BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    two-piece wheels leaky?
      08-06-2021, 12:40 AM   #1
BayDriverSF
204
Drives: BMW M5 2021
I keep reading on forums that two-piece wheels suffer from more leaks because the seal between the two halves can become compromised.
Is this a problem with old designs, or also with more current wheels like the BBS BMW F01 7-Series CH-R II Wheel for example?
      08-06-2021, 07:44 AM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
I've had two-piece 21" wheels on my last three M5's with no issues.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      08-06-2021, 12:15 PM   #3
BayDriverSF
204
Drives: BMW M5 2021
Is there really a seam between the two pieces? I always thought that the second piece is just the cover that's screwed on. I never thought there would literally be a seam running halfway through the inner wheel.
      08-06-2021, 03:18 PM   #4
josec70
josec70's Avatar
There u go .. like I said, I've never had any issues with two-piece wheels. Go with a Monoblock if it is a concern for you.
      08-06-2021, 06:10 PM   #5
BayDriverSF
204
Drives: BMW M5 2021
Thanks for the diagram. Oof. That is not going to be as foolproof as a single piece.
      08-08-2021, 07:38 PM   #6
slicer
slicer's Avatar
2739
Drives: 'E46 M3 Race Car, '23 X7
BBS 2 piece wheels have no place to leak. The rim is a single piece and the face is the second piece. The potential for leaking occurs with 3-piece wheels because they are a lip and barrel bolted together which can possibly leak. That being said, I have never had that occurs with BBS 3 piece (E88).
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
