Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      09-01-2023, 07:04 AM   #1
tgb1974
Drives: 2016 F83 M4 (DCT)
Reduced AC air flow (SIB 64 06 13)?
Recently, during a long-ish road trip, I had the AC going but the blower eventually stopped working. A tiny amount of cold air trickled out of the vents. Several hours later, the AC worked fine again.
I believe that I may need the fix described in SIB 64 06 13 (https://www.tsbsearch.com/BMW/SI-B64-06-13). Wondering if any of you has had this done, and if so, whether it made any difference. Thanks.
2016 BMW F83 ///M4 Tanzanite Blue Metallic/Silverstone Full Merino // NBTevo ID 6 retrofit // G3x/F90 10.25" MGU display retrofit // GTS flash // SmartTOP // 437M + Pilot Alpin PA4 (winter) // 359M + ContiSportContact 5P (summer)
Retired: 2013 E93 M3 | 2015 F22 M235i xDrive | 2012 E70 X5 xDrive 35d | 2010 E90 328i xDrive
      09-01-2023, 11:54 AM   #2
tgb1974
I should have also asked whether you had the physical correction made, the coding change or both. It may depend on the car's manufacture date.
      03-20-2024, 10:23 AM   #3
tgb1974
Update on this. kubax86 just implemented the coding solution in the TSB for post-October 1, 2013 vehicles. Took 5 minutes. I highly recommend kubax86 to make this fix rather than going to the dealer.
Appreciate 2
kubax861800.50
      03-20-2024, 12:56 PM   #4
brody8877
I like cars
Drives: F80 M3
2018 BMW M3  [0.00]
1993 Mazda RX-7  [0.00]
2015 328i  [0.00]
I have the same problem on my 328i. This post helps immensely and going to remedy the issue.
___________________
15 - 328i w/Msport
93 - RX7 Touring
18 - M3 ZCP
      03-20-2024, 04:57 PM   #5
tgb1974
Happy to have helped! Suggest you PM kubax86 to get the coding work done. Cheers.
      03-20-2024, 05:22 PM   #6
brody8877
I like cars
Drives: F80 M3
2018 BMW M3  [0.00]
2015 328i  [0.00]
I already have a great experience with kubax86 and will definitely get more coding stuff done lol.
___________________
15 - 328i w/Msport
93 - RX7 Touring
18 - M3 ZCP
      03-20-2024, 05:40 PM   #7
tgb1974
kubax86 is the man
f80post
