02-15-2023, 01:43 PM | #1 |
11
Rep 130
hard staining on polished LMs
I've noticed these stain spots on some of my LMs on the polished lips. I've tried sonax full effect wheel cleaner and mother's polish but it doesn't clean off. What can I do to clean these off?
02-15-2023, 01:59 PM | #2 |
F15 daddymobile
2352
Rep 3,512
Are the lips bare metal or is there a clear coat? if its bare metal, then a simple mag polish will bring them back to life. if thats not working, then they are etched and a light sanding may be required.
if they are clear coated, then the coating itself is likely ruined and will need to be removed/reapplied or just removed and polished out.
02-15-2023, 02:24 PM | #3 |
11
Rep 130
There's no clear coat just straight polished. Mother's polish isn't doing the job. This is after using mother's polish. That milky mark is still there.
02-15-2023, 02:28 PM | #5 |
F15 daddymobile
2352
Rep 3,512
you might need to try a light sanding then...
02-20-2023, 08:36 PM | #8 |
1055
Rep 3,213
Looks like metal corrosion. Did you use some cheap wheel cleaner? Like the spray ones? Do you frequently use auto car washes?
e92 ///M3 |
02-21-2023, 09:41 AM | #10 |
3956
Rep 3,993
Polished lips will do that if you let water sit on it for too long.
Once you polish them out, I recommend you ceramic coat the wheels, that will help prevent that, but they'll still require frequent up keep. I got tired of always cleaning and polishing them, so I got clear coated lips.
04-15-2023, 01:44 PM | #13 |
1889
Rep 5,506
Do not use wheel cleaners and avoid hard water. SoCal is well known for hard water. Get a water softener if you use it to wash your car.
If it is already etched, you will need to get it taken apart, polished and put back together. Probably clear coat the wheels while you're at it.
Auto Detailing Enthusiast!
