09-20-2016, 11:52 PM | #222 |
240
Rep 342
09-21-2016, 12:24 AM | #223 |
2374
Rep 8,364
Boeing Driver240.00 |
09-21-2016, 12:35 AM | #225 |
2374
Rep 8,364
09-21-2016, 12:40 AM | #226 |
240
Rep 342
09-24-2016, 03:41 PM | #228 |
10445
Rep 40,789
Drives: 2018 Alpina B6 650ix GC
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
09-25-2016, 11:10 PM | #230 |
10445
Rep 40,789
PM sent.
09-26-2016, 08:02 AM | #231 |
84
Rep 154
I have hopefully a quick question/clarification or two. I am about the code my car, I got the software installed got the right cable etc. I have also read the forum and other directions a couple of times to the point where I think I confused myself.
My question if when I try to connect to the car, does the engine need to be running? One set of directions I was reading say the car does need to be running, so I just wanted to verify that. Any other "gotchas" people have run into that could help someone doing this the first time? Thanks to everyone who wrote the directions, and comment. Hopefully after I do this once or twice, I will be someone who can help other. |
09-26-2016, 09:56 AM | #232 | |
10445
Rep 40,789
20) Ensure Car has adequate power and is switched on. *NOTE: A continuous power source of at least 12.6 Volts is needed. Failure to maintain proper voltage can lead to corruption of ECU Data. As such, ideally the car is connected to an external charger. In lieu of using an external charger, the car can instead be coded with the engine running in order to maintain proper voltage, which is acceptable for coding all ECU's EXCEPT the DME (Digital Motor Electronics) ECU or DDE (Digital Diesel Electronics) ECU. The DME/DDE are typically not coded anyway, so this ECU limitation is generally not an issue.
10-04-2016, 01:14 AM | #234 |
10445
Rep 40,789
cloudzy131.00 |
10-04-2016, 06:47 AM | #236 |
10445
Rep 40,789
PM sent.
10-11-2016, 09:08 PM | #237 |
868
Rep 1,413
Drives: 2020 X3MC
Guys I have a quick question as a rookie coder. I got a bunch of stuff done last night and tonight worked on and got the NGHB coded and sweet mama its awesome.
So after doing VO coding I lost my previous FEMBODY coding which I knew would happen but when I go to re-code that stuff do I revert to my previous FA that didn't have the couple modules removed or can i just use the current modified FA and do a straight re-code? |
10-11-2016, 09:24 PM | #238 | |
2374
Rep 8,364
10-11-2016, 09:25 PM | #239 |
868
Rep 1,413
Drives: 2020 X3MC
10-13-2016, 11:50 AM | #241 |
31
Rep 74
I have a 16 comp package and I did vo coding for the euro lights but I coded all the ecu's instead of just the the three specific ones. my question is will that effect anything ZCP related?
Thanks! |
10-13-2016, 01:52 PM | #242 |
913
Rep 1,427
Nope, but I hope you didn't code DME while the engine was running. That would throw errors.
Tags |
bmw coding, f80 coding |
