M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      06-20-2012, 05:36 PM   #23
lz419
Shaunny.L
Australia
17
Drives: E92 20d / R33 GTST
2009 BMW 320d  [0.00]
I'm not quite sure about the fuller they use..is it a oiled one or dry?
Sorry for the question, might be a but stup1d?
let's Torque'
K&N 57i, CRD-t , BE by Breyton 19', smurf with matte white interior, tune pedalbox, MD...almost there...
      06-20-2012, 05:39 PM   #24
Sean@PSI
Sean@PSI's Avatar
Drives: 2021 IOMG M3 Sedan
They use oiled K&N filters.
      06-20-2012, 05:55 PM   #25
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
A. I would never pay over $500 bucks for any intake system for the F10 M5.
B. It's not a RAM Air system unless it has components that directly channel the air from outside into the intakes. I don't see any components that are of a scoop like design.
C. Like somebody else said Dyno results are easy to post up. I would rather see a video showing 2 F10 M5's side by side, one with the new intake setup the other completely stock. If the car with the intake setup wins, they can have my money. Until then I am skeptical.
      06-20-2012, 06:15 PM   #26
Sean@PSI
Sean@PSI's Avatar
The RAM AIR name comes from the (2) CF air scoops which are mounted on the inside of the front grills, these scoops channel air to the intake boxes.
I have highlighted them in RED below.
Once more information and videos are released I will be sure and post them here ASAP, as I know many members would like to see "real world" results.
This product was only just released officially on 6/14 in Japan.
      06-20-2012, 07:49 PM   #27
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
That's still not RAM air.
You're talking about ducted air into an air box and then into a forced induction engine. Quite simply, it's not ram air. Ram air would imply that you are pressurizing the intake into the engine over atmospheric. Simply, you're providing more air in the intake than the engine (which is nothing more than a fuel / air pump) can pull through at any given RPM and load.
You're not doing that with forced induction. THe pressure in the intake manifold is a function of the turbo and the associated controls (ECU, waste gate, etc.) only. Not the intake. The only thing this intake (or any other intake on a forced induction engine) could possibly do is eliminate vacuum in the intake pre-turbo. That's it. Whether or not that's worth power depends on whether or not the vacuum in the intake prevents the turbo from making maximum boost at the target airflow for the given RPM / load. Vacuum in the intake is bad, but it's not guaranteed to restrict power.
Cool intake, but those gains are hard to believe, even with an engine moving this much air. In order to make that much more power, the stock air filters must be VERY restrictive.
Those little scoops are likely worth less than 5 inches of water in increased pressure inside the air box. Which is about 0.18 psi. I've tested similar systems on a manometer using two x 2" round ducts (high performance ducts such as used on race cars) fed by large oval scoops into the same air box. Max differential was approximately 8 inches of water of pressure.
      06-20-2012, 08:41 PM   #28
Sean@PSI
Sean@PSI's Avatar
To clarify, the RAM AIR name carries over from their line of intakes for all types of engines, including N/A and forced induction. To be more specific, it is the name of the specific product line from GruppeM and nothing else.
The Dyno was from a Dynapack system in Japan. Once we receive the intake stateside, we can have some more tests done with a more familiar dyno system, such as a DYNOJET or a MUSTANG Dyno to alleviate any doubts or concerns.
      06-21-2012, 09:05 AM   #29
Felix Chan
Drives: Blue F10 M5
This is very nice indeed.
      06-21-2012, 09:33 AM   #30
BMWPower06
A^M=G is nothing w/o the Power of ///M
BMWPower06's Avatar
Drives: ///M5 & ///M3
WOW! looks beautiful
Indianapolis Red BMW ///M5
      06-21-2012, 01:45 PM   #31
Ash83
Ash83's Avatar
Drives: 135i & RS5 (SOLD)/ 18 CTS-V
Best engine bay ever!!!!!!!!
Alpine White, Coral RED , Glacier Silver Aluminum trim, M sport, 6MT, NAV, HiFi, USB-iPod, Bluetooth
Performance: JB4|BMW PE|DP Cosmetics: BMW Sport Pedals|Black Kidney Grill
      06-21-2012, 05:00 PM   #32
JC919
Drives: CSL
Originally Posted by 91Octane View Post
Very nice. Expecting $5.5K not including shipping for that.
Fuck that
[SIGPIC][/SIGPIC]
2007 GT3 Clubsport w/CGT buckets in Scotland
2003 CSL, SG, Alcon BBK SOLD
2002 M5, SSII/Blk and bone stock. In storage back home in TX
2008 M3, AW/Blk 6MT, lots of track stuff SOLD
      06-21-2012, 07:51 PM   #33
Sean@PSI
Sean@PSI's Avatar
Originally Posted by JC919 View Post
Fuck that
It is substantially less.
