08-17-2023, 02:28 PM | #68 | |
114
Rep 177
There shouldn't be any codes if done correctly. Make sure you are differentiating between US and Euro models. |
08-20-2023, 10:28 AM | #69 |
229
Rep 236
Drives: 2020 BMW M340i xdrive
Just finished the install.
A tip for those trying to get that one screw out that is blocked and you don’t feel like drilling a hole. There are 2 - 10mm bolts which you can remove and push the bracket to the side. This makes it possible to get your screwdriver in there to remove the screw. |
08-20-2023, 04:06 PM | #70 | |
Rep 37
I was thinking of using thermal paste from computer CPUs. Any reason behind commending a 50/50 ratio? |
09-06-2023, 08:35 AM | #71 |
214
Rep 420
Did you ever reach out to confirm fitment? Looks like no one has the boards for US spec cars. I've been talking with IceDriver on Aliexpress and I think I am going to send out a set of US spec LCI boards for him to work on, so hopefully he will have them available for US spec cars soon.
chrish_22114.00 |
09-06-2023, 06:20 PM | #72 | |
114
Rep 177
If you end up doing it, let me know! Would love to see this happen and would appreciate that! |
BLK.G20214.00 |
09-08-2023, 12:13 PM | #73 |
63
Rep 194
I got my yellow DRLs from Mod Emporium on Instagram. He probably gets it from the same source. It did require prying off the old ones from the heat sinks. Install is a PITA because to get to the outer monitors, you need to pull the headlights at least partially out to get access (or you can drill holes I guess), which requires removing the bumper. I also used the paste he shipped it with, and it seems to be holding fine after several months. Overall happy with the purchase and the effort was worth it IMO.
09-11-2023, 12:22 PM | #74 | |
75
Rep 207
G20_Rick5.50 |
09-14-2023, 04:36 PM | #75 |
Rep 37
Had my "version 2" DRLs installed on Tuesday, September 12th. Used the method suggested by BobTheBimmer and it made things fast and easy for install. Also used the method suggested by Nembus with the 50/50 ratio of the thermal paste provided with the DRLs and CPU/GPU thermal paste. Took roughly 20-30 minutes for the 50/50 mix to dry/settle in the sun (cloudy SoCal day in the low 80's).
As for when we took the "version 1" DRLs out, we immediately noticed the DRL modules came right off the heat sinks. A further indication that the thermal tape was faulty by design. I didn't think of it at the time, but I should have taken photos of this. Also, the backings on the "version 2" DRLs have metal backings. Will do a month update as the "version 1" DRLs didn't last that long. Hopefully you all don't hear from me before then. |
09-14-2023, 05:11 PM | #76 | |
75
Rep 207
G20_Rick5.50 |
09-20-2023, 08:33 AM | #77 |
Rep 17
Hey everyone, I am new to all this. I was searching for some modifications for my new car and stumbled upon this item: https://a.aliexpress.com/_mtkAziw
I am planning to buy RGBW DRL Module (EU-LED) and have few considerations before I buy it. It looks dope but I am not sure if it will be a big problem to install it. I saw some videos on Youtube and honestly I don't feel very confident in removing front bumper for installation. The option which BobTheBimmer mentioned seems good and I might try it. The question I have is for those that ordered from IceDriver, did they provide thermal paster and how do I know if this item is version 2 and not version 1? |
09-20-2023, 08:44 AM | #78 | |
B58 Power
496
Rep 630
Drives: 05/2022 M340i xDrive Touring
Version 1 has a blank back while version 2 has a metal plate on the back.
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
09-20-2023, 11:13 AM | #79 | |
155
Rep 191
Drives: BMW M440i
Also are some colors I.e. red and blue illegal in your country reserved for emergency vehicles? DRL Install w/o bumper pull |
09-26-2023, 01:45 PM | #82 | |
114
Rep 177
Funny enough, Bayoptiks is about an hour from where I live! |
09-26-2023, 02:17 PM | #84 |
214
Rep 420
Yeah I just got a second set. They were only $200 for the pair. That way I could have a backup set if I ever need them for some reason. The boards should be delivered to them today. They told me it will take 2-3 weeks for them to convert them.
chrish_22114.00 |
09-26-2023, 05:59 PM | #86 | |
114
Rep 177
Also, do you mind me asking how much bayoptiks is charging? |
09-27-2023, 02:32 AM | #87 | |
Rep 7
Thinking of getting this for my 330i |
chrish_22114.00 |
09-27-2023, 06:37 AM | #88 |
214
Rep 420
