08-13-2021, 12:02 PM | #23 |
BimmerPost Supporting Vendor
24463
Rep 191,414
08-31-2021, 12:05 PM | #24 |
24463
Rep 191,414
09-15-2021, 11:49 AM | #25 |
24463
Rep 191,414
09-30-2021, 12:02 PM | #26 |
24463
Rep 191,414
10-15-2021, 11:42 AM | #27 |
24463
Rep 191,414
10-30-2021, 01:32 PM | #28 |
24463
Rep 191,414
11-27-2021, 01:41 PM | #29 |
24463
Rep 191,414
01-12-2022, 11:54 AM | #30 |
24463
Rep 191,414
07-21-2022, 09:04 AM | #31 |
24463
Rep 191,414
08-16-2022, 01:50 PM | #32 |
24463
Rep 191,414
08-16-2022, 03:06 PM | #33 |
50
Rep 239
Hi there! I m yr italia customer. I did the kratos stage 3 on my s55 with HCP. Does it work adding EXTRA PSI? I'm targeting 30 psi. Running 28 at today
08-17-2022, 02:43 AM | #34 | |
24463
Rep 191,414
Yes, you can use it to add a few PSI
09-13-2022, 01:21 PM | #35 |
24463
Rep 191,414
10-11-2022, 11:39 AM | #36 |
24463
Rep 191,414
12-09-2022, 09:46 AM | #37 |
24463
Rep 191,414
01-20-2023, 08:56 AM | #38 |
24463
Rep 191,414
01-22-2023, 11:34 AM | #39 |
50
Rep 239
T-T Unable to work on strong map
Dear Mike,
Hope you're doing well. I purchased it and installed and set properly. At very beginning I was enthusiast cause at low rpm (psi) was working very well. I shouted for happiness but unfortunately it stops quite immediately because while pressing the gas and increasing rpm (psi) the engine started ... like knocking.... the lower PSI set on the T-T the better, if you put 4 psi increase, it works VERY good at low rpm but gives error immediately, if you set 1 psi increase it works less but for higher rpm. Finally I must remove it most probably because my map is already strong (Halim Stage 3, waiting him for the 4). This device cannot works on heavy tuned map, this is bottom line. I was trying also to run it at opposite, working ONLY at low rpms (psi) and stop it function above certain rpm (psi) where the map is strong itself but I didn't succeed cause the APP doesn't permit this function. Very sorry because it's a good device. Thanks and kind regards, Giorgio
BMW M4 F83 Stage 3/4 - Akrapovic Skat DP, NO OPF, eVenturi Intake, Okada Coils, Kratos Turbos EVO, Dodson 1000 Nm Clutch Dct - Mishimoto IC, Water and Oil Coolers - CP Carillo Pistons - Arrow Connecting Rods - Reinforced bearings - Halim Cazimi HCP Software 2.0 bar Turbo - XHPFlashTool for DCT Stage 3+
03-14-2023, 10:03 AM | #40 |
24463
Rep 191,414
05-04-2023, 08:40 AM | #41 |
24463
Rep 191,414
06-26-2023, 09:06 AM | #42 |
24463
Rep 191,414
08-17-2023, 09:54 AM | #43 |
24463
Rep 191,414
10-09-2023, 10:04 AM | #44 |
24463
Rep 191,414
