11-29-2021, 11:38 PM | #1 |
258
Rep 235
Drives: 2022 M5C /// 2023 XDrive40i
Car “Lurching” Upon Braking/Downshifts
My 2022 M5C is only three weeks old, and during the first week I never noticed this happening before, but since then there is this shudder/lurching forward when almost at a complete stop or when the gears are downshifting as you’re coming to a complete stop.
I observed as best I could if it may be a hard downshift of some sort (regardless of what M mode the car is in), by ensuring the gear number was visible in the cluster and seeing if this phenomenon occurs precisely at the time when a downshift occurs. It actually does not, and the whole thing could best be described as though the car has a vacuum leak somewhere causing it to lurch forward (it doesn’t, but just “feels” that way). Is this notchiness normal in these cars, and if not, then any ideas? Thanks! |
11-29-2021, 11:59 PM | #2 |
225
Rep 426
That’s just how the ZF8 is, the shifts from 1-2 are in general much much more lurchy than all of the other gear shifts, it’s normal to have that. I’ve been in other cars with this tranny that feel similar. It also skips gears (at least in the display) when downshifting in auto al the way to stop so that could make it more lurchy than manually downshifting yourself. I’ve noticed the upshifts from 1-2 are also pretty lurchy, especially when you aren’t WOT at a high RPM when you’re shifting.
Another thing to note is that the instrument cluster updates gears visually before the gearshift is actually completed, so you may be between shifts from 2-1 for example and it will say 1 on the dash. |
11-30-2021, 07:14 AM | #3 | |
Live for today tomorrow never comes
1990
Rep 9,499
None of my F90 ever did that.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
11-30-2021, 07:30 AM | #5 |
1990
Rep 9,499
Can not see why, maybe a different software for other countries .
11-30-2021, 09:01 AM | #6 |
1649
Rep 891
My 21 M5C does the same thing. Quite surprised on the lurches while coming to a stop because I came from an M3 with DCT and that downshifted smoother.
Still don't see any advantage to going to a true autobox in the M5 other than a cost saving to BMW.
2021 MBB M5C (retired) 2018 Daytona Violet M3 ZCP (retired), 2016 AW 550i (retired) 2013 EBII 335i (retired), 2008 Platinum Bronze 535xi (retired), 2007 Monaco Blue 335i (retired) 1999 Hellrot M3 coupe (retired) |
