lower than standard) - Coil Springs (400lbs/in) - Dust covers - Uses original top mounts Applications Ohlins - Road & Track DFV Coilover System http://www.europeanautosource.com/pr...oilover-system 2000-2006 BMW E46 M3 Spring Rate: Front: 70 N/mm (400 lbs/in.) Rear: 110 N/mm (630 lbs/in.) 2006-2011 BMW E9X 3-Series Spring Rate: Front: 60 N/mm (343 lbs/in.) Rear: 70 N/mm (400 lbs/in.) 2008-2013 BMW E9X M3 Front: 60 N/mm (343 lbs/in.) Rear: 120 N/mm (686 lbs/in.) We are a factory-direct Ohlins dealer and have extensive experience in E46M3 and E9XM3 applications on both race and street applications. For those interested in the Ohlins systems, please feel free to contact us directly.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 11-19-2013 at 12:36 PM.. |
12-14-2012, 03:39 PM | #3 |
***Major MammelToe
159
Rep 1,139
Tom, I will be coming by next spring to get a set of these installed!
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
12-19-2012, 05:03 PM | #4 |
310
Rep 4,002
Pre-Orders are being taken for the next shipment
Robert T. | european auto source (eas)
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
01-02-2013, 06:51 PM | #6 |
2921
Rep 21,727
Get your Ohlins coil overs today!!
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
01-04-2013, 12:40 PM | #7 |
coupe la goon
373
Rep 1,640
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
How much of a nuisance is it switching to a coilover system on an EDC car?
01-04-2013, 01:29 PM | #8 |
2921
Rep 21,727
Not bad at all, you can have the EDC coded out or also the Macht Schnell EDC emulator works great as well
01-08-2013, 01:54 PM | #9 |
310
Rep 4,002
Get your Ohlins from eas!
01-15-2013, 06:38 PM | #10 |
2921
Rep 21,727
01-22-2013, 05:51 PM | #11 |
310
Rep 4,002
Order your Ohlins Suspension from eas today!
01-25-2013, 11:09 AM | #13 |
2921
Rep 21,727
01-28-2013, 02:09 PM | #14 |
57
Rep 600
Drives: 2012 E92 SSII ZCP DCT
can you PM me the price for this suspension kit paired with Vorshlag Camber Plates. Ship to 47906 thanks.
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER |
01-28-2013, 07:16 PM | #15 |
2921
Rep 21,727
PM coming your way!!
01-29-2013, 06:33 PM | #16 |
2921
Rep 21,727
Upgrade your suspension today with Ohlins coil overs!!
02-06-2013, 02:25 PM | #17 |
310
Rep 4,002
Order your Ohlins Suspension from eas!
02-12-2013, 07:09 PM | #18 |
2921
Rep 21,727
02-19-2013, 02:51 PM | #20 |
310
Rep 4,002
Another Ohlins R&T ordered from eas!
Get yours ordered today!
03-06-2013, 06:05 PM | #21 |
310
Rep 4,002
Order your set from eas today!
03-13-2013, 05:57 PM | #22 |
310
Rep 4,002
Another Order was placed for Ohlins Road & Track Suspension
PM on the way!
email: robert@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x21 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by robert @ eas; 03-13-2013 at 06:14 PM.. |
Tags |
coilovers, eas, ohlins, road & track, suspension |
