12-27-2021, 02:30 AM | #1 |
66
Rep 144
Porterfield R4S review
I figured I would let any prospective buyers know a thing or two about these pads since I just made the switch. Since I've only driven about 100 miles or so on them I can't get too in depth, but I will say that so far my expectations have been exceeded. I purchased these pads really for one reason and one reason only and that is to cut down on dust. With the stock "M" pads I could drive a few miles up the road after cleaning my rims and they would literally be coated in orange dust. It was to the point where I didn't even bother. These pads cut that down dramatically, to what I would consider a normal amount. I mean I can actually keep my rims clean for at least a few days now. With these massive rotors and calipers there is and always will be a dust factor, but its now manageable, and the stopping performance is surprisingly comparable. They aren't quite as "grabby" as the stockers but I don't mind that anyways. I like a more smooth feel to the brakes. They aren't cheap but nor is anything for these cars! I will continue to monitor their performance as they bed in a little more but so far I'm content and would recommend them to anyone looking to correct the dusting issue without hampering performance much at all. Thanks to all who recommended these to me.
01-11-2022, 02:43 AM | #2 |
IG: @M5RCY_
364
Rep 316
Super interested in set. Please report back after more miles
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
01-11-2022, 02:33 PM | #3 |
2896
Rep 3,726
I have these on my car. They are pretty good cold, but they need a bit of heat in them to REALLY grab.
Very very very low dust, just SLIGHTLY more than Akebonos. Very easy to clean. The P4S will make some noise when you really get on them in the canyons, but it stops once the pads cool down.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
01-11-2022, 04:06 PM | #4 | |
IG: @M5RCY_
364
Rep 316
01-11-2022, 10:33 PM | #5 | ||
2896
Rep 3,726
I would consider Endless MX72s for my next set of pads. They will dust more but I've heard Endless makes some of the best pads in the world.
01-13-2022, 07:44 PM | #6 |
130
Rep 214
^^^ I had both and Endless all day. You will have less brake dust than stock pads.
shawnhayes1829.50 |
01-19-2022, 01:35 AM | #7 |
2896
Rep 3,726
Just to give everyone an update here, the Porterfield R4S failed on me only a couple of months in. Ended up cracking a pad during a canyon run from over heating the pad. I would not recommend it for a heavy car with R compound tires.
Too bad because I really enjoyed them as a street pad, but definitely not something you can be aggressive with in high speed twisty roads. Ultimately I lost confidence in my braking about half way into the run and the pad lost a small chunk of pad material during the process. It seems like when these pads exceed their temperature rating, they become very inconsistent. High initial bite followed by very mediocre braking behavior. I am going to have to step up to a race pad and deal with dirty wheels every other day, but I will learn to live with it to avoid having a miscalculation at higher sustained speeds
shawnhayes1829.50 |
01-22-2022, 03:18 PM | #8 | |
1830
Rep 1,315
For the tooling around town, these sound okay, but not for what you're doing. Suggest you consider RacingBrake or endless for pads that will be up to the task. Shawn |
01-22-2022, 06:04 PM | #9 | ||
2896
Rep 3,726
I ended up with semi-metallic racing pads which make a ton of dust and noise, but the performance is well worth it.
shawnhayes1829.50 |
01-23-2022, 03:51 PM | #10 |
1830
Rep 1,315
hellokitty2895.50 |
02-16-2022, 12:19 AM | #11 |
28
Rep 56
I put these on a few weeks ago solely because I despise brake dust, and i’m slightly disappointed. Yes, it’s less, but it’s still enough that I’m not thrilled. My last car was an F80 M3 and I put Akebonos on it and they had almost zero dust and performed great. Was hoping for something similar.
2018 M5
vanos8466.00 |
02-16-2022, 09:09 AM | #12 | |
2896
Rep 3,726
shawnhayes1829.50 |
02-17-2022, 08:30 PM | #13 | |
12960
Rep 18,706
A few local guys used it already and been happy with it.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-20-2022, 12:54 AM | #14 |
28
Rep 56
You have them on your f90? Where can I get these? No dust?? lol i’m interested!
2018 M5
r33_RGSport12960.00 |
02-20-2022, 01:20 PM | #15 | |
12960
Rep 18,706
https://f90.bimmerpost.com/forums/sh....php?t=1894635 Been selling quite a lot since its arrival few weeks ago.
02-21-2022, 05:09 PM | #16 | |
28
Rep 56
2018 M5
