BMW X5
      08-12-2018, 10:49 AM   #1
hk5er
No_Country
97
Drives: I20 iX xDrive40i
688 / Harman Kardon Power Output
Just realised that the power output for G05 is only 464W compared to F15's 600W. That's 22.6% drop in power. Anyone with insights as to why? New circuitry maybe, or the new tech taken at the expense of HK system?
Past - E60 535i, F07 535i, G05 X5 xDrive40i
Current - I20 iX xDrive40
      08-12-2018, 04:25 PM   #2
Ibiza
Ibiza's Avatar
Drives: 22 G83 comp & 2024 X5 M60
How many speakers come with the HK? It's an up sell to the B&W 20 speaker/1,500-watt output.
2022 G83 PCD & 2024 G05 S68 PCD
Retired:2021 F95 ZCP PCD,2018 F85 PCD,2018 F83 ZCP- ED/PCD, 2015 X5 50i PCD, 2015 435 vert ED, 2011 X3 PCD, 2011 335is vert ED/PCD, 2007 X3is PCD, 2007 335i vert PCD, 2004 328i vert PCD
      08-13-2018, 02:23 AM   #3
hk5er
No_Country
97
It's the same 16 speakers currently on F15. 7/7/2 setup.
      08-27-2018, 03:43 AM   #4
1230vani
1230vani's Avatar
No_Country
653
Drives: G05 40i LCI
From what I saw HK is cheaper as an option now (like many other options on G05)
      11-19-2018, 08:30 AM   #5
hk5er
No_Country
97
Listened to some music on the H/K sound system on G05. Pleased to report that despite the drop in power, it actually sounded really good and decent (sufficient) power to me. I was playing 160kbit/s music tracks which I previously downloaded on Spotify.
      11-19-2018, 09:05 AM   #6
bigdaveindubai
208
Drives: 2018 540i
My 18 540i HK system sounds much better than my wifes 19 x5 HK system.I have to turn it up 3 quarters of the way to get it as loud as the 540 at only a quarter of the volume.
2018 540i
2019 X5 xDrive40i
2012 Boss 302 #2147
2017 Shelby GT350
2017 F250 KR
      11-19-2018, 09:10 AM   #7
PhatBoyG
212
Drives: 2019 X5 50i
If you're using a Bluetooth source, might make sure the phone has the volume for that output turned all the way up.
lumpydog690.50
      11-19-2018, 09:31 AM   #8
bigdaveindubai
208
Drives: 2018 540i
Oh yeah for sure. Dont get me wrong it still sounds great, its just the power behind it is not the same. Suspect they lowered the watts or changed the brand/type/company for the amp.
2018 540i
2019 X5 xDrive40i
2012 Boss 302 #2147
2017 Shelby GT350
2017 F250 KR
      11-19-2018, 10:42 AM   #9
PhatBoyG
212
Drives: 2019 X5 50i
I'm hopeful the HK is enough, I have the high-end B&O in my current Audi, but I'm also getting older and my hearing isn't what it used to be, plus I mostly stream BT audio from iTunes (downloaded, high quality, but still).
With CarPlay wireless, it doesn't use BT for the audio, it uses WiFi to get an AirPlay quality audio stream - so that should be significantly better as a source.
      11-19-2018, 10:46 AM   #10
BigCactus
74
Drives: X5M Comp F95
You should give some time speakers in your new X5 - after warming through few weeks they will start to sound better.
      11-19-2018, 11:10 AM   #11
AndroidRobot
AndroidRobot's Avatar
Drives: 2022 Porsche Boxster GTS
  [0.00]
2022 Porsche Boxste ...  [0.00]
I've heard it's still a 600W system but there an error on BMWs site. check HKs BMW page to see the 600W system reference.
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order)
2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD)
2018 BMW M2 Mineral Grey(SOLD)
2019 BMW X5 50i Carbon Black/Tartufo (SOLD)
      11-19-2018, 11:33 AM   #12
lumpydog
lumpydog's Avatar
691
Drives: 2019 X5
Bingo.
And to the poster above that caught the bluetooth volume involvement - good call. That will also effect the overall sound. I've found bluetooth volume needs to be all the way up for the supporting source to use its own "normal" audio range.
      11-19-2018, 11:48 AM   #13
Xeno
Xeno's Avatar
315
Drives: 2019 X5 M Sport 5.0i
Would you explain CarPlay wireless music audio?
2019 BMW X5 xDrive 50i M Sport: ZD8/ZLS/ZMP/ZP2/ZPK/ZPX/337/ZX7/2NH
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS retired; 2008 X5 4.8i; 2012 X5 5.0i retired, 2004 X5 4.4i retired
R360c + EL, V1G2 + V1Driver, Uniden R8
      11-19-2018, 11:56 AM   #14
PhatBoyG
212
Drives: 2019 X5 50i
With wireless CarPlay, Bluetooth is only used to negotiate the WiFi connect to the vehicle's access point, after which all music/video/etc. is carried entirely via high-bandwidth WiFi. With more bandwidth available (compared to Bluetooth), the audio quality is the same as if you were playing on an AirPlay device at home (basically). If you have lossless 44 Khz, 16-bit files on your device, that audio stream goes directly to the vehicle audio system without being recompressed.
Xeno315.00
      11-19-2018, 02:26 PM   #15
AndroidRobot
  [0.00]
32bit would be better but anything beats Bluetooth compression
Wild Blue3683.50
      11-19-2018, 04:03 PM   #16
Wild Blue
Wild Blue's Avatar
Drives: 2021 X7 M50i, 2004 330i w/ZHP
this is true.
      11-19-2018, 07:29 PM   #17
skalberti
skalberti's Avatar
Drives: 2017 Mineral White M3
The HK in my F15 sounded way better than the HK in my G05. They were both the same price and the G05 has quite a bit less bass.
It's good to be bad
      11-19-2018, 08:01 PM   #18
yvnrg1981
101
Drives: 2019 M5
I respectfully disagree. the g05 noticeably sounds much better than the f15. I still have another few days left with it and going back and forth between the two the g05 def wins. Also has much better bass than before. G05 is wife's car I have the f86 with the b and o. I can def compare all three offerings and was pleasantly surprised by the hk in the g05
      11-20-2018, 11:26 AM   #19
Wild Blue
Wild Blue's Avatar
Either way, bring on the Bavaudio subwoofer!
      11-20-2018, 11:54 AM   #20
JGoodell
84
Drives: Audi Q7
Do you usually install the Bavaudio subwoofer yourself or will the dealership do that for a fee?
      11-20-2018, 12:56 PM   #21
Wild Blue
Wild Blue's Avatar
Personally, I've only become aware of Bavaudio recently here, but others can chime in.
      11-20-2018, 01:03 PM   #22
VTENGR
1053
Drives: 2020 X5 M50i
From their videos online - if you have a basic knowledge of tools and a torx screw set - you can DIY for maybe an hours worth of your time, if you really take your time. Its a simple as swapping out the old sub with the new. No retro fitting or anything like that. Simply remove the seat (4 bolts) tilt it back, remove the sub and housing, replace sub, reinstall sub and housing. While you're in there, you may want to add some dynomat to help insulate the sub even more and maybe increase the performance of the sub some.
xbimmers
