10-03-2021, 09:19 AM | #199 | |
257
Rep 764
Good to hear this, your making me want to run the E30/40 stage 2 file lol |
10-04-2021, 04:46 PM | #202 | |
IG @bmwF9xG80
3813
Rep 7,593
Sent you PM
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
10-04-2021, 04:50 PM | #203 |
87
Rep 315
no just stock tune wanted to feel a good difference paired with dinan tubro inlets and bmc filters
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel |
12-31-2021, 12:13 PM | #204 |
135
Rep 296
Does anybody here have a stock file log? I got my car now (2018 M5, 45k km, fresh out of service - new oil, plugs, fully loaded w. CCB) and it pulls only 8.9s 60-130 / 7.7s 100-200. This is a bit slow it seems to me. All at just 13c (55f), 122m (530ft) DA & 75% humidity.
Here is a log and another. Seems to me that the AFR in second is crazy high up top, the boost not hitting the target. Car is in warranty so want to fix things up first before any tuning in future possibly. |
12-31-2021, 01:38 PM | #205 | |
MFJWADE
120
Rep 351
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
luke1990134.50 |
12-31-2021, 02:04 PM | #206 | ||
135
Rep 296
On timing - do you mean the overall timing correction or individual cylinder corrections? To me the former (overall) is not good, the individual while not clean is not too bad. Thanks! |
01-01-2022, 06:45 AM | #208 | |||
MFJWADE
120
Rep 351
You timing at end of 5th looked close to normal, your timing in 3rd and 4th is where you're losing power in that particular log file.
luke1990134.50 |
01-01-2022, 11:06 AM | #209 | |
135
Rep 296
I did a new log today. I did reset adaptations to see if this would help things (maybe somebody wasn't running best gas in it before I don't know ). From launch it did 3.4 0-100 & 7.4 100-200 (log here); so what I'd expect, but rolling 100-200 was again 7.5-7.8 (logs here, here). The logs show much lower boost but higher timing. My worry is that this is also in almost ideal setting - 40% fuel, 1 person, 12C, 10m DA only. Also logged like 30 mins of driving around (log here) - part throttle most of the time. There are some knocks here when one gets on part throttle and timing corrections of up to -7.5 which I don't like. But its part throttle and when going WOT there are no knocks. Question is - should I get the car looked at before I try any tuning? To exercise any warranty. Does this look like something mechanically wrong? Or is it just base file doing something weird which will get fixed up when flashing proper map? THANKS! |
06-11-2023, 11:26 AM | #210 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
I have been having issues with running any ethanol. Had to replace lpfp twice within the last 30 days. I was running custom tune with timing close to 20 but with bm3 ots stg2 93 timing stays around 10-11. Wanted to ask if that is normal as I have always ran e40 in the past. Also it’s been close to 100f so assuming that contributing to low timing as well.
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
