10-22-2021, 10:43 PM | #24 |
3354
Rep 1,823
My rating in order:
Brunnchen Aremberg (if you loose it in Schwedenkreutz you crash at Aremberg) Adenauer Forest Pflanzgarten II Hatzenbach Nordkurve (now Sabine Schmitz corner) Tiergarten
2017 BMW M2 German Spec
6MT, Driver's Package --> SOLD 2018 Camaro SS 1LE. Because race car! "Redline a day keeps the mechanics away" |
harry.h65.50 |
10-25-2021, 09:42 AM | #25 | |
60014
Rep 19,524
10-25-2021, 09:48 AM | #26 |
60014
Rep 19,524
A lot of the crashes there would be avoided if in the dry slicks would be fitted instead of normal tyres which cannot live with the forces put out at the 'Ring.
10-25-2021, 10:08 AM | #27 |
3570
Rep 10,351
There's a turn that new drivers miss. It's a RH uphill turn which starts with a long downhill str8 coming off a LH turn.. The run off is gravel.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
10-25-2021, 10:40 AM | #28 |
3058
Rep 3,909
10-25-2021, 12:21 PM | #30 | |
1803
Rep 1,011
200TW tires make more noise as you approach the grip limit and are more forgiving to catch an oversteer/understeer situation than slicks that are more on/off. The crashes would be avoided by people who don't know what they are doing driving well past their abilities. Some of these people don't even have proper position on the steering wheel with their hands, or distance to the steering wheel, etc. Most of the people you see smashing up their cars likely don't even understand what the traction circle is or slip angles are in regards to grip level. |
10-25-2021, 12:51 PM | #31 | |
60014
Rep 19,524
A lot of those bods that went off the track appeared to have traction switched off, big mistake. |
10-25-2021, 01:18 PM | #32 | |||
3354
Rep 1,823
If you can handle over/understeer on street tires, you'll go quicker on slicks. Otherwise the crash just happens at higher speed.
OkieSnuffBox1802.50 |
10-26-2021, 03:27 AM | #33 |
2JZ-GTE
3035
Rep 3,992
S2k for the win
10-30-2021, 04:12 PM | #34 |
17303
Rep 18,729
LOL. The cars in the first video seem to crash at not very high speeds. The E30's seem impervious to track conditions.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
10-30-2021, 05:25 PM | #35 |
2990
Rep 1,796
Looks like a mix of poor tires and poor throttle control with a healthy smattering of overconfidence.
When your tires are screetching like that and the car is going the wrong way, yeah you done gone and screwed up. |
M5Rick60013.50 |
11-18-2021, 03:43 AM | #38 |
60014
Rep 19,524
You're correct and that goes on the street too, if someone pulls out on you and you can't brake in time then hit them rather than steering away to get hit from the side and going into others and yes the white M3 had no or little damage hitting armco head on.
11-18-2021, 08:37 AM | #39 | |
809
Rep 1,597
