03-03-2021, 03:55 PM | #815 | |
Rep 22
By the way, I'm getting a bit worried, if BMW will not do the official reveal of G26 during the next couple of weeks. Because all the info bits so far support revealing it in March, specificly early March. Why they revealed the unfinished iX already last November, when the SOP is July 2021, is only to create hype - when G26 still remains hiding with the same SOP and fully finished technology and design. It seems that electricity is making car makers to act illogical. Of course, if they will reveal also i4 at the same time with G26 ICE, they might want to hold it back, because i4's SOP is only in autumn. |
03-03-2021, 11:01 PM | #817 |
Moderator
7517
Rep 19,368
So it’ll actually trail the G20/G21/G80 LCI by one four-month update interval. Oh well, it should go through the end of G21 production in 6/26 (just like the M4 convertible should outlast the M4 coupe, ending with the 4 Series convertible) which still gives it over three and a half years on the market.
03-04-2021, 01:33 PM | #818 | |
2199
Rep 2,558
03-04-2021, 01:53 PM | #819 |
Moderator
7517
Rep 19,368
03-04-2021, 02:09 PM | #820 | |
2199
Rep 2,558
https://g80.bimmerpost.com/forums/sh...23&postcount=8 |
03-04-2021, 02:14 PM | #821 | |
Moderator
7517
Rep 19,368
It could boil down to hair splitting. The E61 M5 wasn't expressly limited, but they sold fewer than 1000 worldwide to my recollection. So, if you apply the same production cadence to the G81, you might end up with a similar total assuming roughly the same production window. However, that cadence isn't set in stone - it can no doubt be adjusted based on demand. I suspect that while the G81's MSRP will be similar to the E61 M5's, it'll be somewhat more popular due to AWD and perhaps a more friendly (if less exciting, subjectively) engine. If, so they'll be pumping them out of assembly a bit more often. |
03-04-2021, 02:47 PM | #822 |
2199
Rep 2,558
03-04-2021, 03:39 PM | #823 | |
Moderator
7517
Rep 19,368
But ynguldyn is the one to listen to when it comes to production vehicle info. A G81 is different from a CS or CSL or what have you. Sure, it's not going to be huge volume. But it's just not the type of vehicle you market as a "special" deal. Same reason you don't see these come in the final year or whatever (I was actually surprised it's trailing the LCI by even a few months - but I forgot to consider the fact that the G21 goes longer than the G20 which helps justify that). I mean if you go through the effort to create stampings for the fenders, rework all sorts of stuff (see the F81 conversions for how much needs to change), it doesn't make sense to only produce it for a short time. |
03-04-2021, 04:10 PM | #824 | |
2199
Rep 2,558
I saw it as, -at initial tease: plan was quick 1000 units for a marketing burst more for the press than satisfying consumer demand (the g81 actually went under @ynguldyn radar until after leaked) -3 months later: legitimate demand higher than expected, expand to series production |
03-05-2021, 03:14 PM | #825 |
7655
Rep 3,441
Now that we know the SOP, I have an explanation of that: it was leaked _very_ early in its development cycle. If that hadn't happened, I would have broken the news some time in the second half of 2020, more than 2 years before SOP - which is pretty much on par with everything else I report here.
I suspect BMW was actually testing the waters at a point where the project didn't yet have a lot sunk costs and would've been easy to cancel. So yeah, the could have thought about a limited run at first but then the enthusiastic reception convinced them to make it into more than just a small experiment. |
03-08-2021, 05:13 PM | #826 | |
Moderator
29652
Rep 13,137
///M is art ↔ Artemis
03-09-2021, 12:07 PM | #827 | |
7427
Rep 10,229
Off hand do you happen to have the production numbers for the F87 M2? I remember seeing them here one day and have had trouble finding them. |
03-10-2021, 08:03 AM | #829 |
Moderator
7517
Rep 19,368
If true that likely means the difference in power between the M50 and M60 is small, and the difference in power between xDrive50 and M50 is zero.
I say this because, while I realize we don't have the numbers for the i4 yet, at this point it seems a forgone conclusion that the M50 model will employ the 523PS (515hp) setup that was previewed in the Concept i4 and which has been the subject of rumors going back years. And, it now appears that the iX xDrive50 will use that same setup, while the iX M60 gets less than 10% more power. We don't know battery capacities, so those could still be further (more significant?) differentiators between these various new model names. Still, this is disappointing. With the M60 setup also headed for the G70 7 Series, I was hoping for more - 600hp at the very least to sort of pick up where the V12 left off (as the name M60 might imply). I suppose we'll have to wait for M70 or M80 or some-such for that. |
03-10-2021, 10:33 AM | #830 | |
Moderator
7517
Rep 19,368
Regarding power output, matching the M50e PHEV drivetrain would seem to be arbitrary / coincidental. That is to say, okay, maybe they will have the same power output, but they won't have anything to do with one another since the iX is a BEV, not a PHEV. |
03-10-2021, 11:26 AM | #831 |
7655
Rep 3,441
Right now I'm looking at a specific US-spec iX M60, which is explicitly named "iX M60" in the document. Are you suggesting that there's an even more recent change and the M60 name has been discarded?
03-10-2021, 11:33 AM | #832 | ||
7655
Rep 3,441
03-10-2021, 12:19 PM | #833 | ||
Moderator
7517
Rep 19,368
I guess my point was, the "M" has tended to indicate a power increase: M40i models make more power than 40i models, M50i models made more power than 50i models when the two briefly coexisted (the 750i is an outlier since it would surely be an M750i if not for the unique M760i V12 model). Quote:
03-17-2021, 03:07 AM | #835 |
Rep 22
The official reveal of the all-new G26 i4 Gran Coupe is finally here:
https://bimmerpost.com/forums/showthread.php?t=1808569 Last edited by Bemari; 03-17-2021 at 05:34 PM.. |
soheil64.50 |
03-17-2021, 05:39 AM | #836 | |
Rep 8
Seems like naming of electric vehicles seems to be a great challenge within BMW |
Tags |
future bmw, release date, upcoming bmw |
