Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M3 (F80) and BMW M4 (F82) General Forum
Closed Thread
      11-24-2013, 09:46 AM   #67
CanAutM3
CanAutM3's Avatar
21125
Drives: 2021 911 turbo
Originally Posted by e39>all View Post
The 0-60 time will be as good as the m5's. BMW simply will not list a lesser model's performance better or equal to their flagship models that cost much more. Also, I would wager the actual power of the new m3/4 is at least 450hp, and around 400 ft lbs torque.
When it came out, the E92 DCT M3 had the quickest advertised 0-100km/h of all models in the BMW brochures, including the E60 M5 and E63/64 M6...
It was the same when the E46 M3 came out compared to E39 M5.
I still have those brochures .
I don't see why it could not be the case with this new generation
      11-24-2013, 01:58 PM   #68
swamp2
swamp2's Avatar
Drives: E92 M3
Originally Posted by CanAutM3 View Post
I am curious on the mathematical formula you used to calculate 0-60mph from a 0-100km/h number
A very rough approximation is the following:
t(100km/h) = t(60mph) * 1.036
This simply assumes that the acceleration from 60 mph to 100 km/h (about 2 mph change in speed) occurs at a constant acceleration and is equal to the average acceleration during the 0-60 mph portion. This is accurate to only about 25% for the M3, it predcts 0.15 s but the actual result is about 0.2 s. The largest error is due to the fact that most of the 0-60 time is in 1st gear but the 60 mph to 100 km/h is in second gear.
For cars of this rough power to weight 0.2 - 0.3 is a very good rule of thumb and better than the formula.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      11-24-2013, 04:39 PM   #69
JoeFromPA
1797
Drives: '15 AW M3 6MT Stripper
Huh, that's interesting. The e46 m3 was ultimately slower in a straight line than the e39 m5. Didn't know it was quoted by BMW as being faster.
The e39 m5 consistently ran faster and trapped higher. Not by much though.
      11-24-2013, 05:28 PM   #70
CanAutM3
CanAutM3's Avatar
21125
Agreed. This is in line with what I would have predicted.
I expected 4.1-4.2 0-60mph from the advertised 4.4 0-100km/h. Not 4.3 as the OP posted. This is why I asked what formula he used.
      11-24-2013, 05:29 PM   #71
CanAutM3
CanAutM3's Avatar
21125
We are talking 0-100 km/h here. Not ¼ mile trap speed.
      11-24-2013, 10:48 PM   #72
swamp2
swamp2's Avatar
Drives: E92 M3
It was a good question.
But an easy/reliable 4.1-4.2 seconds or a best?
IIRC BMW speced the E92 M-DCT at 4.7 s to 100 km/h. In reality it's best time was 3.9 s to 60 mph (thus about 4.1 to 100 km/h). With that simple math transferred to the new model we would predict a best 0-100 km/h of 3.5 s (4.1 - (4.7 - 4.1)). That could be as low as 3.3 s to 60. Now before anyone get's too excited, not that is clearly not the best way to predict this! This really crude extrapolation is probably not very accurate at all and almost for sure under predicts the time. I've predicted (through simulation) a 3.4 - 3.8 s for its 0-60 mph run (here). Either way it's darn clear it will be a sub 4.0 s car to 60 mph (some still actually don't believe this...)
      11-25-2013, 07:54 AM   #73
JoeFromPA
1797
Swamp - I think your 0-60 time and quarter mile ranges are way too optimistic on the the aggressive end of things.
Vehicles getting 0-60 in 3.4-3.6 seconds are doing it by AWD+launch control, gearing to hit it in 1st gear, and/or a lot more power.
I've followed your analyses closely and love a lot of them. However, on the acceleration front, your linked analysis appears to favor using linear increases to acceleration times when it's truly exponentially harder to drop a tenth of a second at these stages.
      11-25-2013, 12:08 PM   #74
pfl
113
Drives: Some slow cars
Awesome. I hope they make the launch control as easy as other competitors... sport mode for engine and traction control, mash both pedals, lift brake... *cough* C63, RS5 *cough*...
