      11-03-2010, 12:28 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Smile M3 Strut Tower Brace Kit for your 128i 135i
HP Autosport, Inc. did all the R&D work and brought the E90post and 1Addicts community the M3 suspension conversion kits back in 2008. With increasing requests, HP Autosport is introducing the M3 strut tower brace kit for your 128i and 135i.
Gone are the days removing the oem brace to get to your rebound adjustment knobs on your struts or change your camber settings for HPDE or track days. With this M3 strut tower brace kit you will be able to access those adjustments with ease.
The "Mount", the piece that bolts to the firewall has been modified to accomodate the different firewall angles found on the 128i and 135i.
The last three photos are the M3 strut tower brace installed in a pre-2011 135i with the N54 power plant.
Independent review by "Alpina B3 Lux"
http://www.e90post.com/forums/showthread.php?t=590096
***The heater closing panel may have to be removed or slightly modified to install the M3 strut tower brace on 2011 vehicles. It's number 13 in the parts illustration drawing***
Includes all parts needed for installation.
$775
Order here:
https://hpautosport.com/product/bmw-...wer-brace-kit/
If you prefer to buy your parts else where and wanted the modified center support mount only, you can order that here:
https://hpautosport.com/product/bmw-...er-mount-only/
An inexpensive set of E Torx Sockets that will help you with this installation:
https://www.amazon.com/gp/product/B0...f738e46857b05e
      11-04-2010, 11:09 PM   #2
wu2x
wu2x's Avatar
36
Drives: 2011 E90 M3 6MT
Harold can you explain what might need to be done to part 13 to get this to fit?
      11-04-2010, 11:52 PM   #3
HP Autosport
Drives: F80 M3
Two ways:
#1 remove(carefully cut around the base of it, a 1 minute job at the most) the two rubber moisture/dust sleeves so you can actually feed the firewall portion of the brace through the closing panel, then you can re-install the sleeve to still retain most of the moisture/dust barrier capabilities.
#2 buy a new closing panel with snap on sleeves as you see it in the illustration - #23 and #24. OEM ones are fused to the closing panel thus the need to cut them off.
      12-07-2010, 10:33 PM   #4
HP Autosport
Drives: F80 M3
These are good in stock and will be there for the holidays!
      02-10-2011, 01:09 AM   #5
HP Autosport
Drives: F80 M3
This kit will end the frustration of not be able to get to your rebound adjustment on your Koni, KW, GC and many other coilover kit with rebound adjustment via the top of the front struts.
In addition, this kit it will take away the need to shim your oem 135i brace to clear the Koni adjustment knob and give you much easier access to all three top nuts for your camber plates when going from street to track or vise versa.
      02-23-2011, 03:22 PM   #6
HP Autosport
Drives: F80 M3
M3 brace installed on 135i with N54.
      03-29-2011, 01:34 AM   #7
HP Autosport
Drives: F80 M3
Having a tough time getting to your strut's damping adjustments under the oem brace? This brace kit will solve that problem!
      06-07-2011, 02:27 AM   #8
HP Autosport
Drives: F80 M3
If you have AST, KW or Koni with adjustable rebound damping on the top of the front struts, these will make those adjustments much easier.
      07-29-2011, 01:35 AM   #9
HP Autosport
Drives: F80 M3
In stock and ready to ship!
      08-23-2011, 08:17 PM   #10
HP Autosport
Drives: F80 M3
Get a piece of M performance that also makes adjusting rebound on any suspension much easier.
      09-28-2011, 07:57 AM   #11
Richard135i
Australia
14
Drives: .
PM me price and shipping to Australia 3142
for N54
      10-05-2011, 12:42 PM   #12
HP Autosport
Drives: F80 M3
for N54
PM Sent!
      10-15-2011, 11:47 PM   #13
HP Autosport
Drives: F80 M3
Strut Tower Brace
Stiffen your front end for better road feedback and faster steering response!
      11-06-2011, 01:58 PM   #14
humanferret
Drives: 2011 BMW 135i
Does this work for the n55 135i?
      11-06-2011, 09:10 PM   #15
HP Autosport
Drives: F80 M3
Yes, it does.
Have a look at the first few photos, that was installed on the N55 135i.
      11-24-2011, 11:50 AM   #16
Pablito1702
Pablo
Drives: 2009 135i
Got my M3 strut brace from HP super fast. Thanks Harold!
      11-24-2011, 12:40 PM   #17
MilehighM3
MilehighM3's Avatar
Drives: Harrop E90 M3
2009 E90 M3  [6.50]
Black Friday sales? ;-)
      12-03-2011, 01:47 AM   #18
HP Autosport
Drives: F80 M3
Everyday low price!
      03-07-2012, 10:29 PM   #19
HP Autosport
Drives: F80 M3
BMW 120i 128i 135i strut tower brace
Strut tower brace for your one!
      04-09-2012, 07:06 PM   #20
HP Autosport
Drives: F80 M3
1 series M3 style strut tower brace kit is good in stock!
      07-24-2012, 09:46 PM   #21
HP Autosport
Drives: F80 M3
Strut tower brace
Stiffens from your end and gain access to your strut if you have damping adjustments.
      07-27-2012, 02:43 PM   #22
int2str
int2str's Avatar
Germany
80
Drives: 2008 135i
Thumbs up
Ordered mine @ HPA just now for precisely that reason!
