01-19-2024, 09:13 AM | #133 | |
729
Rep 581
VGSON220.50 |
01-19-2024, 12:30 PM | #134 | |
2317
Rep 4,174
Congratulations!!! I've been there, and it gets easier - but not too easy, when the baby is born. Every once in a while I do the "I'm going for a drive" and my wife is waiting for me when I come back, praying I didn't die on my drive. I'd also recommend going really early, or late - Highway pulls in 3rd gear. I don't really think you need to do 4th gear, but what do I know.
Mods: Yes.
01-19-2024, 04:23 PM | #135 | |
221
Rep 315
01-20-2024, 02:03 PM | #136 |
409
Rep 587
Drives: 2018 M2
Looking for a little help...
I have a wire/connector that I don't know/remember where it goes. It's not the: CBV/BOV, EWG, or Thermostat (only one goes to this right?). What other two-wire loom comes off the front of the engine that is the top line of this set of wires? It's #2 that I am looking to understand where it goes. I could start taking things apart again, but am hoping someone can help. Thanks! |
01-20-2024, 11:36 PM | #137 |
124
Rep 261
I believe it’s the wastegate or the DV wire, but I can confirm tonight or tomorrow
Speedtech top mount G35|Motive| Reflex plus | Wagner EVO 3 | BMP manifold | Dorch Stage 2 HPFP | PI | Precision Racework stage 4V2 LPFP | BendCalibration Flex Fuel Kit |turner catch can| HRE 20” \Apex 18” wheels| ECUTEK tuned by bendCalibration|ohlins suspension
IG Modded_M2 |
01-21-2024, 11:59 AM | #138 | |
124
Rep 261
IG Modded_M2 |
01-22-2024, 01:38 AM | #139 | |
607
Rep 882
Drives: OG M2
OG M2 with the OEM M mirror retrofit
M2guru409.00 |
01-26-2024, 11:52 PM | #141 |
607
Rep 882
Drives: OG M2
Question for you: How did you reconnect the oil line that plugs into the engine block right next to the diverter valve? I'm having a lot of trouble getting it in even with extensions/swivels... Thinking I might have to remove the diverter first, get the line secured, and then reinstall the diverter...
01-27-2024, 04:40 AM | #142 | |
409
Rep 587
Drives: 2018 M2
I also think I didn't have the manifold completely tightened when I connected that line. In hindsight, I am not sure how I could have put it on/in afterwards because that line is literally so close that the silicone intake pipe that slides on the cold side cannot slide on (not sure if you've seen my other post about that). That oil line had to be bent and there doesn't seem to be much length for bending. As my car sits now, I have the intake pipe on only a few mm further than the width of the worm-gear clamp for the intake pipe. This means that there is extra length on opposite end towards the filter. I have the stock intake and there isn't room for the extra length. So I ended up cutting the silicone intake pipe on the filter end AND cutting some length off the plastic tube of the between the silicone intake and the filter. This is the only part of the installation that I am somewhat not comfortable with, but since it's only going to see vacuum and I don't think it'll compress from that vacuum, I am not too worried about it. If I could do it all over again, I'd bend both ends of the oil feed line to make way for the silicone pipe without stressing the line in any direction before I put anything more back together around the hot and cold side of the turbofold. Happy to help or take pictures if you have more questions! |
samsamdar606.50 |
01-27-2024, 03:52 PM | #143 | |
607
Rep 882
Drives: OG M2
01-28-2024, 12:17 AM | #144 | |
607
Rep 882
Drives: OG M2
01-28-2024, 04:35 AM | #145 | |
409
Rep 587
Drives: 2018 M2
How close is your line to the turbo intake where the silicone pipe would slide on? |
01-28-2024, 04:44 AM | #146 | |
607
Rep 882
Drives: OG M2
No issues that I can see with the inlet hitting the line - to be fair, I’m doing a PS2 which is all OEM housing. It’s tight but it works similar to OEM
M2guru409.00 |
01-30-2024, 06:42 PM | #147 |
607
Rep 882
Drives: OG M2
M2guru so I got a new OEM oil inlet line and it completely fixed all the issues I was having lol - time to reassemble
01-30-2024, 06:47 PM | #148 | |
409
Rep 587
Drives: 2018 M2
I am about to start my engine (probably tomorrow). Just bled the coolant 3-4 times and primed the oil 4-6 times (without spark plugs). New plug just installed. Keep us updated! |
samsamdar606.50 |
01-30-2024, 06:49 PM | #149 |
607
Rep 882
Drives: OG M2
You as well! Good luck!
01-31-2024, 05:11 PM | #151 |
221
Rep 315
curious, i have the ftp turbo to intercooler pipe. It came with worm gear clamps which fail & the inlet isn’t exactly perfect match…Besides going to tbolts. is there another yall found to be better? Mine creeped off/loose after a bit.
02-05-2024, 04:09 PM | #153 |
409
Rep 587
Drives: 2018 M2
Just drove the car after installation. Lots of smoke from the turbofold. Likely burning off a variety of coatings and fingerprints. Took longer than expected for the smole to go away but it did. Bob at StageFP has my first log and is helping me along. More to come!
02-05-2024, 04:34 PM | #154 |
455
Rep 1,389
I left turbo to intercooler pipe stock as even aftermarket ones didn't really look any better?
I noticed a difference in smooth pipes just in stock tune though. By this I mean CP and turbo inlet with bigger fmic. |
