04-03-2019, 02:51 PM | #1 |
876
Rep 1,319
making your exhaust crack at will ?
Chaps,
Can you make your exhaust pop and crack at will, when driving, is there a sweet spot, like in the M4 ?. I could make that pop and bang when i desired. I cant seem to find that in the M5 yet. Im only at 750 miles, so maybe a little more time for the exhaust to settle and open up ?. Have a look at this video, to see what im getting at. Starting at around 2.40mins in. He also has another video where he says that BMW tweaked the exhaust, but just listen to it at around 4.20 mins. I cant believe that its standard, and BMW tweaked it for him?, by doing what ?. Last edited by Simon H; 04-03-2019 at 03:05 PM.. |
04-03-2019, 03:25 PM | #3 |
4425
Rep 4,109
As above works for me. However, if I'm passing say a Prius or a proud Tesla driver, it's required by law to pop+crackle as you do so. In my E63S, there's a guaranteed process--jab the gas hard and let right off--but I haven't found this works reliably in the M5 nor have I discovered its equivalent assuming there is one.
04-03-2019, 03:29 PM | #4 | |
112
Rep 127
04-03-2019, 03:32 PM | #5 | ||
4425
Rep 4,109
Simon H876.00 |
04-03-2019, 03:41 PM | #6 |
1716
Rep 1,913
Drives: 2023 M5C
Make sure you're in Sport+ with the engine, and the exhaust valve button next to the shifter is ON. You shouldn't have any problem making it pop around 2-3k RPM when you let off the throttle. It's not exclusive to the M5C.
Simon H876.00 |
04-03-2019, 04:27 PM | #7 |
4425
Rep 4,109
It doesn't work reliably but I don't think I've tried to ensure I'm within a given RPM range, I can try that when I'm back.
04-04-2019, 12:44 AM | #9 |
376
Rep 600
Try having the transmission in the max setting while having the engine in sport+.
This is where it makes the loudest sounds when lifting off the gas pedal.
2019 - M5 Competition
04-04-2019, 12:47 PM | #10 |
153
Rep 427
Drives: 2019 M5 Competition
I can do it 100% reliably in 1st, 2nd, and 3rd (a little in 4th), by dropping off the pedal or downshifting and having the RPMs drop through the ~4.5k->2k range. I run in Sport+, S3, etc... I know its juvenile but man I love it
Simon H876.00 |
04-04-2019, 01:33 PM | #11 | |
876
Rep 1,319
On a side note, i have to say on the couple of occasions it did let go, it sounded epic, and had me questioning whether a change of exhaust is really needed ?. |
04-04-2019, 01:38 PM | #12 | |
519
Rep 1,367
First M: New '99 M3 Titanium / Black
Most recently returned: New '18 M5 SG / Black Current: '21 X5 M50i Black / Black |
Simon H876.00 |
04-04-2019, 01:53 PM | #13 | |
876
Rep 1,319
Sounds right up my street, fantastic |
Fegelein519.00 |
04-04-2019, 02:15 PM | #14 |
176
Rep 113
I'm around 8k...if I want loud snap crackle and pops I make sure to downshift with my paddles from 4th gear down and it sounds crazy. If I just accelerate to 4-5k rpms and let off quickly I also produce loud sounds (it used to do it at around 2500 but not as consistent as it was before).
04-04-2019, 06:39 PM | #15 |
///M
6658
Rep 3,683
From mine experience it won't do it consistently.
No matter what you do. There is times where it pops like shotgun and there is time it won't do it even dough you try it the same way a minute later. Having DME tune with extra burble was extremely fun to drive, specially with both cats removed
Life is too short...enjoy your life
///M |
04-04-2019, 09:22 PM | #16 | |
4425
Rep 4,109
Miko M6657.50 |
04-05-2019, 01:28 AM | #17 | |
876
Rep 1,319
04-05-2019, 05:08 AM | #18 | ||
///M
6658
Rep 3,683
But the MT gear ratio was different and going down hill and downshift was a killer
///M |
04-06-2019, 10:07 AM | #20 |
500
Rep 1,313
All I have to do is put my engine in sport + mode...just driving through my neighborhood (25 MPH speed limit) and letting off the gas as I meander onto and turn on other streets...that gets more than enough pops. I get a boatload of head turns from the joggers, mom's at the school bus stops, etc. It is hysterical!
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
Simon H876.00 |
05-21-2019, 09:13 AM | #21 |
2274
Rep 3,300
I find that I can very reliably get very loud popping/backfire but putting it in sequential/manual shift mod, bring car up to speed to an engine RPM of about 4k, and just let off the gas to slow down (without shifting), and bang! Plenty of childish man-fun noise. LMAO!
Mike
05-21-2019, 09:54 AM | #22 |
521
Rep 1,439
With these keller pipes, it even pops in 5th. So awesome.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
