BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Flat Tire / Tire bursting every month
      04-08-2021, 02:45 AM   #1
Abran_tasrif
Abran_tasrif's Avatar
Drives: 2020 BMW M5
My F90 is lowered on H&R M550i Springs. After lowering everytime I hit a huge bump my front tires become flat and bursts out either left or right side. Never happened before springs.
I had to change 6 times now the front tires. Happens every month almost. Front is running Pirelli P Zero 275/35/20
Rears are Michelin PS4 285/35/20
Anyone facing similar issue?
      04-08-2021, 03:22 AM   #2
skypx
Veteran U.S. Army
skypx's Avatar
Germany
60
Drives: ///M
wait... you have Pirelli's in the front and Michelin's in the back? thanks, I needed a good laugh today.
      04-08-2021, 05:19 AM   #3
bruza
bruza's Avatar
367
Drives: '21 M5 & '06 Volvo S60 R
HUGE issue there
to answer OP, nope not yet at least and many of the roads in NJ are far from great.
      04-08-2021, 05:25 AM   #4
TrevorM3
3322
Drives: 6.3 AMG
why is running two different tires (and both are similar anyway) on two different axles bad? i've seen this done before. not a huge deal, and this is definitely not caushing his problems.
my dads car is lowered the same, has the same pzeros up front, Never an issue... sorry i can't help OP
      04-08-2021, 05:50 AM   #5
AHall
982
Drives: 1993 Nissan 240sx
I had to change 6 times now the front tires. Happens every month almost. Front is running Pirelli P Zero 285/35/20
Did you try taking the car back to the place where you had the suspension modified? If so what did they say? Just out of curiosity why would you not put the stock wheel sizes on the front? I assume the car came with Michelin tires. Why did you switch to Perrelli tires in the front? I am not sure what is causing the problem, but these are just some questions that come to mind.
      04-08-2021, 06:30 AM   #6
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
I've been on H&R 550's for more than two years with zero issues on 21" wheels.
What tire pressure are you running?
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      04-08-2021, 08:26 AM   #7
italiabrain
74
Drives: 19 M5 Comp
Are you sure about those tire sizes? That’s not the correct size for the front, and doing 285 width on the narrower wheel might contribute to blowing the bead. Also, could you clarify “huge” bumps? You’re not expecting to hop curbs or large potholes with your lowered sport sedan are you?
      04-08-2021, 09:35 AM   #8
Crumbs
192
Drives: 2018 F85 X5M Mineral White
lowered and horrific NYC streets will probably due that to you. i had that issue years ago in a F30 have not lowered the F90 yet.
      04-08-2021, 10:01 AM   #9
Abran_tasrif
Drives: 2020 BMW M5
Car came with P Zeros, I changed the rears to Ps4s. I was just waiting for summer to change the fronts to PS4s. Summer is nearby now so will do it soon.
Changed rears because tires were bald.
      04-08-2021, 10:02 AM   #10
Abran_tasrif
Drives: 2020 BMW M5
Suspension installed 100%.
I had it reinstalled twice as the first shop didnt do it properly
      04-08-2021, 10:04 AM   #11
Abran_tasrif
Drives: 2020 BMW M5
41-42 PSI front, 38/39 PSI Rears if I remember correctly.
      04-08-2021, 10:07 AM   #12
Abran_tasrif
Drives: 2020 BMW M5
Originally Posted by italiabrain View Post
Are you sure about those tire sizes? That's not the correct size for the front, and doing 285 width on the narrower wheel might contribute to blowing the bead. Also, could you clarify "huge" bumps? You're not expecting to hop curbs or large potholes with your lowered sport sedan are you?
Sizes are OEM.
Huge bumps as in the type of bumps in the roads of NYC.
The bump I hit at 40MPH is probably the size of a 27 inch Monitor. Deep hollow inside.
      04-08-2021, 10:11 AM   #13
Oswiff
Oswiff's Avatar
Drives: 2021 m5 comp
Sizes are OEM.
Huge bumps as in the type of bumps in roads of NYC.
OEM for the front is 275/35/20
      04-08-2021, 10:15 AM   #14
Abran_tasrif
Drives: 2020 BMW M5
Sizes are OEM.
Great, I just ordered the wrong tire. Thanks for commenting.
      04-08-2021, 11:06 AM   #15
bruza
bruza's Avatar
367
Based on OP's mention of tread depth difference between front and rears, you should replace all 4 at the same time on AWD Vehicles. Guess I inferred the tread part before he said it.
2021 M5 Competition Marina Bay Blue/ Individual Tartufo/ Individual Piano Black Trim. Took delivery 11/27/2020
2017 X5 ///M Silverstone/Mugello Red/ Carbon Fiber Trim Turned in 11/27/2020
      04-08-2021, 02:19 PM   #16
josec70
josec70's Avatar
Try running 33-34 and see if that helps ... a tire that is less inflated will have more give when it hits a pothole when compressed against the wheel.
I run 33 front and 34 rears.
      04-08-2021, 03:05 PM   #17
Oswiff
Oswiff's Avatar
That's what my tires were inflated to after break in service. Previously they were in the 40's
      04-08-2021, 04:00 PM   #18
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
Im in NYC too, Upper West Side to be exact. Im lowered on 20in and haven't had any issues. The roads are pretty bad so I try to drive around most of the potholes. I run 34 all around.
      04-08-2021, 06:57 PM   #19
josec70
josec70's Avatar
The incompetence at dealerships never ceases to amaze me .. I honestly cringe every time I leave the car.
