proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      08-05-2014, 12:40 AM   #67
Hobbination
Hobbination's Avatar
Drives: 2015 M4
Had my 1200 oil change done yesterday, they used 10w60 here in the motherland, and for the super low price of 26 Euros a quart...Practically giving away free $400 US oil changes
      08-12-2014, 11:15 AM   #68
M4Passion
Germany
20
Drives: pre-order M4
Today i got Information directly from the M Departement that you should use the following oil:
Castrol 0w30 LL01 FE
BMW part number: 83 12 2219 738
It is all very confusing...
      08-12-2014, 04:31 PM   #69
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
I am looking into this... Dack's on the case!
      08-13-2014, 01:44 AM   #70
M4Passion
Germany
20
Ok, thanks
      08-13-2014, 10:31 AM   #71
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
Ok, I doubled check my info on the proper engine oil to use. Everything still is correct(and up to date in the ETK and dealer service infor for Europe.
BMW Quality Longlife-01 SAE 0W-40 (vollsynthetisch)ACEA: A3/B3, EC II
p/n 83 21 0 144 456
BMW Quality Longlife-01 SAE 5W-30 (vollsynthetisch)ACEA: A3/B3, EC II
MINI Quality
p/n 83 21 0 144 450
So @M4Passion you might want to have your guys at ///M show it to you in b&w or in an email.
      08-13-2014, 07:02 PM   #72
miula
Drives: a disturbed shark!!!
p/n 83 21 0 144 456
MINI Quality
p/n 83 21 0 144 450
Any idea if the part numbers differ for the US? The dealer is telling me that the 1 series 5w-30 is the correct oil to use (part 07510017866)...
There is a few different part number for the diff fluid in the U.S. as well; I know its the SAF-XJ 75W-140 of the e9x but is it the plain version or the 500ml bottle with the FM booster/modifier?
FYI part number 83229405462 shows as MSP/A or SAF-XO not SAF-XJ
      08-19-2014, 08:11 AM   #73
getmetnow
42
Drives: G05
I was told yesterday when I gave my SA the part list from this post that 2 of them are European part numbers and they couldn't get them. Is that accurate?
Below are the part numbers.
Screw for engine oil pan/plug: 11 11 7 849 396
Screw for differential: 33 11 7 525 064
      08-19-2014, 03:36 PM   #74
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
IDK... the engine oil plug shows as a USA part. The diff plug shows up as being used on USA and for EU cars.
So what was the problem? Did they not do your service or use new parts(drain plugs) ???
http://www.realoem.com/bmw/showparts...=11&fg=10&hl=7
Screw for differential: 33 11 7 525 064 (you need two!)
http://www.realoem.com/bmw/showparts...33&fg=10&hl=11
http://www.realoem.com/bmw/partxref....=on&series=F80
Dackel
      08-19-2014, 04:22 PM   #75
getmetnow
42
Drives: G05
Dackel
I gave them the sheet with all the details from your post. They came back to me and said that they couldn't get those 2 parts because they were EU part numbers. I will go see them tomorrow to see why they are having an issue.
      08-19-2014, 05:14 PM   #76
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
Just have them look up the parts in their ETK for your car. They should have no problems ordering nw drain plugs for the engine and (2)for the diff.
      08-19-2014, 09:07 PM   #77
miula
Hey Dack, can you shed some light on the situation with the diff. fluid (I would really hate to have the wrong one listed on the sticky)
The part number you listed 83229405462 shows as MSP/A or SAF-XO not SAF-XJ and it says it has been discontinued in the U.S.
The SAF-XJ with FM booster shows up as 83222282583 (same as E9X) at least for the U.S., there is also 83221470080 which shows as SAF-XJ without the FM booster.
Any ideas???
      08-20-2014, 02:53 AM   #78
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
Any ideas???
SAF-XJ can be used where XO is spec'd.
XJ is for all M car diffs.
SAF-XJ one 500ml bottle is: 83 22 2 282 583
Name:  Castrol SAF-XJ diff oil  IMG_0381.jpg
Name:  Castrol SAF-XJ diff oil IMG_0378-1 (1).jpg
The problem with gear oils is that most BMW dealers buy the oil in 60L or 600L or 6,000L quantities. Then the dealer assigns the oil their "own" part number. This varies from dealer to dealer. Best thing to do is order the gear oil in 1 liter bottles from bmw.
      08-20-2014, 03:05 PM   #79
getmetnow
42
Drives: G05
Attached is what they did to the car today. Looks like they didn't install a new diff screw. Should I go back and explain to them that I need that part installed?
      08-20-2014, 05:43 PM   #80
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
I think your car will be ok. Afterall you still have the warranty if anything goes wrong. My bet, is a lot of dealers are not changing out these plugs for new ones.
      08-21-2014, 09:31 AM   #81
jbraslins
Latvian Gangstah
jbraslins's Avatar
84
Drives: 2009 E92 M3 Melbourne Red 6MT
My invoice was the same. I called them and asked them about it. They said plugs are part of the kit and not broken-out separately. Hmmmm.
Does anyone have a copy of invoice that shows the diff screws/plugs?
[SOLD] 2015 YMB BMW M3 M-DCT
[SOLD] 2010 Alpine White E90 M3 M-DCT
[SOLD] 2002 TiAg E46 M3 manual
      08-21-2014, 02:47 PM   #82
getmetnow
42
Drives: G05
I sent a detailed email stating my case to my dealership about replacing the 2 diff plugs. I got a call about 15 min later stating that they indeed were not aware that they need to replace those screws. I am going back tomorrow at 8 am to have that done. A little pushing on them got me what I needed. I don't understand how/why they miss it. All I care about is that they are getting it done.
When I get it done, I'll upload a picture with the part number/info so you can have it as well.
      08-21-2014, 07:19 PM   #83
humpday
33
Drives: M4
I just dropped my car off for its 1200 mile maintenance, and they said that they're only changing the diff fluid. They said that the engine oil doens't need to be changed until 9000+ miles or 1 yr (which ever comes first). This doesn't seem to be what others are experiencing.
      08-21-2014, 07:35 PM   #84
Sir Loin
M3AT LOVER
Sir Loin's Avatar
Drives: Silverstone F80 M3
Don't believe it. Show the picture above to the service people so they know how ignorant they are. This is an M car, not a regular 3 Series or 4 Series.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
      08-21-2014, 09:24 PM   #85
humpday
33
Drives: M4
Thanks Sir Loin. Does the manual say that both need to be changed? My manual's in the car so I can't check, and the online version doesn't specify.
      08-21-2014, 09:46 PM   #86
Sir Loin
M3AT LOVER
Sir Loin's Avatar
I just checked the manual in the car. It doesn't say specifically what service needs to be performed at 1,200 miles. The dealer's computer must already have the exact procedure documented. They just didn't check. The picture above is a pretty good prove.
      08-22-2014, 12:17 AM   #87
Dackelone
European Editor
Dackelone's Avatar
Germany
10628
Drives: N54 e82
+1.
      08-22-2014, 07:16 AM   #88
humpday
33
Drives: M4
+1.
That's helpful. Where did you get that?
f80post