      11-25-2013, 12:43 PM   #75
paddy335
66
Drives: M140i;X5 40d
0-60, who cares. Has anyone seen or heard any mention of in-gear acceleration for the new cars? Especially 50-80, that's the most relevant to me.
      11-25-2013, 01:16 PM   #76
tdizzle
Drives: 2017 F80 ZCP
Sub 4 second is going to be tough. Even if the power/torque is there traction will be the biggest issue. Maybe if you used drag radials on a perfect surface. Now if it had AWD that magically added no weight...
      11-25-2013, 01:22 PM   #77
JoeFromPA
1797
Exactly. We are well into the power range where dropping a tenth of a second has less to do with power and more to do with traction.
      11-25-2013, 01:59 PM   #78
basscadet
basscadet's Avatar
166
Drives: 991.2 GT3
Still waiting for 60-130 times myself. Let's see what this car can really do.
      11-25-2013, 06:43 PM   #79
CanAutM3
CanAutM3's Avatar
21125
We are talking conservative BMW advertised numbers here.
The math I used is quite simple. Most magazine test data suggest a 1 to 1.2 sec time for the 60 to 70mph on a DCT M3 ("similar" power to weight). Doing a linear interpolation yields a 0.22-0.26 sec time from 60 to 62.15mph.
Interestingly, BMW official numbers show only a 0.1 sec difference. The Canadian brochures indicates 4.6/4.8 (DCT/6MT) to 100km/h while the US brochures quotes 4.5/4.7 to 60mph.
Agreed. The F8X will be much faster than that. I also expect best runs to be comfortably in the 3 sec range for the 0-60mph as tested by US car magazines (US accepted test standards). The articles refer to a specially developed PSS for the F8X; I wonder how much improved traction will result.
      11-26-2013, 01:16 AM   #80
pkimM3r
pkimM3r's Avatar
207
Drives: m3 saloon in granny mode.
Im not liking some of the responses here in terms of an "enthusiast" community. As others have mentioned, and argued against me that bmw indeed reads these forums and delivers to "enthusiasts" in this way. But its sad that these types of "wants" exist in this community that i would expect the "other" 99% of bmw owners out there to care about eg. mpg, city usable torque, comfort, blah blah. Hence this is what we are getting. I need a supercharger and call it a day.
      11-26-2013, 05:32 AM   #81
IEDEI
Drives: L'Orange
2011 BMW 1M  [8.40]
Why are you even arguing over 0-60 times? It's a completely inadequate measure of acceleration. It's too easily influenced by gearing, computerized launch, traction influences, and mechanical abuse.
quarter mile time or trap speed, 40-100, 30-70, 60-120....fine, I get it. But 0-60? C'mon. Means so little.
agreed. 0-60 times are like judging a woman only by the perkiness of her nipples. there's always so much more to the story.....
      11-26-2013, 10:34 AM   #82
cjwb1984
cjwb1984's Avatar
Drives: 2012 BMW Z4 Sdrive35i
Thanks for the link. It was interesting to read. I'm excited. There is definitely a lot of technology that went into the M4/M3. It's important to me how all of that translates into the road.
Definitely, this M4 pique my interest.
      11-26-2013, 10:44 AM   #83
basscadet
basscadet's Avatar
166
Drives: 991.2 GT3
So what kind of things should the enthusiast community care about?
I have asked for more power, more than anything else, and I am being told that I should buy a muscle car if all I care about is straight-line performance.
      11-26-2013, 11:41 AM   #84
pkimM3r
pkimM3r's Avatar
207
it should come with slicks, jaw jarring suspension and a cage and no airbags .... what else would you need?
i think the new m3/4 is going to be more muscle car like...c63ish perhaps. since everyone complains about tq, which i still can't understand.
      11-26-2013, 03:11 PM   #85
ersin
ersin's Avatar
Drives: 17 YMB F80 M3
Never underestimate the importance of perkiness.
Just for comparison...
