05-30-2023, 12:29 PM | #1 |
682
Rep 527
Radar Detector - Uniden R8
Has anyone ever used the Uniden R8? Furthermore, has anyone ever mounted a radar detector on their powered rear view mirror? I see kits for this, that way, I do not have have to have an ugly cord going down to my cigarette lighter.
I have seen mounts from Blendmount. |
05-30-2023, 12:48 PM | #2 | |
4110
Rep 3,689
Drives: 2022 M5C
I have been powering my RD off the mirror since my first M5. If you’re using the suction cup mount that comes with it, you can run into issues. Here is my thread about what happened to me. The BlendMount is perfect to prevent what happened to me, but it is bulky and places another bulkier item (RD) right in my line of sight through the windshield, which I despise. Instead, I went with a permanent mount that has a clip like the suction cup mount into the RD, but has 3M VHB tape instead of suction cups that adhere to the winsdshield. It’s allowed me to place it just to the left of the rear view mirror electronics housing/surround on the windshield and is the cleanest looking install you can do for a standalone (i.e. not integrated) RD. It’s also very well hidden there and you can’t really see it from the outside unless you’re looking for it. I’ll post some pictures for you along with links for all the equipment I used when I am in the car later today. EDIT — Here is the MirrorTap, and here is the permanent mount. I’ll post the photos a little later and it will all make more sense. I don’t have a Uniden, I just searched the parts I bought, but for your RD, so please do your due diligence to ensure that these are the correct parts for you (though I am pretty sure they are). EDIT 2 — Sorry the links disappeared! I plugged them all back in now.
Not a BMW guy...but certainly an M5 guy.
dcohen13682.00 |
05-30-2023, 01:14 PM | #3 | |
5258
Rep 10,632
05-30-2023, 01:31 PM | #4 |
682
Rep 527
pbonsalb Does powering the radar from the mirror power cause any issues or codes with the car? Is it a pretty simple plug and play? I like the blendmount idea, as I do not mind the visibility.
Also ResIpsaLoquitur thank you for the detailed response! Only reason I am using the R8, is my buddy does not use it and offered to me for free for a rally I have this summer! |
ResIpsaLoquitur4110.00 |
05-30-2023, 01:55 PM | #5 | |
4110
Rep 3,689
Drives: 2022 M5C
I know the power question wasn’t meant for me, but I have had no issues with the brand I provided in the link. It doesn’t mess with the electronic functions of the rear view mirror, nor with HomeLink. It is simple plug and play. The solid DIY from AGS and this video will get you through it easily. Keep in mind that if you go with BlendMount, you’ll have at least 5-6 inches of cord visible between the RD and the rear view mirror. If that kind of thing bothers you (it would drive me insane), it may be irritating. The R8 is a fantastic device and a lot of owners swear by them. If that’s the level of device I needed to get the job done, I’d go with it again in a heartbeat. EDIT — Sorry the links disappeared in my first post, I’m putting them back in now in case you’re interested. EDIT 2 — Fixed the links!
dcohen13682.00 DarkishM5C308.50 |
05-30-2023, 04:32 PM | #6 | |
682
Rep 527
05-31-2023, 03:32 PM | #8 |
309
Rep 205
I have the Uniden R8 that I use daily on my M5. It has saved me several times since the majority of cops around me use KA band. I have it mirror mounted with the Blendmount adapter and powered from the mirror. I haven't had any issues or codes with powering it from the mirror. The only issue I had with the R8 is that the buttons vibrate, creating a squeaking noise. At first, I thought the squeaking was coming from the mount, since it was not doing it with the windshield adapter. But after trying different stuff, I narrowed it down to the R8. I put some clear tape on the buttons and that stopped the squeaking.
05-31-2023, 05:41 PM | #9 | |
682
Rep 527
05-31-2023, 06:06 PM | #10 | |
309
Rep 205
Best of luck 🙂 |
ResIpsaLoquitur4110.00 dcohen13682.00 |
06-01-2023, 02:37 PM | #12 |
4110
Rep 3,689
Drives: 2022 M5C
dcohen13, sounds like you’re going to go the BlendMount route, but in case you’re interested (or someone is checking out this thread in the future), here are the photos of how I set it up. The cleanest route for a non integrated radar detector if you ask me.
dcohen13682.00 |
06-01-2023, 04:25 PM | #13 | |
682
Rep 527
06-01-2023, 06:56 PM | #14 |
66
Rep 64
Yep, Blendmount is the way to go. IMO best mount out there for portable detectors, regardless of brand. Buy the mirror tap from them too. Perfect setup without spending millions installing an integrated system. And agree, the mirror trim is a bit tricky the first time you take it apart. German engineering...it just can't ever be simple. Lol.
dcohen13682.00 |
06-01-2023, 07:46 PM | #15 | |
4110
Rep 3,689
Drives: 2022 M5C
Keep us posted.
dcohen13682.00 |
06-01-2023, 08:27 PM | #16 | |
113
Rep 216
06-01-2023, 09:02 PM | #17 |
4079
Rep 5,235
Not an R8 but here is my Radenso with Blendmount and Mirrortap.
The Radenso is tiny so the BM works well.
dcohen13682.00 |
07-18-2023, 07:38 PM | #19 |
21
Rep 31
I've had the Uniden R8 for about 5 months now and like the unit. I mounted it using the mount that came with the unit. I wanted to mount it under the mirror using a blendmount but I tried to picture the detector sitting under my mirror and it would create a large blind spot for me. I ended up mounting it to the left of the rearview mirror. It does block my view a little but not as bad as mounting it under the mirror. I need to hard wire it because having that curled cord going from the detector to the lighter is jenky AF.
07-31-2023, 10:41 AM | #20 | |
519
Rep 389
07-31-2023, 02:06 PM | #21 |
4110
Rep 3,689
Drives: 2022 M5C
Check out my install and photos above if you decide to go next to the mirror!
