02-22-2024, 04:16 AM | #1 |
BimmerPost Supporting Vendor
53
Rep 230
Drives: All BMW models
Location: Unit 32 Sundon Industrial Estate Dencora Way Luton Bedfordshire LU3 3HP
EVOLVE | NEW STOCK JUST LANDED!! The Evolve Bilstein Dampers
We love the E9X M3 platform, having our Japan red E92 M3 development car often proves one of the most fun options in our garage to take home. But as the car ages, or when owners simply want to vastly improve the handling, items such as the dampers are one of the most important items to replace.
Click Here to View The Product We loved the existing Bilstein kit available for the E9X M3, but wanted to extend its range even further. So we worked with Bilstein to produce our own variation of its kit: Comfort > Softer than Bilstein settings Sport + > Stiffer than Bilstein settings We have developed these dampers in conjunction with Bilstein UK over a period of years. As good as the original Bilstein dampers were, we wanted to tailor them for our personal preference along with the ability to use with lowering springs and MSS Height Adjustable Springs. We worked with Bilstein to change the valving to make the Comfort setting even more compliant and the Sport + setting slightly stiffer giving more range of damping given by the electronic modes in the EDC equipped E90, E92 and E93 M3. These dampers can be used with stock or any lowering springs on the market that work with stock dampers, including MSS Adjustable Springs. They will not work with KW HAS/BMW M Performance HAS. We run these dampers with MSS springs on our own demo E92 M3 and the ride and handling characteristics are the best we've tested on this platform. • EDC Compatible • Softer setting in Comfort • Stiffer setting in Sport + • Perfect for lowering springs/MSS Height Adjustable Springs Click Here to View The Product Last edited by paulh@evolve; 03-15-2024 at 11:23 AM.. |
02-22-2024, 09:50 AM | #3 |
462
Rep 471
Drives: 2009 E93 M3 DCT
02-22-2024, 12:16 PM | #4 |
53
Rep 230
02-22-2024, 12:24 PM | #5 |
614
Rep 557
02-23-2024, 05:49 AM | #6 |
53
Rep 230
Not at the moment, but if you're looking for a specific feel/response we can guide you in the right direction, feel free to PM and we can discuss your needs and which setups would best for you
a5m614.00 |
02-26-2024, 07:28 PM | #7 |
75
Rep 80
Looks amazing, the boys at Evolve have done it again!
A few questions: Will there be a limited supply of these, what other hardware do I need to install (ie the top bits look different to oem and want to know if I need to order new caps/mounts), and will there be a video? Thanks!!!
2001 E39 M5 - Titanium Silver
2007 Z4 M Coupe - Sepang Bronze 2008 E92 M3 - Jerez Black |
Imran@Evolve5371.00 |
02-27-2024, 05:51 AM | #8 | |
53
Rep 230
Thanks
There's typically always a limited supply as they are proving to be very popular, even after ordering big batches they run out quickly. Hardware wise, the dampers reuse all the OE parts - the only difference is the wiring, hence why we supply the adapters for those in the package. And absolutely there is a video on route that should be completed by next week Quote:
03-02-2024, 10:59 AM | #10 |
53
Rep 230
03-02-2024, 11:05 AM | #11 | |
53
Rep 230
Tags |
bilstein, dampers, evolve automotive |
