2011 335d - Occasional Belt Squeal at Start Up
07-30-2017, 01:37 PM | #134 |
Sleepy
75
Rep 367
Do not use the crank pully bolts! make sure to use the 9mm allen hex. You will back out the bolts when you turn it counter clockwise like i started to do. Also turning it clockwise will probably add torque to the fastener and no need to do any of that when you need the 9mm to turn the crank anyways.
07-30-2017, 04:59 PM | #135 |
213
Rep 2,210
You shouldn't turn the engine counter clockwise to begin with, and it won't add torque turning it clockwise unless you have the wrong belt. The torque to get the belt on is way below the tightening torque of those bolts
07-30-2017, 05:06 PM | #136 |
160
Rep 803
I don't know but when putting on my ac stretch belt on the x5, the already torqued harmonic bolts got tighter. I was worried about overtorquing them. Someone made a little socket that has a cross pattern which goes in between the bolts to turn the harmonic balancer for belt installs.
07-30-2017, 05:53 PM | #137 | |
Sleepy
75
Rep 367
Are we talking about the same engine here? Or the same tool? What are you talking about? |
07-30-2017, 06:06 PM | #138 |
213
Rep 2,210
07-31-2017, 08:39 AM | #140 | |
Sleepy
75
Rep 367
The lisle tool only installs the belt counter clockwise so using the crank bolts will loosen them for sure. As far as clockwise goes i am really only assuming the potential to make them tighter when uninstalling the belt. The point is why is them at all or any other bolt when the 9mm allen on the PS drive shaft works perfectly and you are going to have to use that anyways to install the belt. Whats your reasoning here i dont understand it. |
07-31-2017, 09:44 AM | #141 | |
213
Rep 2,210
08-01-2017, 04:22 PM | #142 | |
Sleepy
75
Rep 367
Please explain. I am not following you at all. Last edited by Asonchadwick; 08-02-2017 at 10:08 AM.. |
08-01-2017, 04:39 PM | #143 | |
213
Rep 2,210
08-01-2017, 05:57 PM | #144 |
2133
Rep 3,361
08-02-2017, 01:34 AM | #145 | |
Sleepy
75
Rep 367
Apparently others are as well because anyone using the make and model of tool and putting said tool on the crankshaft harmonic balancer pulley the belt only installs and uninstalls as mentioned...sorry guys thats all there is to it and no where in reality can it work differently. But you are more than welcome to post pics or better yet videos detailing how you used that make and model of tool to install the 335d a.c. stretch belt, placing the tool on the harmonic balancer, and turning it clockwise to install the belt lmao Last edited by Asonchadwick; 08-02-2017 at 10:04 AM.. |
08-02-2017, 09:13 AM | #147 | |
322
Rep 1,157
08-02-2017, 09:47 AM | #148 | |
Sleepy
75
Rep 367
Ok i now know no one here but me has actually used that exact tool to install the a.c. stretch belt on a 335d Lemme just look real quick make sure i am in the 335d forum...mmmm yep Lemme makensure we are talking about the a.c. stretch belt...mmmm yep So thank for posting the video Come on guys are you just trying to mess with because i am new or do you really, actually, honestly believe this crap you are posting I mean if you wanna put the tool on the back of your harmonic balancer and some how magically remove the a.c. stretch belt by turning the balancer bolts counter clockwise why not just get a knife and cut it off? Better yet how about a ninja sword or just burn off the belt with a torch Personally the fastest way is just take like a stick of dyn-O-mite, strap it to the a.c. belt (make sure your car is properly on jack stands first and the rear wheels chocked for safety), then light the fuse (give yourself at least a foot of clearence between you and the car and have a spotter. A good rule of thumb is to use another forum member or two who have experience removing the a.c. stretch belt...for safety) None of you guys used the tool OBVIOUSLY so i dont know what the point is trying to lie about it here and mess up others Seriously! i hope everyone follows your advice and you all get banned |
08-02-2017, 10:05 AM | #149 |
213
Rep 2,210
Wow that is a lot of smileys and excitement. I will say, the tool is definitely not designed to work for installing and removing the belt by turning the engine the same direction. However, that does not make it impossible as I found out, it just takes a little ingenuity to get it to work clockwise on the front for installation. Obviously Im not going to take my belt off and make a video reinstalling it just to prove a point on the internet, but suffice it to say it is possible.
08-02-2017, 11:00 AM | #151 | |
Sleepy
75
Rep 367
Hell yeah I love getting all worked up for nothing I looked at it again maybe you could put it on clockwise but it's not supposed to go that way |
08-02-2017, 11:22 AM | #153 |
322
Rep 1,157
As far as a 335d goes there's a lot of stuff that isn't supposed to happen going on. These cars are rigged so many ways. Just depends on how creative you want to get. The video doesn't lie though. And considering Hooper's status in this community, I doubt he is going to lie about what he did. It's clearly possible to do it all clockwise. Regardless of how you're "supposed to" do it.
08-02-2017, 11:37 AM | #154 |
213
Rep 2,210
From memory, I believe what I did was flip the tool over to the install side, hook the belt over the install ramp just like you would do if turning counter clockwise but with the belt on the pulley in front of the ramp instead of behind, turned clockwise instead and it worked fine. The fancy little belt director/ramp thing on the install side is really not necessary since the belt does not hold form past the end of the ramp anyway so I just looked past their design and treated the install ramp as basically a hook to keep the belt from sliding off. It is unfortunate that the tool is designed to install and remove in different directions since youre never supposed to turn an engine in the reverse of its running direction, but I guess that is what they had to do to design a tool that would work on both the front side and back side of pulleys.
robnitro160.00 |
