ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > Z4 DIY (Do It Yourself) Articles
  TireRack
      09-18-2021, 12:20 PM   #45
rsutoratosu
114
Drives: Z4 3.0i
Nope.. mine did not.. which is kinda good, that manual valve have known to get stuck.. I left that cable off mine. I mean if you want to buy original BMW for 4x the cost to get the valve, you can.
-Roranji
      09-18-2021, 03:18 PM   #46
golfmanpat
Drives: BMW z4
I've already ordered the Mustang pump. I was just curious whether it had it or not.
      09-23-2021, 08:45 AM   #47
FigureItOut
Drives: BMW Z4 3.0i
The mustang pump alternative does not include a manual bypass valve. Once you plumb the new pump in your top will either function or remain static, no manually wrestling it into place.
Because of this it's wise to have the top in partially open state when you do your initial function testing. This will give you a fighting chance to avoid getting it stuck in fully open or fully closed condition if you plumbed it up wrong.
      10-20-2022, 01:58 PM   #48
JoeModz
Drives: 2003 BMW Z4 3.0
Thanks for this great info. Approximately how long did the job take?
      10-23-2022, 02:13 PM   #49
rsutoratosu
114
Drives: Z4 3.0i
Mine took about 2-3 hour. I didn't have the right tools to pop that cap off the top and had to order the mustang motor and wait for it.. but with the right tool, it should take about 1-1.5.
I also spend time cleaning the mustang motor as the fluid it came in was pitch black.
-Roranji
      12-26-2022, 04:19 PM   #50
Straight Shooter
Drives: 2006 Z4M Roadster
Broken motor terminal
I broke the terminal off my roof motor and thought I could just bolt the Mustang motor up to my pump for a quick fix, but seems they don’t quite match up. Anyone ever fix a broken terminal—or do I just have to swap out entire motor/pump assembly?
      01-15-2023, 09:09 AM   #51
knsaber
knsaber's Avatar
Drives: 2007 BMW M Roadster Imola Red
Definitely a shout out to the OP for this. After. Few years I decide to tackle the broken roof motor. Replaced the motor only with eBay aftermarket but somehow I screwed up a pin inside the pump. Found this and immediately ordered the Mustang assembly from eBay. Quick swap of the entire assembly and it worked right away testing with a Power Wheels 12v battery. OP saved me hundreds of dollars!
Now I have an extra motor available for sale.
      11-07-2023, 02:12 PM   #52
mothy5000
mothy5000's Avatar
8
Drives: '08 BMW Z4 3.0si E85
Originally Posted by 3002 tii View Post
Btw were you able to relocate the pump without taking the top out? Seems like there’s a lot of info on the boards suggesting it’s possible but no definitive DIY. And I don’t see that shop in Europe who does this offering their trade secrets anytime soon.
Most definitely. I've done three of them so far. Takes about 45min to and hour.
      11-07-2023, 05:19 PM   #53
3002 tii
3002 tii's Avatar
2293
Drives: Z4 M, X5, GX460
Too bad you’re not closer to me, I’d pay good money for someone to help swap it if they could do less than an hour!
Follow for latest mods
      11-11-2023, 08:59 PM   #54
rsutoratosu
114
Drives: Z4 3.0i
I could have help you 3-4 years ago. I no longer can fit in trunk. too many burgers
-Roranji
      03-15-2024, 08:40 AM   #55
knsaber
knsaber's Avatar
haha this was not fun.
Appreciate 2
Vanne1623.50
      03-29-2024, 09:22 PM   #56
rsutoratosu
114
Drives: Z4 3.0i
You didn't eat enough burgers..
-Roranji
zpost
