07-25-2014, 02:17 PM | #23 | |
10210
Rep 8,644
The moment a flash comes for further fueling fine tuning, the S55 will go thru the roof.
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
07-26-2014, 11:02 AM | #24 |
74
Rep 1,123
Agreed, This is just the beginning for the platform. I feel that it will be easily a 650whp once its FBO + Meth.
2008 E92 BMW M3 MR/BB 6MT
|Gintani Supercharged|Gintani X-Pipe|Stack Gauges|Volk TE37SL|BC Racing Coilovers|Nitto NT05R |BMW Performance Spoiler|BMW Performance Steering Wheel|BMW Performance Side Gills + Grilles|Mode Carbon V1 Endurance|IND Tri- Stitched Shift + Brake Boot - 566WHP, 371WTQ | |
07-26-2014, 04:08 PM | #25 |
10210
Rep 8,644
the motors r very similar
Straight 6s twin turbod direct injected 3.0L displacement Thats a lot to compare. The rest; internals and so forth have no meaning until much higher power levels. The N54 has done 750 whp on an open block with a much less motor sport ready configuration than the s55. The 2 biggest differences in my mind are redline/powerband and turbos. The redline/powerband doesn't have nearly as much meaning as people think it will as these cars r both shifted much before redline for peak power. The turbos r the absolute biggest difference... but then what if an N54 w a set of rb's rolls by? Are they then that much diffefent in any aspect thats usable? Things to think about.
07-27-2014, 08:19 AM | #26 | |
173
Rep 894
Drives: 2011 Toyota 4Runner Trail
I have heard that the aftermarket can tune the N54 to get +100hp/+100lb-ft, and still maintain decent reliability, but anything beyond that and you really start to risk engine failure or some other breakdown (I know people have upgraded their turbos and rebuilt their engines and cooling systems to mitigate those risks as they take the N54 to higher HP/Tq levels). I was under the impression that the S55 was already running at a higher boost than the N54/N55 and that, in a sense, it was already tuned to a higher level of performance. The N54/N55 family of engines gets around 300hp/300lb-ft and the 335is/1m tuned N54 gets about 320-330hp/370lb-ft. The S55, using different internals, different cooling, and a different engine tune, but based on the same engine architecture, is getting 425hp/405lb-ft...how much more can a tune give that engine without significantly reducing reliability? |
07-27-2014, 08:31 AM | #27 |
74
Rep 1,123
The F8x screams N54 from the exhaust note to tuning capabilities. Terry at burger tuning already has a jb4 prototype for the f8x. yes, the engine is different from the N54/N55 but there's no denying it has all the traits from those motors.
07-27-2014, 08:55 AM | #28 | |
1114
Rep 3,261
2022 BSM/FR M4 Competition X-Drive 2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD] |
07-27-2014, 09:14 AM | #29 |
C
51
Rep 722
07-27-2014, 10:11 AM | #30 | ||
10210
Rep 8,644
07-27-2014, 05:09 PM | #31 | ||
173
Rep 894
07-28-2014, 06:49 AM | #33 | |
12
Rep 734
... a glorious V8 that screamed and hollered as the revs rose and then howled in an orgy of what sounded like BDSM ecstasy as it neared the red line.
Well, you can forget all that. The new car is fitted with a turbocharged straight six. Turbocharging? In an M car? That’s like putting gravy on an ice cream. - Jeremy Clarkson, discussing the S65 and then S55 M3 engines. |
07-28-2014, 11:20 AM | #34 |
10210
Rep 8,644
I do wish BMW did increase the displacement in the S55 a bit to a 3.2L a la S54. Then less people would be complaining about the similarities between the non M motors. I honestly don't care if the motor isn't much different in design than an N54/N55 as long as it's a good motor which it obviously is. Increasing displacement would have made it very special.
07-28-2014, 11:26 AM | #35 |
10210
Rep 8,644
Definitely not a tune... all bolt on's, different fuel (e85 / meth) and a protune would (which is all out for an N54... N55 lol, that wouldn't even come close). You can see a race between that setup and an S55. The S55 stock has much larger turbos and that is its most significant and telling difference... the power and reliability potential of the S55 is faaaar greater.
07-28-2014, 11:32 AM | #36 | |
12
Rep 734
How about up to 80hp to the wheels (100hp crank) on a completely stock car, up to 160hp to the wheels on factory turbos, or up to 350hp to the wheels on a fully modified car with larger turbo(s)? The JB4 includes a simple plug and play installation harness and is compatible with all ECU versions and transmission types. It's everything you need to take your N54 powered vehicle from mild to wild!
07-28-2014, 11:38 AM | #37 | |
10210
Rep 8,644
Well if you can find me an N54 that only has a tune and dyno's 425 WHP... I will sell you my ocean side land in Idaho for very very cheap. Yes, 80 to the wheels... so when the N54 dynos 270 WHP stock and you add 80 WHP, then you are at 350 WHP which is dead on with what a tune only N54 would give you. So you are still short another 80 whp from a stock S55. Come on dude, at least do your research... you are making some valid points but this was not one of them.
07-28-2014, 11:54 AM | #38 | |
12
Rep 734
07-28-2014, 12:35 PM | #39 |
2753
Rep 4,445
facts
"As the S55 engine is based off the N55 engine, 75% of the engine components were adopted from the N55 production engine and the other 25% of the engine components are new developments."
Source: BMW Technical materials
07-28-2014, 12:46 PM | #40 | |
1797
Rep 2,997
So for example: the heads, block, crankshaft, camshafts, pistons, valves, spark plugs, oil sump/pan, injectors, oil pumps, cooling systems, etc. are all unique. But they use the same CPS's, same valvetronic system (with unique controls by DME) and I'm sure many of the same bolts/fasteners. So by the % count, by using a totally unique crankshaft but the same Crank positioning sensor, then that's only 50% unique parts. But who cares if it uses the same crank position sensor - the important part is the crankshaft is cutting edge and made to a much higher level. But when looking at percentages, it makes it sound like it's mostly the same engine. It's not. |
07-28-2014, 12:47 PM | #41 |
10210
Rep 8,644
A lot of reading needs to be done there.
07-28-2014, 01:25 PM | #42 | |
173
Rep 894
The comparison between a tuned + FBO N54 HP/Tq curve and a S55's HP/Tq curve will depend on what kind of tune the N54 has, though ultimately I believe the 2 will look different. Put a upgraded turbo kit on the N54, and you can get something north of 450HP on 91 octane gas. As for a race between the two (n54 car and S55 car), that comes down to much more than the motor: brakes, suspension, chassis balance, tires, gearing, ect. From the lap times and performance specs, it's obvious the M4 is a much faster car, as I haven't seen a modded 335i or 1m pull those kinds of numbers/times. |
07-28-2014, 01:28 PM | #43 | |
10210
Rep 8,644
07-28-2014, 01:44 PM | #44 | |
131
Rep 690
i personally don't need a completely bespoke engine, i am not really one who is complaining about this. BMW should have never made a bespoke engine to begin with IMO. Now they cant make them anymore, and i want one (but dont need it ) |
