12-10-2021, 08:40 AM | #1 |
17
Rep 63
285/35/20 on front OEM wheel ok?
Hi guys.
I have winter tires on (275/35/20 square set up) now but will be putting back UHP tires in spring. My back tire (285/35/20 Pirelli Pzero OEM) has a lot of meat left in them so here is my dilema. Put the 285/35/20 in front wheel (9.5j) and put 295/35/20 PS4S in the back (10.5j) It seems 10.5j can take the 295 no problem, but putting 285/35/20 seem it's pushing the limit on the 9.5j OEM wheel. Has anyone done 285/35/20 and 295/35/20 on the OEM wheels? They are about +0.7% difference, so tolerance should be ok, but my concern is putting the 285/35/20 on the 9.5j OEM wheel. I don't want to have unstable during high speed cornering. Please let me (and the people on the forum) know if this setup is ok even with spirited driving. Thank you guys. |
12-10-2021, 11:44 AM | #3 |
1834
Rep 1,317
Pirelli says that this is okay on a 9.5.
I have put 285/35 on all four wheels and wrung it completely out on the track for many sessions. You will be fine. Shawn |
12-11-2021, 01:16 PM | #4 | |
133
Rep 296
hjl11317.00 |
12-12-2021, 07:53 AM | #5 | |
17
Rep 63
No problems so far. |
12-12-2021, 07:54 AM | #6 | |
17
Rep 63
285/35 on the 9.5j stock wheel? If this is really ok, I plan to put 285/35 in front and 295/35 in the rear for the spring. |
12-14-2021, 10:38 AM | #7 | |
1834
Rep 1,317
https://www.tirerack.com/tires/tires...XLV2&tab=Sizes Running 285/35 square reduces the understeer A LITTLE. Not sure I'd recommend this for novices, but certainly possible. I know little about your proposed setup. I hate non-square setups. Too much brain and worrying. Shawn |
hjl11317.00 Jonathan G.9.00 |
12-14-2021, 07:15 PM | #8 |
294
Rep 195
No issues with running a 285 up front. In fact this is what you’ll find on the M5s at BMWs driving schools. They run their cars with 285 Contis front and rear.
12-20-2021, 10:30 PM | #10 |
1834
Rep 1,317
Jonathan G.9.00 |
12-27-2021, 12:00 AM | #11 |
2337
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
My exact set up. Kinda. I did go into some detail on one of my most recent upgrades to my suspension set up.
IN A NUT SHELL, and based on what I have learned while owning and modding a car with this much power and torque, is that tires a smidge larger than what comes stock on the car ( and no, i'm not talking trash - I have the same set up as you'll see below! ) will NOT fix your issue regarding stability under hard acceleration and hard braking. Basically your rear tension links are "flexing" during these periods which will cause that feeling of instability you seek to fix. It pissed me off for some while and then I was given the knowledge here about a couple of parts that are PROVEN to give your F90 M5 a NIGHT and DAY difference... I can vouch, I did it to my car and it is F-in Perfect. The 2 mods you are in search are linked here: https://ind-distribution.com/collect...ball-joint-kit https://ind-distribution.com/collect...nsion-link-kit My Suspension/Tire Set up 20" 789M Wheels Michelins: Front: 285 | 35 | 20 Rear: 295 | 35 | 20 KW H.A.S Kit Macht Schell 15mm Spacers (Front) Future Classic 12mm Spacers (Rear) Dinan Rear Tension Link Kit Carbahn Ball Joint Kit Future Classic 80mm Titanium Stud kit Front: Rear: Fitment:
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY Last edited by FSHNGRY; 12-27-2021 at 12:13 AM.. |
12-28-2021, 02:03 AM | #12 | |
17
Rep 63
Beautiful! |
FSHNGRY2336.50 |
12-28-2021, 02:10 AM | #13 |
2337
Rep 2,029
thank you! I was just commenting on another thread about your car and the tyres!
I would love to go 305/35/20 in the rear and leave the 285/35/20 in the front on the 789Ms Does it work? any issues?
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
