335i limp mode party at the track
07-30-2010, 07:15 PM | #23 |
675
Rep 4,080
I'm not crazy about covering the radiator with another radiator. AR had a version that fit in the drivers side in front of the wheel, mirroring the other oil cooler. Not sure what happened to that.
I've got the VK oil cooler which looks the same as the Dinan and it's made a big difference v. stock, as has running higher octane on the track. I don't run a tune and have not had issues with limp mode (although I suspect I'm running up against it most of the time). I will do an upgraded radiator as soon as a little more reasonable option is available. That would be for greater margin + long term reliability (BMW radiators are notorious for crapping out). |
07-30-2010, 07:39 PM | #24 |
just another M3
514
Rep 1,152
yeah same here I thought the cooler would on the driver side.
07-30-2010, 11:29 PM | #25 |
893
Rep 9,034
I've ran a couple HPDE with the CCA at the Roval and had no issues. Both times it was around 90 degrees on track and I ran full sessions.
The last time out there, someone in an E92 335 had the same issues as the OP and it was maybe 85 degrees on track. He couldn't get a full session in without limp mode. Go figure??
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
07-31-2010, 08:12 AM | #26 | |
81
Rep 1,510
When I started doing DEs last year, I couldn't overheat the 335 even if I wanted to. Now, it's a matter of how many laps I can get in 90F ambient, with the same mods. On the flip side, I'm 6-10 secs faster this year per lap. I'm sure advanced students and instructors can overheat the 335 in half the laps it takes me to do the same. Also, I'm not in favor of a cool down lap every few laps. It breaks concentration & flow, including messing up the entire run group if you're running with fast guys/gals. I'd rather drive to my limit for 10 mins per session, overheat, do a single cool down lap and pit in. Last edited by mid-corner fun; 07-31-2010 at 10:03 AM.. |
08-02-2010, 01:21 PM | #27 |
104
Rep 2,368
I guess i will join the overheating club . I totaly understand what hack is saying about consistant power and how it distrupts learning. In the beginning of the day, since its cooler i cant get on full power as early as I can in the later portion of the day. I would be easier to learn on a car that spits out the same power all the time so you can define where in the turn you get down to the floor. I guess ill wait for HP on their news of a new radiator.
08-02-2010, 03:22 PM | #28 |
99
Rep 1,050
Hack brings up a good point about the long engine block.
Interestingly, I gentleman around the corner from my office has a Ferrari garage, building and preparing race cars and fixing street cars. He's a friend and tracks himself. He looked at my car after telling him about the overheating and the first thing he said was I should cut vents in my hood and in back of the wheel well He must think I'm made of money that I could do that to my car. He went on and on about getting the air moving more efficiently to get cool air in there to replace all of the hot air. Is this something that's being missed; ventilation? |
08-20-2010, 02:35 PM | #29 |
Rep 13
Drives: 2009 335xi LeMans Blue
No limp mode with Dinan oil cooler
Peter,
I'm pretty sure we were at Monticello together in June. My kid took pictures, and I have some of your car (match your avatar). Anyway, I have never gone past 245-250 degrees on the oil temp with my Dinan package. Even with the stage 2 turbo upgrade, the bigger oil cooler has made all of the difference. Through 8 track days this year, I haven't once gone into limp mode. If you want some pictures (if Mike didn't send them already) or you want to chat about Dinan upgrades let me know via PM/email. Tom |
08-20-2010, 02:49 PM | #30 |
Cogito Ergo Zoom
13
Rep 64
Drives: 2013 BMW M3, 2016 BMW X1
See the cp-e FMIC and oil cooler group buy:
http://www.e90post.com/forums/showthread.php?p=7792304 |
08-20-2010, 02:58 PM | #31 | |
81
Rep 1,510
yep, that was me. Are you referring to the VK cooler? Glad to see you've been enjoying limp-mode-free track days. I had no problems in Monticello in June and from my videos it seems I hit no more than 260 there (1 tick over mid), but from what I recall ambient temps were relatively cool both days. I started having limp mode probs in July when temps hit 95F+. PCA packs 6 x 25min sessions in one day and my oil temps were not dropping fast enough between sessions. I was starting at 230, jump to 270-280 within a few laps and then downhill to 300F from there. I'm running with PCA in Thunderbolt next Friday and I'm back in Monticello with Patroon on Monday in case you're planning to attend either of these, come by and say hi! |
08-20-2010, 03:02 PM | #32 | |
81
Rep 1,510
08-20-2010, 05:24 PM | #34 |
Rep 13
High Temps
Peter,
WOW! I've never seen that. On my car, the Dinan oil cooler replaced the one that came with my car. The oil cooler sits in the right front wheel well, while still allowing air to in to get to the brake rotor. One of track days was a 95 degree day up at NHMS, and still no problems. Temps max-ed at 250. Go to http://www.dinancars.com to check it out. If you have a stock oil cooler, it is a bit cheaper and easier to install since it is a replacement. Tom |
08-20-2010, 09:05 PM | #35 | |
81
Rep 1,510
thanks again |
08-24-2010, 11:53 AM | #37 |
99
Rep 1,050
The Dinan could be better than the AR due to placement but I would like to see a lot bigger OC duct in the bumper with a fog light delete available. I will never use my fogs and would appreciate more air.
When I install the HP radiator it could have a lot more flow with the Dinan since the AR sits right in front of the radiator. |
09-11-2010, 12:25 AM | #38 | |
Supreme Allied Commander
3883
Rep 54,472
Drives: F80 M3
I'll tell you what cost the most, to draw up the inlet and outlet, program the CNC machine and the run-time to make it. If you really want to know how much a prototype one cost us, you better be sitting down. It would be easier if BMW just kept the old E30/36 style hose clamp hose ends, then maybe the radiator can sell for $800. With the prototype all aluminum radiator, we had zero issues with our Time Attack 335i, even in the heat of Buttonwillow and Las Vegas. When ER and Berk had coolant temp issues on the long straights with extended time under full bost, we were nice and cool. What is amazing is the recovering time of the all aluminum radiator, it wook no time to come back down to the 190s F. |
09-12-2010, 08:38 AM | #40 |
99
Rep 1,050
09-12-2010, 01:00 PM | #41 |
3883
Rep 54,472
Drives: F80 M3
We use the stock oil cooler. With our prototype all aluminum radiator we had neither oil or water temp isssues at either Buttonwillow, Las Vegas or Auto Club Race way. Both ER and Berk's 135i had cooling system temp issues at those tracks.
09-12-2010, 03:54 PM | #42 | |
214
Rep 1,071
Not to get off topic, but this is also why I've always questioned the 335’s alleged parity with the E46 M3. While the published specs in many car magazines do suggest that the cars are similar performance-wise, the fact is that they're very different when pushed to the limit. IMO, my 2004 M3 Coupe’s power delivery, chassis dynamics, handling, braking, and SUSTAINED PERFORMANCE are superior to my 2007 335i Sedan’s. The 335i’s N54 engine may be fine getting around the Nordschleife in 8:26, but it will be completely heat-soaked and limping before it completes 15-20 minutes of sustained hot lapping on any track (and even sooner if it’s equipped with a Steptronic slushbox and/or chipped). In contrast, the E46 M3’s S54 engine, transmission, and cooling system will keep the car going strong until it needs to pit for fuel. That’s a HUGE difference between the two cars...
09-12-2010, 04:07 PM | #43 | |
99
Rep 1,050
09-12-2010, 08:17 PM | #44 |
My ride: bimmergirl84
22
Rep 302
And I heard the driver was taking it super easy...
