03-30-2022, 09:20 PM | #1 |
236
Rep 481
FS: Match PP 7S-D Compact Subwoofer
Hi,
Selling like new Match Trunk Subwoofer. Local pickup only. Price: $320 Match PP 7S-D Compact Subwoofer enclosure for Match plug and play amplifiers The right bass for every application - the brand new subwoofers are the perfect complement to the MATCH Plug & Play amplifiers. Select your desired combination according to available space in the trunk and your own requirements for maximum sound pressure. These subs are the perfect example of how an intelligent combination of amplifier and loudspeaker, thanks to sophisticated DSP technology, can provide a rich, perceptible bass pressure in the vehicle even in extremely compact dimensions. The secret lies in the meticulous coordination of the components - only in a team with the MATCH Plug & Play amplifiers, these subwoofers can accumulate to the maximum sound performance. Features: Extremely compact housing - ideal for use in spare wheel wells Optimized for MATCH Plug & Play amplifiers Two 16.5 cm long-throw woofers with hand-made paper cone and double voice coil Double ventilation of the voice coils for minimal compression effects Heavy-duty voice coils with large winding widths Easiest possible connection via pre-assembled subwoofer cable Solid metal mesh for optimum protection of the woofers Power RMS / Max. 200/400 watts impedance 4 x 2 Ω Max. Linear diaphragm stroke +/- 5.0 mm Efficiency 1 W / 1 m 90 dB Dimensions (H x W x D) 500 x 120 mm 1 x Subwoofer MATCH PP 7S-D 1 x Plug & Play subwoofer connection cable MATCH PP-SC 4 |