Vette: 3444 lbs / 460 hp = 7.49 lbs/hp
M4: 3306 lbs / 430 = 7.69 lbs/hp
The best time I've seen recorded for the C7 Vette is 3.7 seconds to 60. The M4 has more weight to horsepower. But also note that, IRL, some are reporting the 1/4 for the vette running 11.4 @ 119 mph, and 11.5 @ 120, which are pretty respectable.
Cheers.
2017 F80 YMB.
      11-27-2013, 02:27 AM   #86
swamp2
swamp2's Avatar
Drives: E92 M3
Thanks.
Can you expand on the important bold part above? I don't understand that at all.
My estimates for all performance results in the new M4 are based on CarTest physics based vehicle performance simulation software. It generally handles vehicle launch, wheel spin and the differences between friction coefficients for spinning vs. non-spinning conditions all quite well. It it a perfect launch algorithm, certainly not but the essence of the physics is captured. Now why have I reported a range of numbers? Again that was from a simple bracketing approach allowing for reasonable estimates of the uncertainties associated with underrating and vehicle weight.
The current M3 has already done a 3.9 s 0-60 (with standard US 1 foot roll out). What makes you think that with a significantly improved power to weight ratio, significantly more power at low rpm, very likely a new improved tire and also very likely improved LC software that at least a couple tenths better than that won't occur? Look I am not saying that your average everyday M4 driver will consistently get 3.5 second 0-60 runs. However, I am also virtually guaranteeing we will see one or more magazines run 3.8 s or less.
Not entirely directed at you but: 0-60 certainly is not the "end all be all" or the most important metric I care about. However, good results do show a combination of good engineering and design all working together, engine, transmission, differential, software, chassis, tires, etc (and of course driver). Some other metrics indeed are better at "displaying" the true power to weight of the car (and not much else...).
      11-27-2013, 06:01 AM   #87
CanAutM3
CanAutM3's Avatar
21125
Cheers.
We also need into consideration that the S55 is most likely underrated at 430ps. On the other hand, I doubt we will see many cars at 3306lbs...
      11-27-2013, 07:38 AM   #88
Sapper_M3
Sapper_M3's Avatar
Drives: 2012 E92 M3, ZCP
Cheers.
Agreed, but if it's even POSSIBLE to spec a 3306 lb M3/M4, it will be a huge victory. I'm cautiously pessimistic (my heart can't take anticipating a 3306 lb vehicle and receiving a 3506 lb vehicle).
As a side note, thinking about the area under torque vs RPM curve is still eating away at me. If we integrate force vs time, do we get work?? Do we need to integrate twice with respect to time in order to find power???
Closed Thread
Tags
2014 bmw m3, 2014 bmw m3 horsepower, 2014 bmw m3 specs, 2014 bmw m4 horsepower, 2014 bmw m4 specs, 2014 m3, 2014 m3 engine, 2014 m3 forum, 2014 m3 horsepower, 2014 m3 hp, 2014 m3 specs, 2014 m3 weight, 2014 m4 engine, 2014 m4 horsepower, 2014 m4 hp, 2014 m4 specs, 2014 m4 weight, 2015 bmw m3, 2015 bmw m4, 2015 m3, 2015 m3 engine, 2015 m3 specs, 2015 m4, 2015 m4 engine, 2015 m4 hp, 2015 m4 weight, bmw f80, bmw f80 forum, bmw f80 forums, bmw f80 m3, bmw f80 m3 s55, bmw f80 m3 sedan, bmw f82, bmw f82 forum, bmw f82 forums, bmw f82 m3, bmw f82 m3 coupe, bmw f82 m3 forum, bmw f82 m4, bmw f82 m4 coupe, bmw f82 m4 s55, bmw f82 m4 video, bmw f83, bmw f83 m3, bmw f83 m4, bmw m forum, bmw m forums, bmw m3 carbon fiber roof, bmw m3 forum, bmw m3 forums, bmw m3 s55, bmw m3 s55 engine, bmw m3 yas marina blue, bmw m4, bmw m4 concept, bmw m4 concept coupe, bmw m4 coupe, bmw m4 coupe concept, bmw m4 curb weight, bmw m4 weight, f80 m3 specs, f80 m3 weight, f82 m4 specs, f82 m4 weight, m4 weight
f80post
