BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    IND | BMW M Performance Coilover Kit
      02-11-2021, 03:12 PM   #45
MSX
100
Drives: X5
Originally Posted by adianaty View Post
In case anyone is interested in these wheels they are 863M not 873M. It took me a good 30 min to find them but the part numbers are:
Front Wheels: 9.5Jx20 ET28 (p/n 36118097642)
Rear Wheels: 10.5Jx20 ET28 (p/n 36118097643)
opps sorry for the typo, now corrected
      02-17-2021, 06:22 PM   #46
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
K&W HAS kit has my vote. This is not on the lowest setting right after an install, which means it will settle a bit more.
Current: 21 M5 Comp, 17 X5M, 06 M3, 14 Ferrari FF, Tesla Model S Performance.
      04-24-2021, 03:38 AM   #47
GJE2008
15
Drives: M5
Hi - I'm having the BMW kit and 12mm spacers installed now on a 21 comp. Dealer is concerned that there is minimal clearance at the factory settings (stock height) and lowering front could result in rubbing under certain situations. Any thoughts on how much the front can be lowered without causing any rubbing issues? Thanks!
      04-25-2021, 02:36 AM   #48
MSX
100
Drives: X5
I am currently running the HAS kit, the front is at its lowest setting and the back is setup to match the front in hight (as i did not want the rear wheel tucked under the arch) i also have 15mm spacers on the front and 10mm on the rear
even with four in the car I've had no rubbing issues
      04-25-2021, 07:02 AM   #49
GJE2008
15
Drives: M5
Thanks, great to hear! How about when steering wheel is fully locked? Dealer seems to be more concerned about potential for rubbing when wheel is locked at slow speeds...parking situations. This is probably dealer being overly cautious.
      04-28-2021, 04:36 PM   #50
GJE2008
15
Drives: M5
Dealer sent this picture over today. Front is set at its lowest setting, back is about 10mm lower than stock height. 12mm spacers in front and back.
Appreciate 2
      04-28-2021, 08:12 PM   #51
euro*
euro*'s Avatar
1658
Drives: F90 M5
Looks quite high. My F90 seems to sit way lower than yours on the BMW M performance has.
You can remove both front and rear wheels and check it out, and see if the suspension is actually set at max low or not.
      04-29-2021, 12:08 AM   #52
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
That's the perfect drop for the M5 in my opinion I'll be doing the same. Looks perfect.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      04-29-2021, 11:11 AM   #53
GJE2008
15
Drives: M5
I personally like the way it looks, but I'm surprised it can't go lower. I'll check settings later in the year when winters go on. Thanks for the input.
      04-30-2021, 12:26 PM   #54
MSX
100
Drives: X5
Ive not had any issues
      04-30-2021, 12:27 PM   #55
MSX
100
Drives: X5
Looking good