      06-22-2012, 07:59 AM   #34
0-60Motorsports
0-60Motorsports's Avatar
Bahrain
792
Drives: BMW M3 JB 04 Coupe
Very nice! Waiting to see more specs on this but Gruppe M makes some nice intakes with good gains.
Current Mods:
2004 E46 M3cs JB/CSL
2010 E70 X5M AW/BLACK
2011 VW Golf R DSG White/Black
IG: @060Motorsports
      06-28-2012, 02:20 PM   #35
Sean@PSI
Sean@PSI's Avatar
NEW PICS
      06-28-2012, 04:40 PM   #36
mpresiv5
mpresiv5's Avatar
Drives: M6 Gran Coupe
hmm.. intake or exhaust first.. hard choice....
2015 M6 Gran Coupe
BMS Stage 1 Tune, BMS Intake & Chargepipes, Meisterschaft Catless Downpipes.
      06-28-2012, 05:10 PM   #37
Sean@PSI
Sean@PSI's Avatar
GruppeM + Akrapovic will be the perfect combo!
      06-29-2012, 01:50 AM   #38
aus
Drives: Odysse
Originally Posted by clar View Post
I am curious how the power gain comes about?
Originally Posted by M_Power_Fan View Post
i just wonder how the air intake affects power on a turbo engine !?
Unless BMW totally forgot how to design intakes, this is BS.
With the N54, you had to be pushing around 380wHP to have an intake help with power.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      06-29-2012, 02:20 AM   #39
clar
clar's Avatar
Singapore
144
Drives: M5
If there is any gain, it's prob from the less restrictive air filter at the expense of letting in more crap into the engine. I doubt those fancy carbon has any real benefit.
- Frozen Grey F10 M5 DCT
- Rosso Corsa 458 Speciale Sold
- Frozen Grey E92 M3 Sold
      06-29-2012, 02:27 PM   #40
Needsdecaf
Needsdecaf's Avatar
6599
The OEM panel filters flow much better than most people think.
"restrictive filter" is marketing gimmicry.
      07-20-2012, 05:28 AM   #41
Aboody99
Qatar
Drives: F10 M5
3.5k for an Air Intake
      07-20-2012, 12:41 PM   #42
zzzmmm
SICK
9
Drives: MCB F10 M5
3.5k is hilarious.
market this for a mustang and they drop the price to 500 dollars.
      07-20-2012, 04:53 PM   #43
RPiM5
RPiM5's Avatar
2873
Drives: Black M5
Originally Posted by zzzmmm View Post
3.5k is hilarious.
It's prolly gonna be over 3K because all of the parts are made from Carbon Fiber.
I'll give someone $500 max, right now for an intake that is made out of non-carbon fiber that makes real gains in power. And I'm talking YouTube videos of F10 M5's with aftermarket intakes that beat stock M5's without them.
By the way Dinan has confirmed it will be designing an intake system for the F10 M5. So I would hold your breath for that instead.
      07-22-2012, 11:45 AM   #44
///M1
///M1's Avatar
Drives: Many
Puuurty, but it seems that just about it. Oh yeah, and pricey.
My experience with GruppeM hasn't been all that great. Their E39 M5 application was greatly flawed as it was an open-air design and actually sucked hot air in. On the RS 4, caused CELs which no tuner could fix. On either car, their performance gains were never substantiated independently.
Pretty and sexy as Kate Upton, but that's about it... A lot to pay for eye candy, which you rarely even see unless you drive with the hood open. LOL
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
Tags
2012 bmw m5, 2012 m5 forum, 2013 bmw m5, 2013 m5, 2013 m5 forum, air intake f10 m5, bmw f10 m5, bmw m forum, bmw m forums, bmw m5 f10, bmw m5 forum, bmw m5 forums, carbon fiber intake f10 m5, cf intake, f10 m5, f10 m5 air intake, f10 m5 cai, f10 m5 carbon fiber intake, f10 m5 cold air intake, f10 m5 forum, f10 m5 gruppem, f10 m5 gruppem intake, f10 m5 intake, f10 m5 specs, f10 m5 tuning, gruppem f10 m5, gruppem intake f10 m5, intake f10 m5, intake for f10 m5, m forum, m forums, m5 f10, m5 f10 forum, m5 f10 forums, m5 forum, m5 forums, new m5 intake, tuning f10 m5
