01-16-2023, 12:59 PM | #1 |
Machine Lover
24
Rep 17
Turbo Intake Filter Removal?
Hi,
Recently on the Facebook F90 owners' group, someone suggested that removing the pre-turbo filter is a 'no brainer'. It was something I hadn't even thought about (although I'm not deeply into modding). What are the thoughts of this group? Aric
Aric Keith
2022 M5 Competition |
01-16-2023, 02:28 PM | #3 |
1475
Rep 1,309
I think you might be referring to the charcoal filters, right? You definitely do not want to remove the air filter or you'll get stuff sucked into your turbos and I am no expert but that's going to cause major problems. If Charcoal filters you have this:
https://f90.bimmerpost.com/forums/sh....php?t=1544785 As for the air filters -- if you go aftermarket intake you'll get those stock ones changed out or a lot of people talk about drop-in BMC filters over stock.
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
01-16-2023, 02:46 PM | #4 | |
Machine Lover
24
Rep 17
Aric Keith
01-17-2023, 12:43 AM | #5 |
151
Rep 141
I removed mine. Noticed a little more intake noise, didn't notice any other difference in throttle response or anything like that. Worth it for the noise
01-21-2023, 02:09 PM | #6 |
Machine Lover
24
Rep 17
That was easier than I hoped it would be after reading the thread where some people seemed to fight with a step or 2.
I would modify the directions slightly to not bother removing the flex hoses. Once you loosen the star drive screws on the airbox, you only need to tip it up a couple inches to get a flat screwdriver into the lid and pop out the charcoal filter. |
