BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > TSB (technical service bulletins) for the E90 / E92
      05-26-2010, 04:38 PM   #67
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
This what you are looking for?
http://www.bmwtis.com/tsb/bulletins/...p/B540205g.htm
      05-26-2010, 07:40 PM   #68
cb1111
I ask the questions you're afraid to ask.
cb1111's Avatar
44
Drives: 335xi
Originally Posted by raceyBMW View Post
yep - thanks. One of my co-workers has this issue and the dealership was clueless.
      06-01-2010, 02:54 AM   #69
red.66mustang
Black.e90
red.66mustang's Avatar
Drives: 03 M3, 6MT, Carbon Blk/Cinnamn
Any information on the TSB re: creaking windows? Where they replace "window guides"
Mentioned in this post (#55)
http://www.e90post.com/forums/showth...ng+door&page=3
This issue is driving me nuts! Any help would be appreciated!
Current: 03 M3 6MT Carbon Black/Cinnamon; 1963 Volkswagen Beetle Ragtop; 1965 Ford Mustang Conv. 289/4spd
Retired: 2006 325i 6MT, 1966 Ford Mustang; 2006 VW Jetta 2.5L, 5MT
      06-05-2010, 05:49 PM   #70
hhkim
hhkim's Avatar
Drives: '10 335d
2006 325xi  [0.00]
+1 it is driving me crazy!!
MY10 335d: Montego Blue, Oyster/Black Leather, Aluminum Trim, Navi, ZSP with Paddle Shifters, ZCW, Alarm
Order Placed: Aug 15th, In Production: Sept 1st, At Port of Exit & Awaiting Transport: Sept 15th, Sept 16th, At Prep Center: Oct 7th, Released to Carrier: Oct 22nd, Delivered: Nov 11
      06-09-2010, 02:46 PM   #71
cobradac
cobradac's Avatar
20
Drives: '05 645Ci Coupe
2005 645Ci  [0.00]
Updated list through end of May 2010. BTW I did a review of the body related SIBs and found nothing directly related to creaking windows "window guides".
Member - Knights of the Roundel (bimmerdriver s.com)
Over 58 runs of the ToD (or 18,444+ curves)
      06-09-2010, 03:03 PM   #72
raceyBMW
king of the hills
raceyBMW's Avatar
92
1994 530i  [9.00]
This is such an excellent resource, thank you for taking your time to update these lists...you rock!
      07-08-2010, 05:47 AM   #73
beeker
32
Drives: e90 2005 3-series
Hi ya
Your lists have help me on a couple of occasions where the dealership has denied all knowledge of their being a known issue. Keep up the good work.
I have gone from and E90 to an E84 (X1) are there any TSB for the X1 yet?
Thanks in advance.
      07-09-2010, 11:51 AM   #74
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
Originally Posted by beeker View Post
Hi ya
Thanks in advance.
You must be in UK?
BMWNA is not yet bringing in E84 to USA. Not sure if they will or not. SIBs I list are from BMWNA and not necessarily applicable worldwide, although th etechnical stuff sahould be unless ONLY applicable to US equipment. You may notice gaps in numbers and that for one of two reasons. The missing may be for other worldwide locations or just held in reserve for something being worked on. If/when X1 is brought to USA then they will be included in SIBs.
      07-09-2010, 12:28 PM   #75
DJHakim
DJHakim's Avatar
23
Drives: 330i xDrive
Is this the thread where you report the latest list of Target Data Status, too?
F34 (2019 330xi): Luxury, ZCV, Nav, ABSD, Alp White
F34 (2016 328xi): Nav, ZDA, Alp White
F30 (2013 328xi): ZCP, Nav, PDC, Alarm, Shades, GS Metal [Ret]
E90 (2009 328xi): ZCP, iDrive, BMW Assist, PDC, Alarm, Shades, SG Metal [Ret]
E90 (2006 325xi): ZSP, ZCP, iDrive, BMW Assist, PDC, CA, Xenons, Shades, CrO3 Exhaust, TiAg Metal [Ret]
      07-14-2010, 09:10 AM   #76
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
It hasn't been but probably should be here. I had been using a thread (not a sticky) that I responded to once early on with the list and just kept using it for updates. I will post here (next post) and let ADMINS determine if it should remain here or have its own place (preferably a sticky)
      07-14-2010, 09:22 AM   #77
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
ISTA/P (formerly CIP) list
Updated ISTA/P list:
And a note or two.
Recent terminology change (may have been at time ISTA/P came about [ or ISIS] and I simply did not notice) is the coding in vehicle is now titled "Vehicle Data Status" (VDS) vice previous "Target Data Status". This is the information coded into the car at time of a software update and is the only reliable method of determining your software level. Just as a reminder, one individual may have been told they got ISTA/P 2.33.1 and another ISTA/P 2.33.3. They both have the same software: VDS E89x-09-03-520. ISTA/P is a collection of various models' software so while a 5 series may have changes the 3 series may not and of course vice versa.
File Type: pdf CIP_Level_info_1-3_series_Rev6_0710.pdf (29.8 KB, 2002 views)
      07-29-2010, 11:37 PM   #78
skybox
skybox's Avatar
Drives: E92 335i Dinan II
Nice..
This is very helpful, Many Thanks!
