2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Need to replace rear brake pad carrier bolts?
      01-19-2020, 07:10 PM   #1
bthomas518
Drives: 2016 228i
I've looked up part # for rear brake pad carrier bolts (34-20-6-850-536), it is a M12 x 1.5, 32mm. Was wondering if anyone knows if these are supposed to be replaced after removal?
The torque spec of 30Nm + additional 90 degrees turn makes me think these are one time use "stretch" bolts, but not sure.
Can anyone chime in?
Thanks,
Bryan
      01-19-2020, 07:27 PM   #2
bthomas518
Drives: 2016 228i
Page 22 of this .pdf suggests that they need to be replaced. http://f30.bimmerpost.com/forums/att...6&d=1476916748
I think they are under $5 each, probably wise to just buy new ones and toss the old.
If anyone knows for sure, would still like to hear from you.
      01-19-2020, 07:56 PM   #3
John in VA
1001
Drives: 2015 228i M Sport
This isn't a project I've had to do on the F30 or F22 yet, but on the 2002s, E28s, E30, E39 & E46s I've not replaced the bolts. Maybe use some blue threadlocker.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      01-19-2020, 11:51 PM   #4
aerobod
Car Geek
aerobod's Avatar
3718
Drives: Caterham R500, M2-G87, Macan S
Definitely a stretch bolt that should be replaced. The TIS specifies 50Nm +60 degrees for the 228i rear caliper carrier here: https://www.newtis.info/tisv2/a/en/f...rakes/GfyH0Hrd that would likely be close to 30Nm +90 degrees, though.
Appreciate 2
dradernh4480.50
      01-20-2020, 12:39 PM   #5
bthomas518
Drives: 2016 228i
Thank you, sir!
      01-23-2020, 10:25 AM   #6
dradernh
dradernh's Avatar
4481
Drives: 2017 M240i
I'm curious...when reinstalling the front caliper bolts, would you recommend replacing them as well?
Oddly, the bolt is listed as a Torx while a hex is shown in the parts image:
2017 M240i: 23.8K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
      01-23-2020, 11:30 AM   #7
aerobod
Car Geek
aerobod's Avatar
3718
The TIS shows them as requiring replacement, but not a stretch bolt due to no angular specification in the tightening torque, so the replacement may be a precaution due to thread locker or other reasons, but shouldn’t be due to the elongation of the bolt making it unsuitable for reuse: https://www.newtis.info/tisv2/a/en/f...rakes/GfqyNpyB
M12x1.5 at 110Nm for a 10.9 or 12.9 bolt is below it’s plastic range, so strain in the bolt shouldn’t be an issue for reuse. The picture in realoem showing a hex bolt may just be a generic image, the descriptions are usually more accurate.
Appreciate 2
dradernh4480.50
      04-13-2024, 04:42 PM   #8
pbedrosi
pbedrosi's Avatar
Drives: BMW E91
Doing rear brakes now, called dealer for bolt replacement and they reuse them unless seriously corroded....and the torque is "pad carrier to knuckle" torque. It was a bitch to remove, definitely not 22 ft-lbs, these are the 110Nm/81 ft-lb bolts.
2addicts
