BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Replacing front facing camera
      08-18-2023, 07:18 AM   #1
CrashCade
112
Drives: '19 M5 Comp,
I am planning on pulling my front bumper and taking care of a couple upgrades/repairs. I have a lowered replacement grille, camera, drl module, and a couple other items to address.
When replacing the camera do I need to do anything to ensure the new one works/functions correctly? Does it need to be coded? What I don’t want to do is pull it all apart and swap it out just to find out that there is something to code that I don’t know how to do.
Any help or insight would be greatly appreciated.
      08-18-2023, 08:43 AM   #2
NoMods
NoMods's Avatar
1108
Drives: 2022 M5
2022 M5  [10.00]
Like everything else it seems, does it need to be recoded?
      08-18-2023, 09:55 AM   #3
Aronis
Aronis's Avatar
2273
Drives: 2018 M5
no mention of coding anything in this pdf
Mike
File Type: pdf 6653120 Remove and install front camera.pdf (621.3 KB, 83 views)
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
PetroM543.00
      08-18-2023, 10:16 AM   #4
CrashCade
112
Mike
Thank you for posting this. Replacing the camera is pretty straight forward and simple. Just wanted to make sure I wasn’t going to regret doing it by failing to code something.
      08-18-2023, 10:19 AM   #5
Aronis
Aronis's Avatar
2273
Drives: 2018 M5
Taking bumper cover off was easy too....
Mike
      08-19-2023, 12:24 PM   #6
CrashCade
112
Mike
Well, I can factually report today that the replacement camera would not display when it was swapped in. I received a camera malfunction error. As soon as unplugged the OE camera back in, everything works as it should, minus the 40 rock chips in the camera lens.
Does anybody else have any insight or input? I am reaching out to see if I can exchange the camera as maybe it is defective but it is an OEM bmw part.
      08-19-2023, 03:44 PM   #7
Aronis
Aronis's Avatar
2273
Drives: 2018 M5
double check part number......I had issues with various electronic items before. I got a new sensor for the windshield and the item I got had a part number that did not match the box. The correct sensor was plug and play and my heads up display had proper light dimming function. With wrong part it was backwards, bright sun made it dimmer and darkness made it brighter LOL.
Mike
      08-20-2023, 02:14 PM   #8
CrashCade
112
The part supplier is thinking I need to code something in BimmerCode and I do t know where to even begin.
      08-21-2023, 08:37 AM   #9
Aronis
Aronis's Avatar
2273
Drives: 2018 M5
Do you mods. Go to dealer.. " my camera is not working, can you scan the car and look for error (warranty), and they can "recode it" Freebo.
Mike
      08-22-2023, 06:28 AM   #10
NCRob
608
Drives: 2021 BMW M5C
I replaced mine a couple months ago with this one. Good seller with fast shipping. Plug & play and works flawlessly.
https://www.ebay.com/itm/15571422611...id=24054373589
      08-23-2023, 05:40 PM   #11
CrashCade
112
This is the exact one I purchased.
      08-24-2023, 06:23 AM   #12
NCRob
608
Oh! Actually I see in your moniker you drive a pre lci. Maybe that camera only works on the lci? Mine is a 2021. Otherwise, confirm with the seller and maybe try a replacement. Sorry for your luck with it!
      08-25-2023, 07:16 AM   #13
CrashCade
112
It is the same camera, you may have a valid point though in that the software handles the exchange a little different.