      08-03-2010, 02:09 PM   #79
ALLLRIGHTYTHEN
12
Drives: 2007 Silver 335i Sedan
New Open Campaign - B13 09 10
New DME calibration improves the engine starting strategy and the robustness of the HDP high-pressure pump...
      08-05-2010, 08:31 AM   #80
Rinos
Cyprus
17
Drives: E92 320i coupe
Hi guys
I need some help
I have an E92 320i
--- Last November i got the engine management light and the car was shaking immensely
It was still within warranty so they changed an ignition coil and was fixed.
--- Around march i got the engine management light again and took it in. The mechanical engineer said it was probably because i had too little gas in the tank and the car might have sucked air.
--- The last month i was getting huge hesitations and lately with the A/C on i could not drive the car. I took it to the dealers and picked it up today. They changed the following:
1. Knock sensor
2. One ignition coil
3. NO2 sensor
--After just a month the car is again kaputt
Can anyone tell me if there is a Service Information bulletin concerning this problem?
Thanks, appreciate any help
"Go fast or go home"
320i Space Grey, Dakota Black, Aluminium Trim, 6FL, Bluetooth
      08-06-2010, 11:59 AM   #81
sfef84
Drives: 06 325i
AWESOME STUFF
I especially appreciate the new TSB about excessive cranking to start the engine!
What is the difference between TSB and ISB?
1)As I was reading through the list, I saw an ISB for E60 regarding the replacement of valve cover due to cracked screws or something. My e90 325i w/ 127,000 miles has FOUR cracked screws but has not been leaking oil (phew).
Any TSB for the e90 yet for that issue?
2) Any update for a TSB regarding the DSC FTM failure (some say the fix is a steering wheel sensor replacement)? It seems there have been a lot of instances of this failure lately
      08-06-2010, 12:04 PM   #82
sfef84
Drives: 06 325i
Also, are TSBs covered with vehicle OUT of warranty? It would seem like they should but want to know before I go to the dealer armed with e90post printouts... especially since BMW techs LOVE to deny they know about any recalls or prior experience with the "problem at hand"
      08-09-2010, 03:48 PM   #83
cobradac
cobradac's Avatar
20
2005 645Ci  [0.00]
Originally Posted by sfef84 View Post
AWESOME STUFF
Do not know what an ISB is. SIB is Service Information Bulletin, which is BMW speak for Technical Service Bulletin (TSB).
1) That was pretty old SIB on the V8 engines only. No similar issue with I6 engines.
2) Nothing new in regard to SIB ion this subject. Way back on '06 and '07 the 5 and 6 series had issues with the SZL (Steering wheel sensor) that manifested itself as a DSC, or ABS or Active steering or active roll stabilization errors or failures.
As to your next question on in / out of warranty – Each SIB states clearly whether BMW will cover the cost or not and gives the center a special code to use for IN WARRANTY. 99 % are covered but some items will not be. If you are out of warranty you would be obliged to pay regardless. Now it is true that once in awhile you can get the dealer to cover the cost under “goodwill”. That is applied on a case by case basis and works best of you had complained about a problem during the warranty period which subsequently does break after the warranty period. Or it could be something they already repaired once or twice before. You usually have to approach this in a polite but firm manner and often requires going to the service manager and pressing your case. Polite letters often help in this case as well. There are some special cases (I think the HPFP is one example) where BMW has extended the warranty period on that item ONLY for 5 or even 10 years.
      08-21-2010, 05:09 AM   #84
pmenadue
Drives: 320i Exec
Incredibly Useful!
This thread is SO useful!!!
THANK YOU for posting the Service Bulletin summaries - this has helped me discuss this with more information on my side.
Thank you.
      08-23-2010, 10:37 AM   #85
acontisr330i
acontisr330i's Avatar
Drives: 2006 330i blk/blk
Tsb
Can anyone find me tsb 640805 ? 06 330i rear defrost
      08-23-2010, 01:43 PM   #86
m_thompson
m_thompson's Avatar
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
http://www.bmwtis.com/tsb/bulletins/...p/B640805g.htm
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
      08-25-2010, 10:40 AM   #87
e92phreak
e92phreak's Avatar
Drives: E92 335i TiAg/E46 323i TiAg
2007 E92 335i  [9.50]
2000 E46 323i  [0.00]
Having this one done this morning. "SUPPOSEDLY" it's the end-all update for the HPFP long cranking issue... My SA cautiously said this, saying that it's only the latest fix. We'll see how long until another one goes out.
Since my HPFP is an April 2010 one, I should have the new part.
07 E92 335i | TiAg | Step | Padl | Cmft | Alum Trm | PDC | Nav | Assist | Sat | Lthr | Prem | Sprt | Rear Splr | RDSport Quads | iPod | V1 | LT Refl | VS Clear Bra | OEM Lip | KWV2 | Mtec Sides | BBS LM-R
00 E46 323i | TiAg | 5sp | Sport | Roof | RDSport Cams | RDSport tune | RDSport Shift | Volk LE37 | M3 spoiler | PSS9 | SuperSprint | Brembo
      08-26-2010, 01:38 AM   #88
Rinos
Cyprus
17
Hi again
i am the poster of post #80 with the 2008 E92 320i
Do you get this engine in the states? Do you have any Service Information bulletin for this engine?
I have a serious problem with the car
Also do you know if there is a European equivalent to http://www.bmwtis.com?
Thanks
